Jack is too small now
Discussion in '5 Lug' started by rambo33hockey, Oct 5, 2015.
  1. Oct 5, 2015 at 11:02 AM
    rambo33hockey
    rambo33hockey [OP] Member
    matt
    powell
    08 2wd reg cab
    2" lift, Custom Painted Interior, Tires,
    So i did the classic lift and tires, but now my stock jack doesn't lift my truck. Are there any jacks out there that are bigger and fit into the stock location or can be mounted under the truck?
  2. Oct 5, 2015 at 11:03 AM
    Boone
    Boone Vaginas are rad.
    Boone, NC
    Airbags deployed
    Forklift mod.
    DustStorm4x4 likes this.
  3. Oct 5, 2015 at 11:04 AM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    I have 6 ton stands from Harbor Freight and I use a block of wood on my Harbor Freight jack
  4. Oct 5, 2015 at 11:04 AM
    Rattletrap66
    Rattletrap66 (ノಠ益ಠ)ノ彡┻━┻
    Frank
    Tampa, FL ☜(゚ヮ゚☜)
    2014 TRD Off Road DCSB
    ╭∩╮(ಠ۝ಠ)╭∩╮
    Just use some wooden blocks
  5. Oct 5, 2015 at 11:05 AM
    rambo33hockey
    matt
    powell
    08 2wd reg cab
    do you have a link to that i cant find it?
  6. Oct 5, 2015 at 11:10 AM
    scocar
    scocar hypotenoper
    Do you mean a bottle jack for changing flats? If just for that, you should be able to jack up just the LCA or the rear axle as needed. If not, as someone else said, blocks of wood. A couple pieces of 2x4, maybe a block of 4x4, and a small piece of plywood for putting underneath it for use in sand or dirt.
  7. Oct 17, 2015 at 10:36 PM
    Vang Toua Moua
    Vang Toua Moua Well-Known Member
    Vang Bang
    Visalia, CA
    05 Silver Tacoma 2.7, Access cab, 5 lug
    Custom front bumper and rock sliders, glasspack muffler, shorten exhuast, abs killswitch, roof light bar, rear e locker.
    I got a hi lift on my 5 lugger because of that issue.
  8. Oct 17, 2015 at 10:39 PM
    Tom Servo
    Tom Servo Dickweed
    Thornton, CO
    2013 DCSB TRD Sport
    Lol
