Jack and Jack Stand Suggestions
Discussion in 'Technical Chat' started by ahkouchi, Oct 21, 2016.
  1. Oct 21, 2016 at 8:14 PM
    ahkouchi
    ahkouchi [OP] Well-Known Member
    Andrew
    Big Island Hawaii
    2016 Magnetic Gray Metallic Tacoma
    Front Elka 2.5 non resi with 650lb spring Rear Serviceable 5160's with AAL 265/75/r16 BFG KO2
    Hey guys,
    Just looking for some advice on what you would recommend for a decent jack and jack stands. Before everyone starts recommending harbor freight, let me start by staying I live in Hawaii so they are not an option. What is an option is Amazon prime :), Sears, Costco, Wal Mart, K Mart. Those places have free shipping or shipping that won't bend me over and go in raw. I'm not looking for anything that is amazing, just something reasonable that won't break the bank. Also, something where i won't have to use blocks of wood anymore. I almost had my Tacoma fall today after the wood cracked. I have been getting away with using wood and car stands positioned in the right places but id like to stop doing that now.
    thanks for your guys help
    MandoTaco666 likes this.
  2. Oct 21, 2016 at 8:17 PM
    TacoRD16
    TacoRD16 Well-Known Member
    Houston, TX
    2016 Tacoma TRD Off Road 4x4
    Fox 2.5 RR C/O Fox 2.0 RR Rear Dakar leaf Pack Headstong Brakeline Extension Bracket 16"Konig Countersteer wheels BFG's KO2 285/75r16 All-Pro UCA 1.25" All-Pro APEX Slidders Unided CB w/ Firestick II Lamin-X fog Lens 1" Diff Drop OME 1/2" CB Drip OME Mobtown 3/16" Skid plates: Front, Trans and Transfer case Relentless Hood Brackets AuxBeam Ditch Lights DBCustons Grill "Recolored" Matt Black Relentless High Lift Mount Softopper Diff Breather Mod Tail Gate Inserts HondoGarage Tablet Vent Mount Weather Tech Floor Liner
    harbor freight...
    Blais03, 1madmnky and t4daddy like this.
  3. Oct 21, 2016 at 8:23 PM
    ahkouchi
    Andrew
    Big Island Hawaii
    I knew that was coming! Thanks for being the first one :)
    greeneggsnspam likes this.
  4. Oct 21, 2016 at 8:32 PM
    TacoRD16
    Houston, TX
    Well its true...literally bought a 3 ton jack and 2x 6 ton jack stands last month for $100
  5. Oct 21, 2016 at 9:01 PM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    This Arcan 3 ton jack is similar to one I got on craigslist (I'd suggest checking there, though obviously you may find limited selection) and it's worked really well for me. This 2 ton Arcan (with Prime) or this 3 ton Powerzone also look reasonable to me and won't break the bank (with shipping).
    Jack stands - these are good ones for Taco's on Prime - Torin T46002A 6 ton, since they have good height.
    Biscuits likes this.
  6. Oct 22, 2016 at 1:42 AM
    ahkouchi
    Andrew
    Big Island Hawaii
    sweet thanks! those stands look good. I have the Arcan 2.5 ton one from costco. it's like 3 or 4 years old. still going strong but it barely lifts the tires off now that i have a lift and larger tires. i'm looking for something with a little more height.
  7. Oct 22, 2016 at 1:43 AM
    ahkouchi
    Andrew
    Big Island Hawaii
    I believe you man. I see all the things people are getting from HF on the forums here and from other forums and it sucks we don't have one here. But in a way it's good, Id be broke if we did lol
  8. Oct 22, 2016 at 3:25 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I have to ask Does any one repair Hydraulic jacks in your area ??
    I got hooked up with my local Hydraulic Repair Shop they sell what they service I need new Jack Stands or another Jack they are my go to people
    Worth a try
    It also depends just what type of projects your getting into
  9. Oct 22, 2016 at 10:53 AM
    RobertHyatt
    RobertHyatt You just can't fix stupid...
    Robert
    Birmingham AL
    2007 Tacoma Prerunner SR5
    For the jack, go to your local building supply and buy a 4x4 post. Cut off about 8" and put that sideways on top of the jack pad. You just increased your lift height 4" for very little cost. If you want more stability, buy a couple of bolts, and then drill/tap the jack pad to match. Run bolts through the block to lock it down solid if you are concerned. I've been using this for years to get the rear of my boat up off the bunks so I can clean/wax the bottom in the off-season.
  10. Oct 31, 2016 at 8:36 AM
    RichVT
    RichVT Well-Known Member
    Rich
    Northern Vermont
    2016 Tacoma TRD Off Road 4X4 AC Grey
  11. Oct 31, 2016 at 8:53 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    I bought a decent floor jack at my local Napa auto parts. Any of those in Hawaii?
  12. Oct 31, 2016 at 12:26 PM
    ahkouchi
    Andrew
    Big Island Hawaii
    Ill hit up napa! they tend to be pricy here and the service sucks ass. For those reasons i try to avoid them like the plague lol
  13. Nov 4, 2016 at 7:57 PM
    757yotas
    757yotas Well-Known Member
    Virginia
    2007 TRD Sport
    ICI Magnum front bumer Rigid LED lighting OME lift 285/70 Nitto Exos 17" Fuel Hostage TRD Exhaust TonnauPro Cover Oil Catch Can Tint Pioneer Nav system Sound System LED lighting Euro headlights Paint
    I have 3 ton jack stands from walmart and they work just as good as any other ive used and they cost alot less.
  14. Nov 12, 2016 at 4:11 PM
    JJ04TACO
    JJ04TACO Well-Known Member
    Jim
    Dallas
    04 White DC/TRD
    Fox 2.5 RR front, 2.0 RR rear from AccuTune Offroad, OME Dakar Leafs, Camburg Uniball UCA's, CBI Offroad Bolt on Sliders w/kickout, Scangauge II Uniden Bearcat 880 w/ 3' Firestick on CBI antenna mount B&M Trans Cooler
  15. Nov 14, 2016 at 7:54 AM
    Xyphon112
    Xyphon112 Well-Known Member
  16. Nov 16, 2016 at 7:02 PM
    BlindingWhiteTac.
    BlindingWhiteTac. Well-Known Member
    Thomas
    Vancouver, WA
    07 LQ4 4L80E
    Just the essentials and no extra fluff.
