Jack
Discussion in '2nd Gen. Tacomas (2005-2015)' started by wtrwrkwgn, May 29, 2018.
  1. May 29, 2018 at 7:25 AM
    wtrwrkwgn
    wtrwrkwgn [OP] Member
    Kayaker
    CA
    4cyl 2wd
    There is not enough clearance for the jack if you have a flat tire! Anybody else?
  2. May 29, 2018 at 7:29 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Here's the weather report for this thread - :crapstorm:
  3. May 29, 2018 at 7:35 AM
    Muddinfun
    Muddinfun Well-Known Member
    Where are you trying to put it?
  4. May 29, 2018 at 7:50 AM
    llamasmurf
    llamasmurf Herpa Derp
    Wes
    Northern Ontario
    '15 Matte Black TRD AC
    FJ t-case with twin sticks, UTE bed, some other things :D
    ChadsPride likes this.
  5. May 29, 2018 at 7:52 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    If you carry a small piece of 4x4 and place it between the jack and the frame, it's enough to lift them.
    Are you stuck on the side of the road right now with a flat?
    Alexely999 and llamasmurf like this.
  6. May 29, 2018 at 8:15 AM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Stock jack works fine with a block or two of wood.
  7. May 29, 2018 at 8:19 AM
    Muddinfun
    Pic of OPs truck 2 months ago has little tires on it. Guessing that running out of travel isn't the problem.
    Alexely999 likes this.
  8. May 29, 2018 at 8:19 AM
    Pigpen
    Dan
    Northwest Montana
    :rofl::rofl::rofl::rofl::rofl:
  9. May 29, 2018 at 8:22 AM
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    Maybe he means the jack when fully compressed literally can’t fit underneath his jack point.
    Front or rear? If there’s not enough space the put the jack under the rear u bolt plate you could try under the axle or use the frame rail, if it’s a front flat tire and the jack doesn’t fit under the lower control arm you could maybe try using the frame rail? just try a different location than you’re trying, as long as it can support the weight of the truck.
    SilverBullet19 likes this.
  10. May 29, 2018 at 8:26 AM
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
  11. May 29, 2018 at 8:35 AM
    SilverBullet19
    SilverBullet19 Well-Known Member
    Scott
    Sacramento County
    2015 DCLB Prerunner TRD Sport
    I think he is saying there's not enough room to get the jack in place, not saying its not enough lift?
    Limp the flat wheel onto a couple sheets of plywood, it should provide enough clearance.
  12. May 29, 2018 at 8:35 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Ohhhh, yep, I'm picking up what he's putting down now.
  13. May 29, 2018 at 9:21 AM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
  14. May 29, 2018 at 9:22 AM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    Yeah I'm sure there is random plywood on the side of the highway o_O
  15. May 29, 2018 at 9:24 AM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    o_O:evil:
  16. May 29, 2018 at 9:24 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    :evil:
  17. May 29, 2018 at 9:27 AM
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    nah you still deserve the o_O:evil: for the initial post answering a question that wasn't asked :boink:
  18. May 29, 2018 at 9:29 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  19. May 29, 2018 at 9:56 AM
    llamasmurf
    Wes
    Northern Ontario
    Yea the OP was 100% clear and to the point.
    :facepalm:
  20. May 29, 2018 at 10:00 AM
    MFTAF13
    MFTAF13 "If it ain't broke, fix it till it is"
    Bob
    NorCal
    13 MGM TRD OR
    Lift, sliders, skids & some other stuff.
    Stock jack is a scary POS. One of the first things I replaced after using it to change a flat.
