Jacks & Stands For Lift Install
Discussion in 'Suspension' started by SManZ, Nov 6, 2009.
  1. Nov 6, 2009 at 4:56 AM
    SManZ
    SManZ [OP] Sold the Taco in June 2020
    Fauquier County, VA
    Current, 2020 Ford Super Duty Tremor, Previously 2010 Supercharged 4x4 Tacoma Sport 6-spd
    TRD Supercharger, King 2.5" extended travel remote-resi coilovers, OME Dakar leaf packs, King 2.5" extended travel rear shocks, Total Chaos UCAs, MBRP turndown exhaust, TRD intake, TRD Quickshifter, Goodridge SS brake lines, EBC Sport Rotors, Hawk HPS pads, TRD FJ Cruiser Special Edition 16" Anthracite Rims, Spidertrax wheel spacers, 265/75R16 A/T, Autometer oil pressure, oil temp gauges, TRD boost gauge, PLX DM-100 OBD II scanner, flexpod mounts, A-pillar gauge pods
    I read some posts about people's difficulties installing lift kits with the rear not being jacked up high enough. I went to Sears yesterday and bought this GM SUV jack that will lift up to 21"
    http://www.sears.com/shc/s/p_10153_12605_010W439904490001P?keyword=jack&sid=K-on-Sx20k061224x0000002
    I also picked up these jack stands that will reach up to 21"
    http://www.sears.com/shc/s/p_10153_12605_00950159000P?keyword=jack+stands
    I have a smaller hydraulic jack that will reach 15" and jackstands that will go up to 17".
    Will the 21" stands be tall enough to hold the truck up at the frame and give me enough room to drop the rear axle for the AAL install? If not, is it SAFE to place a block of wood under the jackstand? And one last question...since I have a second set of jackstands, what would be the best way to set them up as a failsafe? I plan to park the truck with the front tires against a curb as a chock.
    -Thanks!
  2. Nov 6, 2009 at 6:30 AM
    bajamoon
    bajamoon Well-Known Member
    STEVE
    Whittier
    don't know the answer to the height of your jack, i have a 22 lift jack from kragen and it does the job just fine. but don't put wood under the jack stands, you will be working under your truck and you want as stable as you can get it.
  3. Nov 6, 2009 at 7:43 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    I can't remember the size of ours....but the Harbor Freight jack stands are well worth the money. We have two sets. Reach up to 24" and cost only $37 a pair. I'd be careful about purchasing hydraulic jacks from Harbor Freight. We bought a rather light-duty small one and it failed.
    We have a Craftsman hydraulic jack. It's been a work horse for atleast 10 years or more (bigger than the one you have pictured).
  4. Nov 8, 2010 at 8:34 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    Where the best place to put the stands under the truck? Front and rear.
  5. Nov 8, 2010 at 8:37 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    frame and rear axle
  6. Nov 8, 2010 at 8:47 AM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
  7. Nov 8, 2010 at 8:47 AM
    Toyota Truck
    JT
    Texas
    2008 Prerunnner
    Ok cool. The reason I was asking is I am gonna tackle the task of painting my rims today. Thanks for the response.
  8. Nov 8, 2010 at 8:50 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    That's pretty much what I did, except for the 'don't work by yourself' part. As an extra bit of safety I had a 3rd stand set lower and under the side of the axle I was working on just to make sure it didn't drop too low and pull a brake line or something.
  9. Nov 8, 2010 at 8:56 AM
    Toyota Truck
    JT
    Texas
    2008 Prerunnner
    :cool:
