jack stand question...
Discussion in '3rd Gen. Tacomas (2016-2023)' started by kiki111, Sep 30, 2020.
  1. Sep 30, 2020 at 6:15 PM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Front first or rear?
  2. Sep 30, 2020 at 6:18 PM
    EdgeCrusher
    EdgeCrusher Well-Known Member
    Chicagoland
    '16 OR DCSB Fully Loaded
    Put jack on the rear diff and set the two stands on the axle. then jack up the front with your wheels already loosened. pop off the fronts and move to the rear and vise versa.
  3. Sep 30, 2020 at 6:23 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Careful if you're on a slanted driveway and not in 4wd!
  4. Sep 30, 2020 at 6:26 PM
    waltuo
    waltuo Well-Known Member
    Toyotas
    Went to a friends house to throw on my Eibach pro lift. All he had was 2 jack stands for his slammed Evo. 2 in the front and a floor jack on the rear diff. Also on an incline. Pretty hairy but he was the one going under the truck haha.
  5. Sep 30, 2020 at 6:26 PM
    EdgeCrusher
    Chicagoland
    Always chock the tires! But yes I have always done this in the garage where its flat and I only need to get it about 2 inches off the ground.
    Skydvrr[QUOTED] likes this.
  6. Sep 30, 2020 at 6:28 PM
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Learned this the hard way helping a buddy change tires on a Cadillac ext haha. I don't remember what happened but it was mostly unscathed haha.
  7. Sep 30, 2020 at 6:32 PM
    CleanWilly
    CleanWilly Well-Known Member
    2017 Access Cab Offroad
    No reason to be under the truck rotating tires. Expect it to fall in an instant at any time and you're good to go.
    Rick111, Boghog1 and CaptainBart45 like this.
  8. Sep 30, 2020 at 6:50 PM
    scotkw
    scotkw Well-Known Member
    A free State
    '17 DCSB V6 2wd Sr5
    No matter the safety factor you build into your stands, if going to be under a vehicle, I also always stack up 6x6 and 2x4 blocks near the stands or under frame, just in case.
    3ton is fine. You're only lifting half the vehicle. 2000 lbs. So have 4000 lb cushion. If you had to lift whole vehicle, 3 ton is still fine because you'd need four of them.
    3JOH22A likes this.
  9. Sep 30, 2020 at 6:58 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    You'll be fine. 3-ton jackstands used to hold up 1.2 tons or so.
    It's possible, but risky, to rotate tires with just a single hydraulic jack. I did it 3 months ago (look closely: the jack stand isn't touching the rear axle):
  10. Sep 30, 2020 at 7:06 PM
    kairo
    kairo >_>
    Nor Nev
    '20 OR DCLB Quicksand
    I've always jacked up the front, thrown a couple of whatever jack stands under each side, and then put the floor jack under the rear axle and lifted it. Put a block of wood on each side of the back if you happen to be nervous with just the jack, and then rotate the tires. You might be over-thinking this for a tire rotation. Just get the truck off the ground and don't lay under it.
    bax, Tullie D and Professor D like this.
  11. Oct 1, 2020 at 5:55 PM
    kgilly
    kgilly Well-Known Member
    Kurt
    Pennsylvania
    2016 DCSB SR5 4x4
    Bed cover and Mud flaps, OEM Audio, Super Bump stops, Sumo Springs, Bed Stiffeners, Stryker hood shocks
    yes, no issues
  12. Oct 1, 2020 at 7:12 PM
    jerkwithkeyboard
    jerkwithkeyboard Well-Known Member
    Western suburbs Chicago, ILL
    2016 TRD Sport DCSB Inferno 4x4, loaded /JBL/Tonneau Cover/ Roof Rack
    17" Black TRD rims Tacoma Stainless Steel Rear Tailgate Letter Inserts Brake light flasher Center LED 110v and 2-3amp USB plugs mod in back seat center 400w on all the time mod SSR-610-40 SumoSprings 32 INCH 180W CREE LIGHT BAR (5D ) AUXBEAM BedStep and Pop & Lock Power Tailgate Lock Blue LED glove box light (fix no light) Bed light Blue LED's Wired to turn on when Gate is opened Tempered Glass Center Touch Screen Protector Rear Camera anytime Navigation Bypass ( a must) Rexing V1 3rd Generation Dash Cam hard wired in OXILAM 912 921 LED Reverse Light 2000 Lumens TRD Pro Grill TRD Skid plate
    He has a 1.5 ton jack stand people
    You need to assume that at one point you can have all the weight on only (1) stand (possible) 1500 lbs. And remember the truck is heaver in the front.
    SO do it this time but you need a 3 ton rated jack EACH you don't add all the weight together as it is only as strong as the lowest one (math and brain required )..
    don't squish yourself and get better ones for christmas .
    :santa:
  13. Oct 1, 2020 at 7:15 PM
    2008taco
    2008taco Well-Known Member
    chris
    san diego
    no. Anything other than $800 snapon jack stands are unworthy and and untrustworthy of supporting your vehicle.
    TurdTaco64 likes this.
  14. Oct 1, 2020 at 7:18 PM
    jerkwithkeyboard
    2008taco[QUOTED] likes this.
  15. Oct 1, 2020 at 7:19 PM
    #35
    kairo
    kairo >_>
    Nor Nev
    bax and Boghog1 like this.
  16. Oct 1, 2020 at 7:27 PM
    #36
    jerkwithkeyboard
    OR use 2 of these like i do. PITTSBURGH AUTOMOTIVE
    3 Ton Aluminum Rapid Pump® Racing Floor Jack A racing jack that lifts up to 6000 lb. in just 3 pumps
    $179
    shakerhood likes this.
  17. Oct 1, 2020 at 7:28 PM
    #37
    2008taco
    chris
    san diego
  18. Oct 1, 2020 at 7:53 PM
    #38
    jerkwithkeyboard
    To late i already gave it to my neighbor..
    :threadjacked:
  19. Oct 1, 2020 at 8:13 PM
    #39
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    The Owners Manual recommends Front to Back.
    Rick111 likes this.
  20. Oct 1, 2020 at 8:16 PM
    #40
    TurdTaco64
    TurdTaco64 Well-Known Member
    Brandon
    Fort Collins
    2019 Cement TRDOR 6MT
    Just call luke skywalker and have him use the force to support your truck. Yes you will be fine with those stands as nothing that is sold to the public is advertised at it's absolute maximum capacity. Although I'd be curious if those are even tall enough to be useful.
