Jack stand's on asphalt
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Teleholic, Jun 13, 2015.
  1. Jun 14, 2015 at 7:35 AM
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    I've been using the same 3/8" plywood stand supports since 2008 without a single issue. Whether they be on concrete, asphalt, gravel, or even unlevel surface they haven't slipped or cracked.
    Teleholic[OP] likes this.
  2. Jun 14, 2015 at 7:52 AM
    Pigpen
    Dan
    Northwest Montana
    There's some serious drama and over thinking going on here. OP, you're doing it exactly right. 3/4" plywood is more than enough for what you're doing, which makes it perfect. The stands will crunch into the first layer a bit, but don't be worried. There's no way the stands can slip off of the wood once there's some pressure on them.
    Teleholic[OP] and DoorDing like this.
  3. Jun 14, 2015 at 2:35 PM
    dm1215al
    dm1215al Well-Known Member
    Dan
    Fl
    2014 TRD Offroad 4x4
    Step tubes,Window tint, HomelinK rear view mirror, changed the entune image screen Rear Differential Breather Relocation Extended AC condensate hose KB Voodoo tailgate cap Redline Tuning QuickLIFT ELITE hood lift system.
    The wood can save that asphalt if it's a really hot day.
  4. Jun 14, 2015 at 3:32 PM
    Teleholic
    Teleholic [OP] Well-Known Member
    2014 Baja tx
    Yes, there is a bit of overthinking, that's just the way I operate lol. Found out the place is pretty leveled.
    Will be using wheel chocks, one jack up front, one in the rear diff (for extra safety), with four jack stands on plywood, tires underneath frame, put in park, with the hand break; woo I'm out of breath.....
    I will have my jacks welded later when I have time.
  5. Jun 14, 2015 at 3:58 PM
    08TacoTrD
    08TacoTrD Well-Known Member
    08 TRD Offroad
    Just don't sharpen the bases of the jack stands to a razor's edge before you put them on the wood and you'll be fine.
