Jacks for a Lifted Taco
Discussion in 'Technical Chat' started by BRP27, Jan 26, 2010.
  1. Jan 26, 2010 at 6:13 PM
    BRP27
    BRP27 [OP] When I grow up I want to be just like Me
    So far south in Texas my feet are in salt water
    04 4X4 Tacoma SR5
    3 in Ultimate ToyTec, set @ 2.5 in. AAL PINCH Weld Mod ( beat the pinch weld over inside the fender) Painted the pinch weld on bottom of cab Black Hi Lift Knock off
    Problem was I had lifted my Taco and had a spare that matched the 33s I had on the truck, but I could not change a flat because the stock jack would not reach the frame. So I bought a Hi Lift jack that I could use on the back with the receiver for the hitch but I could not get the front wheels up because the Hi lift would not reach under to get to the frame, no strong frt bumper to lift from, no sliders.
    Looked at the lift the wheel accessory for the Hi lift, not a fix for me.
    Looked at welding an attachment to the frame to allow the Hi Lift to pick the front wheel up. Didn't like welding to the frame unless I have to.
    So I finally came on the solution. Add 6 in to the stock jack. It still fits in the compartment in the truck and it is a cheap fix untill I can get sliders on the truck.
    So here it is the cheap temp fix
  2. Jan 26, 2010 at 6:16 PM
    s2kvtak
    s2kvtak Well-Known Member
    Lee
    Tulsa, OK
    2004 Tacoma 4x4 SR5
    Grillecraft grill w/ TRD badge, Bilstein 5100s on all 4 corners set at 2.5" and Toytec AAL in the rear. 285/75-17 Interco TRXUS M/T
    idk how sturdy that will be but better than nothing in a pinch i guess
  3. Jan 26, 2010 at 6:17 PM
    JAG
    JAG Well-Known Member
    Scary!!! Use a jack when under it! :eek: Very ingenuitive though.
  4. Jan 26, 2010 at 6:20 PM
    JDMcQ
    JDMcQ Well-Known Member
    The Mushroom Capital of the World
    Umm, couldn't you just put the stock jack under the lower control arm or the rear axle?
  5. Jan 26, 2010 at 6:24 PM
    timbo805
    timbo805 Well-Known Member
    SanDiego
    09 tacoma trd sport pre-runner
    couldt you just stick some pieces of wood betwen the jac and the frame ????
  6. Jan 26, 2010 at 6:39 PM
    bajaracer
    bajaracer Well-Known Member
    Charly
    Chandler
    05 PRERUNNER DBLCAB SPORT 4.0
    AEM DRY BRUTE FORCE, FLOWMASTER 50 SERIES, 285/70/17 BFG'S AT KO2'S MOTO METALS 17X8 885's with 5100's LOUD STEREO
    Im currrently running 33's and had to buy a replacement bottle jack. Went to Wally World and bought a 6ton Black Jack hydrolic bottle jack that fits in the same area as the stock jack. It can easily lift and provide more than enough clearance from more than one lifting spot. The best part is that it only cost $15!!! I dont have to worry about lugging around an extra 50 lbs and having to secure extra.
  7. Jan 27, 2010 at 4:43 AM
    BRP27
    04 4X4 Tacoma SR5
    Never get under a truck with only a jack holding it up!
  8. Jan 27, 2010 at 5:27 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    Be careful. w/that one
  9. Jan 27, 2010 at 5:56 AM
    JAG
    Exactly. Always use a jack stand.
  10. Jan 27, 2010 at 11:10 AM
    BRP27
    04 4X4 Tacoma SR5
    I thougt about using rocks, wood, Dead Cows :))) and such, thats just to easy, got welding to do so welding was the answer. Using a lower point to lift from ment crawling under the truck on the side of the road. Thats not how I roll. To easy:rolleyes:
    I jacked the truck up last night with my ingenius contraption and it works good. Not unstable as long as the wheels are chocked and brake is set. No more unstable than a Hy-Lift :eek::eek: Used the factory lift point where the frame and the cross member cross. Set the jack and raise it from the side of the truck using the linkage supplied with the jack. The idea here is to use this on the side of the road where you don't have all the stuff you have in the garage.
  11. Jan 27, 2010 at 12:28 PM
    indoheat
    indoheat Active Member
    soMD
  12. Jan 27, 2010 at 12:39 PM
    BRP27
    04 4X4 Tacoma SR5
    Please do hyjack this thread:crapstorm:
  13. Jan 27, 2010 at 3:48 PM
    indoheat
    soMD
    not hijacking...thought it was related...my bad if u got offended
  14. Jan 28, 2010 at 4:43 AM
    BRP27
    04 4X4 Tacoma SR5
    You didn't offend me
