jacobrippey's 1995 V6 Swapped Tacoma single cab build
Discussion in '1st Gen. Builds (1995-2004)' started by jacobrippey, Dec 12, 2016.
  1. Jun 7, 2017 at 6:09 PM
    #241
    COMAtized99
    COMAtized99 Well-Known Member
    North Carolina
    99 DCLB v8
    The Bed is stock...ish
    Op, does your truck have EGR?
  2. Jun 7, 2017 at 8:25 PM
    #242
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    That's correct and you also cannot put a heavy duty truck engine into a light duty truck or car (or vice versa - not that anyone would want to). Also have to keep any and all original emissions equipment... at least no restrictions on displacement
  3. Jun 8, 2017 at 4:05 PM
    #243
    jacobrippey
    jacobrippey [OP] It’s always Taco Tuesday Instagram #rippstik
    Jacob
    Surprise, Arizona. USA
    2004 Tacoma DC 4wd
    Find me on Instagram: @rippstik
    The new engine set up is from a 1996. Body is a 1995.
    TireFire likes this.
  4. Jun 8, 2017 at 4:05 PM
    #244
    jacobrippey
    Jacob
    2004 Tacoma DC 4wd
    Sadly, yes. #notrdheadersforme
  5. Jun 8, 2017 at 4:07 PM
    #245
    TireFire
    Olympic Peninsula
    Can't you just unbolt that and install a resistor to trick your ECU into thinking it's still there?
  6. Jun 8, 2017 at 4:08 PM
    #246
    jacobrippey
    Jacob
    2004 Tacoma DC 4wd
    Yes, but then it probably wouldn't pass emissions.
  7. Jun 8, 2017 at 4:09 PM
    #247
    TireFire
    Olympic Peninsula
    Obviously do it later? How often is smog in CO? Can't be more than here in CA which is every two years?
  8. Jun 8, 2017 at 4:10 PM
    #248
    jacobrippey
    Jacob
    2004 Tacoma DC 4wd
    Every two years. I know that when I go to register it in Colorado (still have AZ plates), I'll need to bring it in and have them inspect the swap to be sure it's kosher. I have some anxiety over it, as it feels like a professor grading a final paper...except this took longer and much more money to do. At least the check engine light went away today (knocks on wood).
  9. Jun 8, 2017 at 4:13 PM
    #249
    TireFire
    Olympic Peninsula
    Yeah, same here! I'd be scared too! I heard they give you chances to correct things Once or twice for no extra charge tho
  10. Jun 8, 2017 at 4:17 PM
    #250
    jacobrippey
    Jacob
    2004 Tacoma DC 4wd
    I hope so. Even then, I literally moved every single piece of emissions equipment over from the 1996 v6 to my truck. I should be fine (famous last words).
  11. Jun 8, 2017 at 4:25 PM
    #251
    COMAtized99
    North Carolina
    99 DCLB v8
    Ok, looks like I'll be running a 4runner ecu then.
    Thanks for replying!
    I love NC. We have emmision, but as long as the engine ecu is happy and not throwing codes or too many monitors incomplete, it's a go.
  12. Jun 8, 2017 at 4:36 PM
    #252
    TireFire
    Olympic Peninsula
    Good luck brother! Do you have a date set for it?
  13. Jun 8, 2017 at 4:53 PM
    #253
    jacobrippey
    Jacob
    2004 Tacoma DC 4wd
    Probably late august, early September.
    I still have some stuff I want to fix before taking it through, mainly, fixing the exhaust leaks.
    TireFire[QUOTED] likes this.
  14. Jun 8, 2017 at 8:41 PM
    #254
    1997tacomav6
    Denver
    Yea emissions tests are stressful.
    Mine has one too, only issue I have had is it got plugged up and needed to be cleaned once around 500,000 miles.
    So no 7th injector unless you deleted the EGR.
    FYI if you got around to supercharging that motor later with a 1997 forward ECU, your emissions levels would be super lower,
    My last emission test done by the state was 6 months ago.
    The teck guys were pretty surprised about how low the emissions where or how clean the truck was running. Said it was right up there as one of the cleanest tests for the day for a vehicle.
    The teck guy said most superchargered engines run very low emissions.
    This was new news to me at the time
  15. Jun 8, 2017 at 9:17 PM
    #255
    jacobrippey
    Jacob
    2004 Tacoma DC 4wd
    Because I was interested, I looked into how different the ecu pinning would be, to simply swap ecu's. Answer: I can't, without rewiring the entire truck. Lame!
  16. Jun 8, 2017 at 9:26 PM
    #256
    1997tacomav6
    Denver
    Mmm, wound not think it would be to hard but I have not looked into that. There is a guy in Loveland
    that does this type work out of house in his garage , he did my engine swap when my old engine blew
    a gasket if you get to that point It can be done, the son does the electrical stuff
    like swapping ECU
  17. Jun 8, 2017 at 9:39 PM
    #257
    jacobrippey
    Jacob
    2004 Tacoma DC 4wd
    In theory, all id need to do is go to yoda Jims and get a newer ecu and corresponding harness (interior/engine), tear out the interior, and swap the engine and interior harnesses. Or...I could go the piggyback ecu route.
    1997tacomav6[QUOTED] likes this.
  18. Jun 9, 2017 at 6:21 PM
    #258
    1997tacomav6
    Denver
    You can get one of these to fine tune your emissions if your worried,
    https://m.youtube.com/watch?v=WzAQajstFRk
  19. Jun 11, 2017 at 5:23 PM
    #259
    COMAtized99
    North Carolina
    99 DCLB v8
    Hey, OP, what did you do about the fuel filter? The 4cyl has them mounted on the block, and the v6 under the cab.
  20. Jun 11, 2017 at 5:32 PM
    #260
    jacobrippey
    Jacob
    2004 Tacoma DC 4wd
    Swapped the fuel lines for one with an in-line filter. Goes right in.
    COMAtized99[QUOTED] likes this.
