Jack and Stand
Discussion in '2nd Gen. Tacomas (2005-2015)' started by linkfeeney, May 26, 2020.
  1. May 27, 2020 at 9:24 AM
    jproffer
    jproffer Well-Known Member
    Jim
    Perryville, MO
    '15 MGM Sport DCLB, V6
  2. May 27, 2020 at 9:25 AM
    eon_blue
    Azusa, CA
    uh...I think 22 tons is a little bit overkill lol
  3. May 27, 2020 at 9:31 AM
    jproffer
    Jim
    Perryville, MO
    Definitely a LOT overkill lol.............
    Still don't mean I wont buy them :) . Jack stands is one thing I don't mind overkill.
    TacomaCZman and crackils like this.
  4. May 27, 2020 at 9:35 AM
    eon_blue
    Azusa, CA
    For sure, I'd just worry that they might be wayyyy too big. The problem I have with the 12T Harbor Freight stands is that they take up so much space under the frame, I can't imagine what a 22T stand looks like. Although those are a different style than the ones I'm used to
    Really though 6T stands are pretty overkill for our trucks. Most jack stands are rated in pairs though, which is something to keep in mind....meaning a pair of 6T stands individually hold only 3T each. Together they hold 6T. I'm not sure if its the same with those 22T stands but I would assume so. Still way overkill lol
    TacomaCZman likes this.
  5. May 27, 2020 at 9:38 AM
    jproffer
    Jim
    Perryville, MO
    I'm assuming 22 together. Didn't read close enough to find out.
    I have a pair of 3 tons from HF, not the recalled ones but the blue ones. But they're not through-pin style so I only use them for holding up parts....not the whole truck. One because they're 3T...two because they're from HF and since last week for some reason, I'm questioning ALL jackstands from HF :)
    eon_blue likes this.
  6. May 27, 2020 at 9:40 AM
    eon_blue
    Azusa, CA
    yeah same here but the 6T ones from Harbor Freight. Mine weren't part of the recall but even still, I'm looking for a new pair that has the safety through pin in them as well. I'll keep the 6T ones for backups or whatever. I only use the 3T stands for holding up the rear axle when I do tire rotations or leaf spring work.
    jproffer[QUOTED] likes this.
  7. May 27, 2020 at 9:41 AM
    eon_blue
    Azusa, CA
    Oh and the 3T stands are what I bring with me on offroad trips in my tool kit, since they're smaller. In case I need to swap out a CV axle or change out a flat. I have a Hi-Lift too but after changing out a CV axle in the snow using only a Hi Lift once, I don't intend on doing that again lol. Talk about sketchy
  8. May 27, 2020 at 9:43 AM
    jproffer
    Jim
    Perryville, MO
    Yep same here...driveshaft so I don't have to hold it up...esp since I'm stretched out anyway just to reach it. I'd be ok with using the 3T for rear end work. Shit like that
    eon_blue[QUOTED] likes this.
  9. May 27, 2020 at 9:44 AM
    jproffer
    Jim
    Perryville, MO
    LOL, yea that don't sound like fun. Watch what you're doing with one eye....watch the jack with the other...can't concentrate on either....yea, no thanks
  10. May 27, 2020 at 9:53 AM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    jproffer likes this.
  11. May 27, 2020 at 9:54 AM
    eon_blue
    Azusa, CA
  12. May 27, 2020 at 10:25 AM
    Muldoon
    Muldoon Well-Known Member
    Robert
    Northeast Ohio
    2009 4x4 ACLB TRD-OR 4.0, Green
    5100s, Wheelers AAL, Leer 100R
    The Delco’s I have are 6T, rated 6T each, 12T/ pair. I got them because they are higher than the 3T without ratcheting the extensions at all, so I can get under the truck to comfortably work and apply fluid film without having to extend them too much, so they feel safer in that regard.
  13. May 27, 2020 at 10:27 AM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    ESCO jack stands are really nice
    ...I have HF 3 ton....but one day I will upgrade...shouldnt skimp on life or death safety equipment
  14. May 27, 2020 at 10:28 AM
    jproffer
    Jim
    Perryville, MO
    Now that I could do. If I didn't have to extend them, or extend them very little...a click or 2...I'd be ok with it I think. Just don't like the easy up adjustment.
  15. May 27, 2020 at 10:29 AM
    #35
    Muldoon
    Robert
    Northeast Ohio
    Yeah I can see the secondary pin feature being a good idea.
