Jacking from lower control arm
Discussion in 'General Tacoma Talk' started by Mastiff37, Jul 12, 2025 at 10:14 AM.
  1. Jul 12, 2025 at 10:14 AM
    Mastiff37
    Mastiff37 [OP] Well-Known Member
    Tucson, AZ
    2011 Regular Cab 4x4
    Dumb ass maneuver this morning... Doing a tire rotation and decided to jack under the lower control arm up front. I always use stands when I'm getting underneath, but for a rotation sometimes I blow it off. With absolutely no warning (I wasn't even touching the truck) it just slid off. The tire was off on that corner and it came down on the brake disc. There doesn't appear to be any damage (looks fine, drives smooth, brakes fine), but I about jumped out of my skin.
    I see some mixed messages about jacking from the control arm (mostly negative, but not all). I sure will not be doing it that way again. Plus stands all the time just to protect the truck if nothing else.
  2. Jul 12, 2025 at 10:24 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Thankfully you weren’t under the truck and are able to tell us about it. Jack stands are a must. I’ve skipped it when doing a quick peak but your story reinforces why I shouldn’t.
  3. Jul 12, 2025 at 1:38 PM
    Diver_De_Taco
    Diver_De_Taco Well-Known Member
    ‘23 TRD OR
    I rely solely on the jack when jacking up the front during tire rotation. I throw the rear wheels underneath just in case. Wheels are easier to replace.
  4. Jul 12, 2025 at 5:04 PM
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    I'll put the jack on the lower arm support, but never on the arm itself. It's a lot more solid, and allows me to take care of both front tires in one shot
  5. Jul 12, 2025 at 5:30 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Just curious... why not use the front lifting point?
  6. Jul 12, 2025 at 6:59 PM
    soundman98
    NW Indiana
    Which one? I use this one. Inside/between front arms.
    https://www.tacomaworld.com/threads/3rd-gen-jack-points.649345/#post-22554122
    If I'm doing a full tire anything, I normally jack up the rear by the center diff, put jackstands on each side by the shocks, and the bring the jack to the front and use that single point.
    I've done it the other way, with jackstands just inside the front suspension on the chassis pivot point and jacking the rear on the diff, but it's too far inboard for my preference on side to side stability.
    If I'm only working on the front, and need clearance in the middle, I'll use that center bump to lift, then Place jackstands on the chassis pivot point of the lower arms.
    What I don't like about running on the suspension arms is the suspension being loaded. It adds another variable to the situation I can't control.
    And after enough bad stories from others, I've started throwing the wheel/tire assembly underneath the brake rotor/drum unless I'm actually working on the brakes. But then I'm not underneath the vehicle. I would always much prefer to scratch/damage any set of wheels than get pinned and die under the vehicle.
  7. Jul 12, 2025 at 8:54 PM
    OffroadToy
    Yep... that's the one. :thumbsup:
