Jack is way to small for my taco
Discussion in '1st Gen. Tacomas (1995-2004)' started by dvschramm, Aug 13, 2013.
  1. Aug 13, 2013 at 12:58 PM
    dvschramm
    dvschramm [OP] New Member
    Rockaway Beach, NY
    04 Taco
    I have a 2004 Taco Limited SR5 4x4 and the supplied jack is in no way big enough.
    I have this model:
    http://www.villagetoyotaparts.com/p...-4-SPEED/HANDLE--JACK/1997400/0911304020.html
    I got my truck second hand and I'm not very mechanically inclined so I'm not sure if it's been jacked up or not (it definitely has nice clearance). I should really have a jack to change my tire or get me out of bad situations. Suggestions on a new one, or should I just head to the auto parts store?
  2. Aug 13, 2013 at 1:16 PM
    zacharypaul89
    zacharypaul89 Eat right, be fit, die anyway
    Zach
    Georgia
    2019 Quicksand Trd Offroad
    After lifting mine 3'', the OEM jack didn't work. Just put a few bricks under the jack and it should work just fine.
  3. Aug 13, 2013 at 1:19 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    Mine in my 03 4x4 and it lifts just fine. There is a certain spot that the jack goes in the front, under the A arm i think. Not sure in the rear i will have to look, dont remember right off hand.
  4. Aug 13, 2013 at 1:33 PM
    WThomas1250
    WThomas1250 Well-Known Member
    My OEM jack sucks as well. My suspension is stock (although I do have the TRD package) the supplied jack barely lifts my tires up high enough.
  5. Aug 13, 2013 at 1:52 PM
    tomtom
    tomtom Well-Known Member
    The Desert SW
    2012 FJ
    Check the owner's manual for jack points. Should be the transfer case crossmember in the front and the rear axle housing for the back.
    If it has been lifted, you may not be able to jack the front up with the bottle jack unless you use a block of wood, brick or something very solid as a base underneath the jack.
    You should still be able to get the rear off the ground unless you are running some very, very oversized tires.
    You're other option is to get a hi-lift but unless you put on some sliders or off-road bumpers, you have no lift point to use the hi-lift on.
  6. Aug 13, 2013 at 1:57 PM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
    Whose jack???
    I keep a block of 6inch wood or something in an ammo can in my bed to put under the jack.
  7. Aug 14, 2013 at 5:22 AM
    dvschramm
    Rockaway Beach, NY
    04 Taco
    Ok, I think this is the issue. I'm looking in the 'normal' spots for jack points (infront of back tires, behind front). I'll check the manual. Thanks.
  8. Aug 14, 2013 at 5:24 AM
    dvschramm
    Rockaway Beach, NY
    04 Taco
    I don't know jack!
    Yeah, I'm getting a beach driving pass this week and they require a piece of wood as a jack base. I'm going to have to do the same.
  9. Aug 14, 2013 at 5:42 AM
    Sloth
    Sloth Baby Ruth?
    Seth
    Democratic Peoples Republik of Massachusetts
    07 FJ Cruiser, 98 Landcruiser
    Stuff
    You could also get the lift mate to go with a hi lift jack, which allows the hi lift to lift the vehicle by the wheel. Then you just need jack stands to hold it up.
  10. Aug 25, 2013 at 5:58 PM
    Bahamayellow
    Bahamayellow Well-Known Member
    2002 tacoma sr5
    I have an 2002 tacoma 4x4 with the stock height that i bought brand new. First thing I did was toss out the stock bottle jack. I carry a 40 dollar 2 ton standard jack with a pump up handle in my tool box.
  11. Aug 25, 2013 at 6:02 PM
    KenLyns
    KenLyns 8.75" Third Member
    Belly of the Beast
    4x4 TRD Off-Road Full-Auto
    In the front, you can put the jack under the lower control arm. In the rear, put the jack under the axle tube. These two jacking points are not sensitive to any installed lift. A few cranks is enough to get the tire off the ground. I still use the stock jack, but pack an 18" breaker bar and socket, since the stock lug handle isn't long enough to loosen the lugnuts.
  12. Aug 25, 2013 at 7:04 PM
    mmcmahan2206
    mmcmahan2206 Well-Known Member
    McCall, Idaho
    00 Tacoma SR5 TRD 3.4L
    6" FabTech suspension 3" body lift, 35x12.50R15 BFG AT T/A KO tires, Mickey Thompson Sidebiter wheels, 4:88 front and rear gears, e-locker, "grey wire mod," Hella driving lights retroed to 55w 8000K HIDs, custom grill, Downey chrome air intake w/ AEM filter, AirAid throttle body spacer, Flowmaster exhaust, Alpine audio w/ 12" RF sub, racing bucket seats, black powdercoated toolbox, smoked out black taillights, black headlamps and corners, red LED interior lights, sway bar removed, rear shock relocation, u-bolt flip mod, 01 center console, Relentless Fab front plate bumper, LED fog lights.
    I just use my Xtreme Hi-Lift 60" that can lift both my rear tires off the ground by lifting from the hitch, or one side on the front by lifting from my plate bumper lift points! :p Just get yourself a bumper and a jack! ;) :D
  13. Aug 25, 2013 at 7:18 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    Either use the stock jack with a block of wood, old brake rotor, etc.. or this:
    + lift mate:
  14. Aug 25, 2013 at 7:57 PM
    KenLyns
    Belly of the Beast
    How does the lift mate work for changing a punctured tire?
  15. Aug 25, 2013 at 7:59 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    Lift truck, put jack stand under truck, remove jack, change tire, re-set jack, remove jack stand, lower vehicle, proceed with lulz:confused:
  16. Aug 25, 2013 at 8:00 PM
    blakes09
    blakes09 Toyota Tech..when im not Fishing
    Blake
    Deep South
    4x4
  17. Aug 25, 2013 at 8:19 PM
    KenLyns
    Belly of the Beast
    You carry an axle stand in the truck for changing a flat?
  18. Aug 25, 2013 at 10:19 PM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    If your truck hasn't been lifted, the stock jack, with some well-chosen profanity, should work. I always carry a short piece of 4x4 and 2x4 in the truck, so I have either 2, 4, or 6 inches of extra reach. Enough to change a tire.
  19. Aug 26, 2013 at 12:34 PM
    Sloth
    Sloth Baby Ruth?
    Seth
    Stuff
    I always have two jack stands in my truck. And an old rotor to use as a larger foot for the jack stand. And ya, I put it on jack stands whether I'm using the stock jack or hi lift, even just changing a tire. Takes an extra whole 3 seconds, and it gives me price of mind
  20. Aug 26, 2013 at 1:07 PM
    tomtom
    The Desert SW
    2012 FJ
    If you have the cargo space, no reason not to.
