Jack Size?
Discussion in 'Technical Chat' started by se2schul, Jul 12, 2010.
  1. Jul 12, 2010 at 9:40 AM
    se2schul
    se2schul [OP] Member
    Ottawa, ON, Canada
    2006 TRD Off Road
    Is a 2 ton jack sufficient for my Tacoma, or do I need to go with the 3 ton jack?
  2. Jul 12, 2010 at 9:47 AM
    1337Taco
    1337Taco Sold all 3
    Kevin
    NorCal
    2012 4x4
    Kings
    I would go with a 4 ton atleast.
  3. Jul 12, 2010 at 9:49 AM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    Build thread in sig...
    sufficient as far as weight capacity...it will struggle, but work fine.....problem you will more than likely run into is that it will not have enough lift height.
  4. Jul 12, 2010 at 9:50 AM
    se2schul
    Ottawa, ON, Canada
    2006 TRD Off Road
    How much lift height do I need for a stock Tacoma?
  5. Jul 12, 2010 at 9:52 AM
    scocar
    scocar It's not rocket surgery
    Dick
    In close proximity to an undisclosed location
    2015 DCLB 4x4 SR5
    Mostly pallet racks loaded with very impressive boxes, and a smashed head unit
    2 ton is pretty lightweight, and it may not have enough vertical lift without blocks (which you should avoid using for safety). I have an Arcan 3.5 ton I got at Costco for $89 (Northern Tool has it too, but for about $135) and it is pretty effortless, and great control on lowering. Others have been happy with it too. Check out the garage forum. ;)
  6. Jul 12, 2010 at 9:52 AM
    colinb17
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    i had a 2 1/4 ton that i think had 15 inches of lift. it worked fine on teh back (under the axel), but i had to use a block of wood to get the front. i now use a 3 ton that has 21 inches of lift and it works like a dream. i'd say 17-18 would probably be enough for the factory jack points.
  7. Jul 12, 2010 at 9:55 AM
    scocar
    Dick
    2015 DCLB 4x4 SR5
  8. Jul 12, 2010 at 10:10 AM
    Zombie Runner
    Kevin
    Wichita Falls, TX
    2011 taco, sport 4x4
    oil change...
    check harbor freight, 60 bucks for a lightweight 3 ton jack.
  9. Jul 12, 2010 at 10:10 AM
    se2schul
    Ottawa, ON, Canada
    2006 TRD Off Road
    Thanks guys. I hadn't even thought about the lift height.
  10. Jul 12, 2010 at 10:12 AM
    se2schul
    Ottawa, ON, Canada
    2006 TRD Off Road
  11. Jul 12, 2010 at 10:44 AM
    colinb17
    Colin
    Lusby, MD
    '07 TRD Sport 4x4
    x2 on what kevin said. and you can't beat the price.
    $80 + 20% off with the cupon you can get in just about any magazine now
    http://www.harborfreight.com/automo...on-capacity-low-profile-floor-jack-94629.html
    this is the one i have. i probably use it twice a week, so it diffinately gets put through it's paces. it get's some pretty heavy use on the weekends too becasue i'm usually helping out friends. great quality and takes a beating. it's a little on the heavy side (abotu 80 lbs), but for a home use jack, that's not really an issue.
