Jack Questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Wolftaco0503, Feb 6, 2017.
  1. Feb 6, 2017 at 4:13 PM
    Wolftaco0503
    Wolftaco0503 [OP] Well-Known Member
    Adam
    Chicago
    2013 Super White LONG BED TRD SPORT 4x4
    Maglite mod Bottle Opener in bed Weathertech Mats Front & Back
    Is the stock bottle jack enough to lift a Taco to change a stock size tire? If not what should I get? I know enough that to say a high lift won't work with sliders.
  2. Feb 6, 2017 at 4:41 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
  3. Feb 6, 2017 at 4:43 PM
    jowybyo
    jowybyo Well-Known Member
    Joe
    Baltimore, MD
    '14 MGM DCSB Postrunner 4wd Conversion, Debadged
    I'm not sure I understand what you're saying here. A Hi-Lift works very well with sliders.
  4. Feb 6, 2017 at 4:44 PM
    Wolftaco0503
    Adam
    Chicago
    Meant to say that a high lift won't work with out sliders
  5. Feb 6, 2017 at 4:47 PM
    inwood customs
    Dave
    Another option..... carry a few 2x4s cut to 18ish inches.
    Or a 4x4....
    Ymmv, the frame is not your only option with the bottle jack, shit even my tallest floorjack will barely touch the frame with a 2" lift. Even my old 2 ton stands would just touch frame fully extended.
    Its dependent on lift and tire size, as well as what lift points u wanna use.
  6. Feb 6, 2017 at 4:52 PM
    Wolftaco0503
    Adam
    Chicago
    I have no Lift and stock tires
  7. Feb 6, 2017 at 4:59 PM
    jowybyo
    Joe
    Baltimore, MD
    Haha yup. That makes sense. It is certainly harder without sliders or plate bumpers.
  8. Feb 6, 2017 at 5:01 PM
    SuperBad
    SuperBad Well-Known Member
    Dallas, TX
    2017 MGM Tacoma OR DCSB
    Truck stuff
    Stock tires and stock height is what the stock bottle jack is meant to be used for. They arent going to give you a jack that wont work when everything is stock. Just follow the directions in the owners manual on where to use the jack.
    QChawks and inwood customs like this.
  9. Feb 6, 2017 at 5:05 PM
    GHOST SHIP
    GHOST SHIP hates you.
    GHOST
    In case of emergencies, you can use the stock jack under your LCA or the rear axle. It will lift from the frame if the truck is completely stock and on flat level ground, but it's usually at the end of it's ability at that point and I wouldn't trust it. Keep in mind that off-camber situations will also affect the amount you need to jack the truck up to get the tire off the ground.
    If you're at home and have time, I'd suggest a good floor jack, maybe some 2x4's as other have mentioned.
    People have had good fortune with the HF jacks. I have one in the garage and love it.
  10. Feb 6, 2017 at 6:44 PM
    BlindingWhiteTac.
    BlindingWhiteTac. Well-Known Member
    Thomas
    Vancouver, WA
    07 LQ4 4L80E
    Just the essentials and no extra fluff.
    A high lift jack used with the lift mate and a jack stand.
    jowybyo likes this.
  11. Feb 6, 2017 at 8:11 PM
    QChawks
    QChawks Well-Known Member
    Davenport, IA
    2009 TRD Sport DCLB
    +1
    It's a pain to use compared to my rapid pump shop jack but it will work in a pinch.
  12. Feb 6, 2017 at 9:20 PM
    bluezzy
    bluezzy Love My SuperCharged 07 Sport!
    Monty
    Eugene, Oregon
    I have 275-17s with a 3" lift and last Friday the stock jack worked just fine. However, I do want to get a hi-lift as soon as I can.
  13. Feb 7, 2017 at 7:14 AM
    BlueWaffleTaco
    BlueWaffleTaco Well-Known Member
    Brendan
    Stl (wentzville) MO
    2007 Blue Double Cab sr5 trd sport
    SOS CONCEPT ROCK SLIDERS, CALI RAISED LED w/ STEALTH MOUNTS, THULE ROOF RACK, 3" ROUGH COUNTRY BODY LIFT w/ 5100 BILLYS, VISION WHEELS W/ 285 70 R17s, AFTERMARKET HEAD UNIT, SOON TO BE OWNER OF NEW FRAME
    have a 3 inch lift with 33s how much range should my hi lift have? Don't want to buy the 54" one if its not needed.
