Jack and Stand
Discussion in '2nd Gen. Tacomas (2005-2015)' started by linkfeeney, May 26, 2020.
  1. May 26, 2020 at 11:12 AM
    linkfeeney
    linkfeeney [OP] Well-Known Member
    link the stink!
    Sewell, NJ Eh!
    09 Doublecab TRD Off-Road! Magnetic Grey!
    Hey guys
    looking to get a new floor jack and stands for the truck... what do you guys recommend??
    thank you!
  2. May 26, 2020 at 11:18 AM
    JoosBox
    JoosBox Well-Known Member
    Pat
    Boise, ID
    2007 TRD OR
    Harbor Freight! If you’re only using them for light truck maintenance and don’t plan to use the hell out of them than why get anything nicer.
    Or the old ones in grandpas shed, those are best value haha
    Spare Parts and linkfeeney[OP] like this.
  3. May 26, 2020 at 11:21 AM
    eon_blue
    Azusa, CA
    There was a huge recall on Harbor Freight 3 and 6 ton jack stands recently so I'd steer clear of those, or at least make sure you buy new ones and check the serial numbers to make sure they aren't part of the recall (shouldn't be on the shelves anymore anyway).
    Personally I'd spend a little more $ on jack stands and get the kind that have the safety pins on them, the HF ones don't come with safety pins.
    The Harbor Freight floor jacks are great though, have had my 3 ton one for a few years and no issues other than having to bleed it once (normal maintenance for a floor jack).
  4. May 26, 2020 at 11:22 AM
    six5crèéd
    six5crèéd Be the light
    Southern Virginia
    8 lugs no plugs
  5. May 26, 2020 at 11:48 AM
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    I want a good quality stand and jack... but there is a lot out there...
    I was thinking about going to facebook marketplace to look for used ones... but I wasn't if they are garbage or not.
    six5crèéd likes this.
  6. May 26, 2020 at 11:58 AM
    Qauthority
    Qauthority Well-Known Member
    So Cal
    2020 Tacoma
    Lifted Custom Rims Blackout Package
    the Daytona floor jack’s are great. I have the 3 ton low profile version and it’s very nice. Jacks up easy with a few pumps and releases smoothly when lowering the vehicle.
  7. May 26, 2020 at 12:04 PM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    HF had recalls on some jack stands. Be careful. Don’t end up like a pancake!
  8. May 26, 2020 at 12:06 PM
    tamer
    tamer hamerworx.com
    NorCal
    2015 TRD OR AC, MGM, 4x4, 6spd MT
    TexasWhiteIce likes this.
  9. May 26, 2020 at 12:06 PM
    linkfeeney
    link the stink!
    Sewell, NJ Eh!
    so should I look at Amazon or home depot? fb marketplace looks like shit.
  10. May 26, 2020 at 12:10 PM
    hemitruk
    hemitruk Old man , young boi truk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
  11. May 26, 2020 at 1:27 PM
    spitdog
    Amazon sells one that also utilizes a pin as a secondary safety mechanism. So you have two methods that safe guards the jack stand from collapsing. There only a few buck more than HF
    MrFixit420 likes this.
  12. May 26, 2020 at 2:41 PM
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    The one on left model a jack . Was at friends house the other day and so happened to show me his modal a jack . I thought it was cool .Neva thought anyone with a mind would think of using those lol. :thumbsup:
    In&out likes this.
  13. May 26, 2020 at 2:42 PM
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Now on to some legit post . Dumb ass me:crazy:
  14. May 26, 2020 at 4:20 PM
    jproffer
    jproffer Well-Known Member
    Jim
    Perryville, MO
    '15 MGM Sport DCLB, V6
    Heresy!!! :argue:
  15. May 26, 2020 at 5:16 PM
    Micbt25
    Micbt25 Well-Known Member
    TM
    2015 MGM TRD Sport Access Cab 4X4 V6
    I have the following 6 ton jack stands that I’ve used a couple times and really like them, I have 3 ton Torin jack stands that have worked great. I like these new stands because they’re double pin:
    Pro-LifT T-6906D Double Pin Jack Stand - 6 Ton, 1 Pack
    $46 Pro-LifT T-6906D Double Pin Jack Stand - 6 Ton, 1 Pack
    https://www.amazon.com/dp/B074R17GL4/ref=cm_sw_r_cp_tai_x17XEb0XJFB4V
    I also have this floor jack that has worked well:
    Husky 3-Ton Low Profile Floor Jack with Speedy Lift (Model # HD00120-DIP)
    https://www.homedepot.com/p/Husky-3-Ton-Low-Profile-Floor-Jack-with-Speedy-Lift-HD00120-DIP/307751401
    Only thing I would change is I would have gotten high lift floor jack, the one above goes up to 19-3/4 in., which isn’t bad, but the harbor freight Daytona high lift jack goes up to 24:
  16. May 27, 2020 at 12:04 AM
    hemitruk
    Kurt
    Hawaii
    2010 Dbl Cab Sport,
    A few
    Tried Napa ?
  17. May 27, 2020 at 7:01 AM
    Muldoon
    Muldoon Well-Known Member
    Robert
    Northeast Ohio
    2009 4x4 ACLB TRD-OR 4.0, Green
    5100s, Wheelers AAL, Leer 100R
    HF is fine for a Jack, but jack stands it’s good to make sure they’re good. If a jack fails it’s a bummer but probably isn’t going to kill you, if a jack stand fails, it could easily kill you. I have the AC Delco 6 ton stands and like them a lot. Price was good, I like that they provide more height than the 3 tons, and I also really like that the feet have metal pads on them so they won’t sink into gravel or softer ground as readily.
    https://www.oreillyauto.com/detail/...39b8f/acdelco-6-ton-jack-stands/34115/2494162
  18. May 27, 2020 at 7:09 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
  19. May 27, 2020 at 9:07 AM
    jproffer
    Jim
    Perryville, MO
  20. May 27, 2020 at 9:19 AM
    Muldoon
    Robert
    Northeast Ohio
