Jack kit
Discussion in '1st Gen. Tacomas (1995-2004)' started by Justrydin, Feb 20, 2021.
  1. Feb 20, 2021 at 12:52 PM
    Justrydin
    Justrydin [OP] New Member
    02 Tacoma sr5
    I do not have a jack kit for my 02 Tacoma. The spare tire is present. Do I need any special tools for this or can I go with aftermarket tools?
  2. Feb 20, 2021 at 12:56 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
    Welcome to TacomaWorld
    You'll need the tool to lower the spare below bed to ground.
    It's the folding crank rod also used for jack.
  3. Feb 20, 2021 at 1:00 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Or anything with a flat tip.
    I used a flat head bit (large one) at the end of an extension with a socket wrench and undid mine on the Tacoma; I had no spare tire tools.
  4. Feb 20, 2021 at 1:01 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Improvise adapt and overcome gents :burp:
    Wyoming09 likes this.
  5. Feb 20, 2021 at 1:23 PM
    Justrydin
    02 Tacoma sr5
    Thanks for the info. I will look into this. I might be able to save a buck or 2 using the above mentioned ratchet method.
  6. Feb 20, 2021 at 9:41 PM
    jnossoff
    jnossoff 2000 Xcab Pre-Runner with Leer 122 shell
    Joel
    Albuquerque NM
    2000 PreRunner SR5 TRD Xcab V6 A/T
  7. Feb 21, 2021 at 7:52 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Then it all depends where the truck lives .
    Living in the great liquid brine belt cutting was the only way to remove the spare.
    mine lives quite happy now in the bed no more crawling in the slop to check the air pressure.
