Jacksonville area Tacos..
Discussion in 'Florida' started by Oh_Six_Taco_4x4, Jan 15, 2009.
  1. Jan 17, 2010 at 6:55 AM
    #1161
    rmb_crew
    rmb_crew My other ride has 18,400HP!!!!!!
    Jacksonville, FL 30.243103, -81.591007‎
    2010 F150 XLT SuperCrew 4X4
    Access larado tonneau, magnaflow exhaust
    I also have an angle grinder is that would work better?
  2. Jan 17, 2010 at 6:58 AM
    #1162
    jaxchrisfla
    jaxchrisfla Well-Known Member
    flooriduh
    lots
    i just need something to trim down the inside of the fiberglas flair, and to roll or beat up the inside lip of the bedsids. i do need to check and see if my blocks are centered, because my alignment shows i have toe in the rear and there should be any with a solid rear axle.
    shes doing good, we are thinkin about bringing her so that she can get out and walk some now that shes doing better.
  3. Jan 17, 2010 at 6:58 AM
    #1163
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    I just tried a 13/16ths. I don't think I would get it to fit without a bfh and then I probably wouldn't be able to get it off.
  4. Jan 17, 2010 at 7:01 AM
    #1164
    Jason'sLawnCare
    good good.
    I just thought if we need jack stands for your truck mine probably won't work because they are highlift and the lowest setting is about a foot. So I hope somebody has lower ones.
  5. Jan 17, 2010 at 7:01 AM
    #1165
    jaxchrisfla
    flooriduh
    lots
    its because our lugnuts have a outer shell on them for looks. the actual acorn style lugnut underneath is a little smaller.
  6. Jan 17, 2010 at 7:02 AM
    #1166
    jaxchrisfla
    flooriduh
    lots
    i actually need taller ones. they would work great.
  7. Jan 17, 2010 at 7:02 AM
    #1167
    rmb_crew
    lol i have high lifts also....
  8. Jan 17, 2010 at 7:03 AM
    #1168
    rmb_crew
    well i am gonna start getting all the stuff together. i will check right before i leave incase i need to get something else.
  9. Jan 17, 2010 at 7:22 AM
    #1169
    Jason'sLawnCare
    What part of the truck are you going to put them under?
  10. Jan 17, 2010 at 7:23 AM
    #1170
    jaxchrisfla
    flooriduh
    lots
    are they actual jackstands? or hi-lift offroad jacks?
  11. Jan 17, 2010 at 7:24 AM
    #1171
    Jason'sLawnCare
    jack stands from sears. I don't have a hilift.
  12. Jan 17, 2010 at 7:26 AM
    #1172
    jaxchrisfla
    flooriduh
    lots
    if i can get a jack under the rear axle and lift it that way, then i put them under the xbrace in the back. that way the axle can still sag like i need it to, but be higher off the ground.
  13. Jan 17, 2010 at 7:27 AM
    #1173
    Jason'sLawnCare
    Oh ok. I see what you want to do.
  14. Jan 17, 2010 at 7:28 AM
    #1174
    jaxchrisfla
    flooriduh
    lots
    to just rotate tires, i just jack it up from the side and the whole side comes up .
  15. Jan 17, 2010 at 8:02 AM
    #1175
    s10nick
    s10nick Well-Known Member
    nick
    Greeley, CO
    base mod. debaged
    3inch hbs lift toytec diff drop grillcraft grill hella 500s conv. to 8k hids xentec hid head light conv. 5% tint more to come
    i have some low jack stands i can bring and i got 2 cans of flat rustolium and 2 cans flat krylon is that enough? and i have some tools in my truck also
  16. Jan 17, 2010 at 8:04 AM
    #1176
    s10nick
    nick
    Greeley, CO
    base mod. debaged
    o and 2 cans of cheap gray primer
  17. Jan 17, 2010 at 9:30 AM
    #1177
    jfrost007
    jfrost007 Well-Known Member
    Lake Charles, LA
    06 Prerunner 4.0
    Magnaflow Exhaust,AFE Pro Dry S, BHLM, Grillcraft grill, hella 500s, Sockmoney black vinyl badges, OME 885s, OME Front and Rear shocks, toytec aal, Built Right UCAs, 255/85r16 BFG KM2s, Powder Coated Valance , Stealth Custom Series Wheels,
    hey jason or ryan could one of you pm me there number just in case i cant find the house..thanks
  18. Jan 17, 2010 at 1:51 PM
    #1178
    jaxchrisfla
    flooriduh
    lots
    I'm obviously not going to be able to make it. Got caught up helping a friend lower his accord.
  19. Jan 17, 2010 at 4:30 PM
    #1179
    jaxchrisfla
    flooriduh
    lots
  20. Jan 17, 2010 at 4:38 PM
    #1180
    haireez
    haireez Member
    jacksonville, fl
    08 4x4 V6 Taco SR5
    Jaxchrisfla your truck is looking good man... and so are the quality of your photos.
