Jack points..
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wawireguy, Apr 11, 2009.
  1. Apr 11, 2009 at 3:33 PM
    wawireguy
    wawireguy [OP] Well-Known Member
    The manual says the front jack point is on the side rail? Won't this let the front suspension extend quite a lot? Can you just jack the A arm or whatever it's called up? What do you guys do?
  2. Apr 11, 2009 at 4:17 PM
    Brunes
    Brunes abides.
    Rotorhead
    NO-Jacking from the LCA is a bad idea- it's a sloped surface and the jack/truck can slip and fall.
    You'll get enough clearance using the factory jacking points to get the tire off.
  3. Apr 11, 2009 at 5:07 PM
    wawireguy
    Jacking from the LCA worked fine. Put a piece of 2x4 in there to distribute pressure a little. Not recommending other peeps do it but I did put a jack stand under the frame also. Tires are rotated!
  4. Apr 11, 2009 at 5:09 PM
    Brunes
    Brunes abides.
    Rotorhead
    Yeah...Lots of things CAN work man...Glad you put the jackstand under there because it runs a solid risk of falling...
  5. Apr 11, 2009 at 5:12 PM
    wawireguy
    I always put something under the truck. Block the tires and set the e-brake also.
