Jack points
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tacomaislife, Apr 29, 2019.
  1. Apr 29, 2019 at 8:20 AM
    Tacomaislife
    Tacomaislife [OP] Well-Known Member
    Texas
    2002 tacoma trd
    Hello does anyone have a idea were the jack point are I'm trying to change my brake pads 1556551034799390706479.jpgdo i jack it up from here or from here
  2. Apr 29, 2019 at 9:49 PM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    I'd go with pic number 2, it's solid point for floor jack.
  3. Apr 30, 2019 at 1:59 AM
    Tacomaislife
    Texas
    2002 tacoma trd
    Okay thanks any idea were I should put a jack stand
  4. Apr 30, 2019 at 6:00 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    Here is my recommendation for if you have a floor jack and assuming you mean for the front brakes.
    Jack up the whole front end by placing your floor jack in the center of the cross brace under the engine. You may need a spacer (piece of wood) on top of your jack to get enough travel due to suspension sag.
    Then put a jack stand on both sides of the cross member. If you have too (lack of width), move the jack a bit to one side of the brace, lift and place the stand on the opposite and only go with a single at a time. Not preferred.
    Putting the stands under the A-Arm absorbs the suspension sag, but I just don't think it's as safe/stable a placement point due to having the spring compressed with a wheel off. If I use that method, I leave my jack under the center brace with slight pressure so I know if the jack stand releases, the truck wont fall all the way to the floor.
    Chock your rear wheels, parking brake on, etc...I've seen guys lay the wheel/tire under the frame or A-Arm in case the truck falls.
    Area51Runner likes this.
  5. Apr 30, 2019 at 1:51 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
