Jacking truck on a slope?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dacon, Sep 3, 2017.
  1. Sep 3, 2017 at 3:13 PM
    Dacon
    Dacon [OP] 2017 Tacoma TRD PRO Quikrete
    Danny
    Gilbert, Arizona.
    2017 TRD PRO DCSB. DOP 02.20.2017
    TRD PRO Cement 2017 TRD CAI and AFE Magnum Flow Dry Air Filter Camburg KINETIK Series Billet UCA Icon LCA skid plates Icon Coilover extended travel shocks with 700# springs Icon 2" rear shocks Icon RXT leaf springs full pack (new rims and tires soon)
    I have life insurance. My wife said DO IT! :facepalm:(joking)
  2. Sep 3, 2017 at 3:16 PM
    Tacomamike mike
    Tacomamike mike Just that, nothing more.
    Michael
    2017 DCLB TRD OFFROAD 4x4
    Working on it, dissent offroad racks, shift sense pro, pedal commander , ARB twin, rigid SS dually's , dual batteries, ARB fridge , 2.5 Fox coil overs wResi , 2.5 Fox rears w resi Total chaos UCA , deaver packs , Nitto trail grappler's 33" .
  3. Sep 4, 2017 at 5:26 PM
    Istan
    Istan Leave it stock they said
    Stan
    Vegas and Yuma
    03 Xtra Cab 5Speed 4*4
    With a lift? If so, just make sure you have a tall jack to hold the rear axel up. I can't remember what that tool is called.
    You could also send out a mod day request in AZ and see if there is anyone with room to help.
  4. Sep 4, 2017 at 5:45 PM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    No way HOA would bitch at you if you were to work on your car in the street, especially if it's for safety. Not worth it to do it in your driveway IMO. The only time I would risk it if it was an emergency and I HAD to be under there to get to safety---otherwise no way.
  5. Sep 4, 2017 at 6:13 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    I'm going to get slammed for this I know, but here goes anyway. It depends on "now much" of a slope you are talking about, what equipment you have, and how safe you are. People get killed all the time under cars on perfectly flat surfaces, so yes it's dangerous under any circumstances. But right tools, not too much of a slope, and don't be an idiot. I've changed axles, engines & transmitions on jacked up vehicles in my old driveway, which was a sloped. Those items are the worst due to the change in weight once removed. Even dropped the axles on a 1ton ~8k vehicle. Chock wheels, (in gear / handbrake) use a trolly jack to lift as the jack will move with the vehicle as you change its angle, set it on decent axle stands, leave jack under vehicle as safety but make sure weight is on stands. NEVER use bottle / scissor / hi-lift jack, only trolly, as the jack needs to move as you raise the vehicle. Then again at home you should only ever use a trolly jack anyway, all other jacks are "emergency use only", unless you have a lift.
  6. Sep 5, 2017 at 3:20 AM
    Skidog1
    Skidog1 Well-Known Member
    Chicagoland
    2016 Black TRD 4x4 Sport DCLB
    I would if I could set the jack and jack stands on a solid level base. I would put something under the truck to keep it from crushing me if it fell. If I can push the truck off the jack stands and still not be hurt I would do it.
  7. Sep 5, 2017 at 3:20 AM
    Skidog1
    Chicagoland
    I'm not saying you should.
