Jacks used on lifted trucks?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by remgu2000, Feb 23, 2018.
  1. Feb 23, 2018 at 3:36 AM
    remgu2000
    remgu2000 [OP] Keepin' on keepin' on.
    Ray
    Roswell, GA
    Used to have a 2017 Barcelona Red TRD Off-Road DCSB 4x4
    I plan on lifting my taco today. What jacks do you all use for roadside flat tire changes? Or do you just use the stock jack propped up on a piece of 4x4?
    Edit: I will probably get 2.25 - 2.5" lift out of my setup.
  2. Feb 23, 2018 at 4:01 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    People will tell you not to do it but that's one reason why you have a High Lift jack.
    JimboAnz likes this.
  3. Feb 23, 2018 at 4:06 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
  4. Feb 23, 2018 at 4:21 AM
    remgu2000
    Ray
    Roswell, GA
    I tend to agree with those people, hi lifts should be a last resort. So I am looking for an alternative strictly for on-road use.
  5. Feb 23, 2018 at 4:30 AM
    Extra Hard Taco
    Extra Hard Taco Well-Known Member
    R.J.
    Devil's Island
    2012 Tacoma TRD OR, 2007 DC (sold), 2003 TRD OR (sold)
    ARB Bumper, SOS sliders, SOS rear bumper, SOS skid plate. OME Lift. Some other stuff.
  6. Feb 23, 2018 at 4:36 AM
    iiitsmikey
    iiitsmikey Well-Known Member
    Sarasota fl
    2017 MGM SR5
    I’m running a 3” lift and used the oem jack on a piece of wood when I got stuck in the mud, but you have to jack it up from the axel for you to be able to lift it high enough. Although it could get a little sketchy getting partially under the truck to jack it up.
    remgu2000[OP] likes this.
  7. Feb 23, 2018 at 4:37 AM
    TRDZILA
    TRDZILA MPS SUX
    Brian “”Keith””
    Kokomo Indiana
    DCSB 12 slightly lifted Tacoma
    Ripped off all four mudflaps. Scratches all down both sides 6112’s up front on 3rd notch 5100’s in back with Toytech 1” block Skids & sliders from SOS Concepts I got rid of the 1” block and put on Wheelers 1 1/2” progressive AAL. SPC UCA. Be sure your standing on the drivers side when reading the instructions! I swapped sides so many times that I can swap UCA’s in 15 minutes. I put in the 3/4” spacer to eliminate the Taco Lean, and just got my 4th alignment. Traded the OEM rims for 17” Sport rims and a bora bora 1” spacer. I got my Firestone 285/70/17 MT2’s. Pelfreybilt gas tank skid and hi-lift jack should be here Friday. Looking at bumpers, but I think they will wait for next year. So far I’m happy with my build. I’ve done it all myself, leading to a lot of cussing and frustration, but it’s all mine.
    Is the plastic baseplate worth the extra $30-$40.00?
  8. Feb 23, 2018 at 4:44 AM
    Doc's Rig
    Doc's Rig Your opinion is not statistically significant
    Doc
    The Natural State
    2016 4x4
    JimboAnz[QUOTED] likes this.
  9. Feb 23, 2018 at 4:47 AM
    swordfish
    swordfish Well-Known Member
    Jon
    CT
    Back ordered
    Hi-Lifts are horrible to use and dangerous if you don't NEED them. If you are not looking for a solution to raise a lifted vehicle that gets a flat in a paved surface or moderate trail, look at https://safejacks.com/ hell of a lot easier to use, store, and safer to boot.
    Granted if you heavily wheel, a Hi-Lift is the way to go for reasons other than lifting the vehicle.
    gunn_runner and remgu2000[OP] like this.
  10. Feb 23, 2018 at 4:47 AM
    Bluegrass Taco
    Bluegrass Taco Politically incorrect low tech redneck
    Bill
    Mt Washington Ky
    2011 DCSB, TRD OR, 5100's, 885's 285/75r16 Cooper STT PROs.
    Nothing wrong with HiLift jacks IF USED PROPERLY. That description applies to millions of tools.
    Must use common sense. Rules out many folks by default
  11. Feb 23, 2018 at 4:48 AM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    Cherry picker.
    Bullnettles and iiitsmikey like this.
  12. Feb 23, 2018 at 4:50 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Fuck hi lifts for anything aside from a recovery. I use the stock jack, and rest it on two 2"x12" pieces of wood. A chunk of 4"x4" between the frame and top of jack will work equally well. For the rear, just jack from under the axle.
    Brie and remgu2000[OP] like this.
  13. Feb 23, 2018 at 4:54 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
  14. Feb 23, 2018 at 4:55 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    theres a guy here on TW that makes the adapters, I got mine from. @adanfon .... :thumbsup:
    Coot83 and Doc's Rig[QUOTED] like this.
  15. Feb 23, 2018 at 4:56 AM
    Darth_Yota
    Darth_Yota I intend to live forever, or die trying.
    Cam-moron
    Somewhere USA
    Dented, broken-down ‘08 hoopty
    Ain’t good’nuff for insta
    A 2x4 or 4x4 block will be fine for on the road tire changes. Take into account bigger tires as well though, that will increase ground clearance too.
    $30-$40 base not needed. Keep some 3/4” ply 1’x1’ for a base.
    Hi lifts are safe if you’re not stupid. And practical outside of your truck bed. It’s a farm jack. I use mine every other day for work. Great fence post puller, great for jacking up heavy objects to get sleepers under. Awesome for positioning heavy equipment. I’d suggest anyone with sliders and good lifting points on their trucks to get one. Indispensable tool.
    Orco59, Bullnettles, EricL and 3 others like this.
  16. Feb 23, 2018 at 4:58 AM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    Rather than a piece of wood (which there is nothing inherently wrong BTW) I carry a 14" X 14" X 1/4" piece of aluminum. Being as thin as it is, it takes up little space.
  17. Feb 23, 2018 at 4:58 AM
    remgu2000
    Ray
    Roswell, GA
    I follow you. The thing is when you're in a rush and get a flat tire on the side of the road and it's raining or snowing you just don't have the same luxury that you do when you're on the trail and you can just chill and do it right.
    I'll get a hi-lift I just want something else for paved roads.
  18. Feb 23, 2018 at 4:59 AM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Sometimes you gotta do what you gotta do
  19. Feb 23, 2018 at 5:00 AM
    Darth_Yota
    Cam-moron
    Somewhere USA
    Hi lifts are faster than any other jack I’ve used.
  20. Feb 23, 2018 at 5:02 AM
    Bluegrass Taco
    Bill
    Mt Washington Ky
    I'm into saving space/saving weight/and not carrying the kitchen sink when I go anywhere. HiLift will do things a bottle jack can't. Only want one or the other due to space/weight limitations.
    JimboAnz and Coot83 like this.
