Jacking up a lifted truck
Discussion in 'Suspension' started by Hawaiian05, Aug 28, 2013.
  1. Aug 28, 2013 at 1:27 PM
    Hawaiian05
    Hawaiian05 [OP] Well-Known Member
    Tony
    Boise, ID/ Hawaii
    2021 Army Green TRD OR 6mt/ 2002 4Runner Sport
    I recently installed a 3" Toytec lift on my 1st gen and it hit me that the stock bottle jack may not be sufficient enough. What do all you guys with lifted trucks use or carry if needing to change a tire on the side of the road? Also, what about at home? I had to place the jack stand on a brick plus add a block of wood just to raise the vehicle at home.
    I see that many carry a Hi-Lift jack, but wasn't sure if that was the best/ most common route.
    Any suggestions would be helpful. Thanks!
  2. Aug 28, 2013 at 1:31 PM
    TACO TX
    TACO TX Well-Known Member
    Kelly
    Denison ,Texas
    2017 DC TRD Off Road 4x4(Barcelona red)
    Weather tech liners, Ranch Sierra truck cap
    The jack goes under the A frame in the front and you can put it under the axle housing in the rear. Niether of those heights really change unless running way bigger tires.
  3. Aug 28, 2013 at 2:39 PM
    Hawaiian05
    Tony
    Boise, ID/ Hawaii
    Thanks for the input. I guess I never thought about the dynamics and the fact that the axle remains at/near the same height until bigger tires... So, once bigger tires are installed (either 31's or 33's) will that still work, or will I need another option? What size tires you running and what do you do?
  4. Aug 28, 2013 at 2:48 PM
    PCTaco
    PCTaco 36 hour Build
    Adam
    New Columbia, PA
    '18 Access Cab TRD Offroad RIP '13
    Working on it
    Hi-lift.
    After you replace your front and rear bumper and put on sliders you'll never have to worry about jack points!
  5. Aug 28, 2013 at 3:09 PM
    TACO TX
    Kelly
    Denison ,Texas
    You will just have to try it in the rear, but the front should still work no problem as it doesnt take much since your actually just compressing the suspension. May have to carry a block of wood with you for the rear. I have had 265/75's (32")and didnt have a problem.
