Jake brake feeling
Discussion in '4 Cylinder' started by jpneely, Jan 9, 2012.
  1. Jan 9, 2012 at 7:59 PM
    jpneely
    jpneely [OP] Well-Known Member
    Charleston, SC
    2011 PreRunner SR5
    very, very stock.
    ok so this has been happening since day 1 and naturally the dealer doesnt have anything to add/help. mainly i was just wondering if anyone else has the same "occurence" as mine.
    ok so i have a 2011 4X2 4cyl access cab.
    it happens in the morning, it doesnt matter whether its cold or not outside just before the truck warms up. as the truck decellerates and the rpms drop from 1100-800, the truck does a "shudder" deal. the only thing i can compare it to is the feel of the engine braking or if you roll over a small rumble strip on the side of the road.
    again its not really bothering anything im just curious if anyone else has experienced this or if im unique
  2. Jan 9, 2012 at 8:33 PM
    jpneely
    Charleston, SC
    2011 PreRunner SR5
    very, very stock.
    bumpppppp
  3. Jan 9, 2012 at 8:35 PM
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    2015 Tacoma TRD OR & 1985 SR5 4Runner
    is it more of a "feel" or a sound? i have had something similar (i think) happen to me too
  4. Jan 9, 2012 at 8:38 PM
    jpneely
    Charleston, SC
    2011 PreRunner SR5
    very, very stock.
    its a feeling. but it happens just about every time after its been sitting for over 6-7 hours (night) and before the temp gauge gets above the C (cold)
    but also this may just be a 4 cyl thing. ive never driven a 4 cyl before this truck
  5. Jan 9, 2012 at 8:40 PM
    tacoman15
    tacoman15 Boobies
    Northeast Georgia
    sorry man don't think i can help ya out. good luck
  6. Jan 9, 2012 at 8:54 PM
    jpneely
    Charleston, SC
    2011 PreRunner SR5
    very, very stock.
    that sounds great and all and it makes sense but are you talking about like if you have a stick shift and you downshift to to slow down and the rpms jump UP to slow you down?
    the reason i ask is that it feels almost like the opposite. almost as if your trying to start out in 2nd or third. but the (automatic) truck is decelerating...
    still not sure if im explaining this in an effective way or not...
  7. Jan 9, 2012 at 9:07 PM
    AndrewFalk
    AndrewFalk Science!
    The North East
    2010 5 speed 5 lug
    It might just be the way the transmission downshifts at that speed. I drive a 5 speed so I can't say I've experience exactly what you're describing though.
  8. Jan 9, 2012 at 9:20 PM
    joes06tacoma
    Joe
    Central Coast, CA
    I had a Dakota that would do that only when cold. It was a sticking Idle Air Control valve. The Tacoma doesn't have that, but I suppose you could have a sticking electronic throttle body.
    I have a four cylinder Tacoma at work, but it's a 5 speed.
  9. Jan 9, 2012 at 10:05 PM
    johnanm
    johnanm Well-Known Member
    Up
    2011 Double Cab 2.7L Prerunner
    Bilstein 5100 @ 1.75" front shocks on stock springs, AFE ProDry drop-in, white DTRLs, Sylvania ZXE headlamps, DeeZee bed mat, Tailgate hose clamp mod, cheap snap craigslist tonneau, Weathertech vent visors, secondary air filter removed, Class III hitch
    It the feeling just for a split second and usually around 15-20 mph? I have felt almost the exact same thing you have, complete with the very muffled rumble strip sound.
  10. Jan 9, 2012 at 10:06 PM
    jpneely
    Charleston, SC
    2011 PreRunner SR5
    very, very stock.
    WOOO im not alone!
  11. Jan 10, 2012 at 1:12 AM
    johnanm
    Up
    I feel the same way brother, it's not going to bother me at all now that I know my truck is normal :)
  12. Jan 16, 2012 at 7:15 PM
    tacomalex
    tacomalex Well-Known Member
    Alex
    WV
    '11 SR5 2.7l 4x4
    plasti dip engine
    my tacoma, 11' I4 5spd, does get a shudder sometimes when I first start, and sometimes when I stop at a red light or stop sign right after I come to a complete stop..
  13. Jan 16, 2012 at 9:48 PM
    ffbartlett
    ffbartlett Well-Known Member
    southern california
    2011 Reg Cab 4x4
    tint, bfg's, 5100's, tunnel cover.
    haha funny that you posted this. mine does the same thing in the morning if i have to stop at the first light. once i get down to about 15 mph it does a quick shudder as I'm slowing and doesn't do it again until the next morning.
  14. Jan 17, 2012 at 9:48 AM
    jpneely
    Charleston, SC
    2011 PreRunner SR5
    very, very stock.
    yup thats it! just once a day. at that first stop sign.
  15. Jan 20, 2012 at 7:15 AM
    DGXR
    DGXR Well-Known Member
    Friend
    Sacramento, CA
    2006 2.7L SR5 2-wheel drive
    aFe Pro Dry air filter, magnetic oil drain plug, synthetic seat covers, steering wheel cover
    Yup me too, once per day, usually just before my first complete stop. It kind of feels like the fuel cutoff engine braking feature, only much stronger and at much lower RPM.
  16. Jan 20, 2012 at 2:17 PM
    Richardsquid
    Richardsquid New Member
    Richard
    New Hampshire
    Reg cab 4x4 4cyl auto
    I have the same thing, my dealer said that since the vehicle is cold, it is still enriching the fuel into the engine. If you were in neutral it would be idling higher than it does once it is warm. As you slow down to stop, the extra fuel keeps trying to keep the idle a little higher so it is sort of like if you had a manual transmission and tried to give it gas in too high a gear, it is basically lugging for a second before the automatic drops out of gear. They said it is more noticeable on newer trucks because the automatic stays engaged longer as you slow down to help emissions. But once it is warmed up there is less fuel so you don't feel it then.
  17. Jan 20, 2012 at 2:54 PM
    DGXR
    Friend
    Sacramento, CA
    That makes total sense to me... thanks for the education, and to your dealer/tech as well.
  18. Jan 20, 2012 at 7:08 PM
    jpneely
    Charleston, SC
    2011 PreRunner SR5
    very, very stock.
    that does make total sense! now i have an explanation finally! im glad someones tech is smart in the way of how engines/trucks work...
  19. Dec 8, 2012 at 5:58 PM
    Canufixit
    Canufixit Well-Known Member
    People ask me "CANUFIXIT"!
    New England
    Black Taco '12 4x4
    Delay wiper mod. "Access" Tonneau cover. BedMat.
    Mine does the same .... mine is a 2012 base, 4L 4X4 Auto ~4K miles. The Solution /reason stated makes sense. one other possible issue that "might" be a cause (although I do not believe it is so in this case) .... a Bad/leaky vacuum booster on the power brake could steal enough vacuum to cause the rough engine vibs .... leaks when cold and you step on the brake ...
  20. Dec 10, 2012 at 6:10 AM
    BamaToy1997
    BamaToy1997 ASE Master Tech
    Bill
    Navarre, FL
    Multi-point tow hooks, new bored 2.7L engine, custom paint. 3 inch adjustable Fabtech front coils, 2.5 inch rear AAL. Front Aussie locker. LED bed lights. Full LED conversion interior and exterior. Relentless Fabrication front and rear bumpers. 4X4innovation sliders. BAMF bed rack. CVT rooftop tent.
    Just to correct some misinformation here, the computer can and does sometimes prevent shifting into the higher gear when it is cold, but it does this to help warm up the transmission fluid, not to help warm up the engine.
