jack under hitch
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jeremy_283, Jan 15, 2009.
  1. Jan 15, 2009 at 8:54 AM
    jeremy_283
    jeremy_283 [OP] Super Member
    08 TRD Offroad Access Cab 4x4 Auto 4.0L
    Hella Rallye 4000 Cornering Lights PIAA 510 Fog Lights All Pro Front Bumper All Pro Rear Bumper All Pro Transfer Case Skid All Pro IFS Skid All Pro Rock Sliders All Pro High Clearance Hitch OME Dakar Leaf Springs OME Rear Shocks OME Front Shocks OME 885 Front Coils Wet Okole Seat Covers WeatherTech Floor Liners Sony Head Unit JL XD600/1 Amp 2 JL Audio 10” Subwoofers Custom Subwoofer Enclosure Kenwood Front Speakers Sony Rear Speakers Sound Deadening Mats LED Interior Lighting Pop N’ Lock Tailgate Lock Viper Alarm System Extra D-Rings In Truck Bed Maglite Seat Mount Disable Seatbelt Chime Rear Differential Breather Relocation Hi-Lift Bed Mount Flexible Front Mud Flaps 110v Inverter Always At 400w ABS Kill Switch Locking Center Console Removed Sway Bar
    its right there, easy to get to, can i just put my jack under my class 4 hitch to jack up the rear end of my truck to change my shocks? or are there other good points to lift on? actually, i can compress the rear struts by hand, you think i might be able to get away with just changing my rear struts without jacking up my rear end at all?
  2. Jan 15, 2009 at 9:14 AM
    WoadWunner
    WoadWunner Well-Known Member
    Peter
    Bridgetown, Nova Scotia
    17 Accesscab TRD Offroad Inferno
    Tonneau Cover, Devils Horns on the way, Blackened Grill, LED Low beams and Fogs, weathertecs
    Don't use the hitch, it will become a pivot point that will become unbalanced when you remove a wheel or pull on a shock. The smart way is to use the recommended jacking points for changing a tire and put a jack stand under the axle. Then do the same on the other side. That will provide you with a nice stable platform to work on.
  3. Jan 15, 2009 at 9:34 AM
    jeremy_283
    the rear struts dont support anything do they really, so could i just switch em without jackin anything up?
  4. Jan 15, 2009 at 9:48 AM
    moserjjx
    moserjjx Tacoma Newbie
    Eau Claire, WI
    08 DC TRD 4x4
    Weathertech liners, bed mat, rear spring TSB, extra 12V outlets in center console, seat belt chime off
    yep you can do that in the rear although you may have to compress the new ones more to install them. can be done though
  5. Jan 15, 2009 at 9:51 AM
    sonjay
    sonjay Well-Known Member
    It's gonna be a lot easier to get in there with the wheels off. But it would be possible.
  6. Jan 15, 2009 at 10:29 AM
    Delmarva
    Delmarva Mayor of TW
    Tucson, AZ
    2013 4runner Limited Looking for a Taco
    It's the wife's T4R so it's stock
    x2... much easier with the wheel off.
  7. Jan 15, 2009 at 11:01 AM
    sonjay
    You can do one side at a time, just put the wheel under the truck where if the jack fails, the truck can't fall far and falls on the wheel.
  8. Jan 15, 2009 at 11:05 AM
    LonghornTaco
    LonghornTaco Can you pass the bailout please?
    Minnesota
    Black 09 4x4 TRD Off Road Doublecab
    3" ToyTec coilover lift on Bilstein 5100s, Total Chaos UCAs, ToyTec diff drop, Scangauge II, 4D MagLite mounted on the drivers seat, Painted engine cover, Painted calipers (red), Painted skid plate (red) Valentine 1 radar detector hard wired, Damplifier Pro on the floor, back wall and doors, Luxury Liner Pro on the floor and doors, Kenwood DNX8120, 2 Pioneer TS-SW1041D 10" shallow mount subs, 2 Pioneer PRS-D4200F 1200W amps, Mr Marv sub enclosure, Hybrid Audio Clarus 6.5" components in the front doors, Alpine 5.25" coaxials in the rear doors, A.R.E. LSII fiberglass tonneau cover, All Pro bumper, All Pro sliders, Wet Okole seat covers, Sockmonkey Mountain badges, PIAA 510 SMR Driving Lights, Warn M8000 Winch, Bud Built skids
    Why don't you tell us how you REALLY feel?? :D
  9. Jan 15, 2009 at 12:43 PM
    JDCPA
    JDCPA Well-Known Member
    Jim
    SW FL
    09 5 Lug Access Cab SR5
    Curt Hitch and etrailer.com wiring harness.
    What he said. Even with a wheel under the truck it can fall hard enough and fast enough to kill you. Get proper jack stands before EVER getting under a vehicle.
  10. Jan 15, 2009 at 1:58 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Absolutely!
  11. Jan 15, 2009 at 3:55 PM
    AZFizik
    AZFizik Slowpokeologist
    James
    Phoenix
    07 TRD OffRoad Prerunner
    TRD Catback & CAI, Fogs only, Recovered Armrests, BFG AT's
    +100
    Its no fun pulling a corpse out from under a brake drum that has crushed a chest cavity.
  12. Jan 15, 2009 at 3:57 PM
    Delmarva
    Tucson, AZ
    An Air Traffic Controller I used to work with was killed when his car fell on him after he jacked it up and didn't put jackstands under the car...
  13. Jan 15, 2009 at 4:10 PM
    Snipe
    Snipe Well-Known Member
    Pacific NW
    08 TRD Off Road
    Anybody else thinking about crawling under an unsupported truck while balanced on a jack, would you please tape this above where your legs will be sticking out.
    Dear EMT/Fire rescue
    Please take care in removing my corpse because I am willing my truck to my Good Buddy Snipe and he doesn't want it scratched.
    ______________ <---- sign and date it
  14. Jan 15, 2009 at 6:00 PM
    sonjay
    you really don't need to get right under the truck to do the shocks, with the wheel off its all pretty open.
