Jacking Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by vapovick, Aug 25, 2010.
  1. Aug 25, 2010 at 6:55 AM
    vapovick
    vapovick [OP] Active Member
    1999 Toyota Tacoma 4x4
    I know the rear jack points on my Tacoma, but I need to put stands under there and the jack gets in the way, can I jack under the "center" of my jack points? i.e. the hump? if that makes sense?
    thanks
  2. Aug 25, 2010 at 7:18 AM
    Packman73
    Packman73 ^^^^ 3%er ^^^^
    The free state of Arizona
    2007 TRD Off Road
    Bilstein 5100's (front set @ .85"), OME 885's, chris4x4 anti-Taco-lean spacer on driver's side, Total Chaos UCAs, Rear Leaf Spring TSB, Toytec AALs, Black FJ TT Wheels, BFG 285/75R 16 AT Tires, TRD Exhaust, Viper Alarm, Fog Light Mod, De-badged, Blue LED Dome Light, EZ Clamped Tailgate, Wet Okoles, Satoshi Grill, 5% Tint, Engine Tick Fix, Black Rear Bumper, Black Center Valence, Exhaust Cut At Axle, Thanks for all the help chris4x4!
    Are you asking if you can jack under the rear diff? If so, yes you can.
  3. Aug 25, 2010 at 2:33 PM
    vapovick
    Yup that was it. Didnt see a reply so I called the dealer, who advised it was A OK.
    Thanks again.
  4. Aug 25, 2010 at 5:04 PM
    STLharry
    STLharry Lube: It's the key to penetration.
    Harry
    VT
    Yeti Rescue Package with 270k miles
    '95-'97 camouflaged, ARB bull bar, RAT Products skid plate kit, sliders, Green Mountain Customs rear tube bumper and overland bed rack, King coilovers with Icon neoprene covers, defenestrated sway bar, OME Rear Suspension: CS046R leafs + AAL/5125 shocks/NWOR greasable hardware/U-bolt flip kit; S13WL Tundra calipers/pads/rotors, IPF H4 lenses and bulbs, IPF 968 DCG 100W lights, clapped out CB radio, Aussie-spec FJ60 inclinometer, ARB CKMA12 compressor, Superwinch S9000 with 12V Guy clock switch, 4' Hi-Lift, deckplate mod/grey wire mod/dif breather extensions, Duratrac tires, Sockmonkey bedside decals, boat cupholder, Dakine bike pad
    I always put the jack under the dif and the stands under the frame.
  5. Oct 13, 2011 at 1:26 AM
    Stout890
    Stout890 Well-Known Member
    Palmdale ca
    99 prerunner sr5
    Navigation, 10" sub, ome881 on billies 3" all-pro leaf springs with billies, taneau cover, k&n intake,axle swap with a E locker. 31" BFG A/T on premium wheels, hoola girl air freshener and a broadie knob!
    How do you jack up the truck if your going to remove the rear axle? Can you use bricks to elevate jack stands to reach the frame?
