Jan 27th Hollister aftermath!
Discussion in 'Northern California' started by 4x4Runner, Jan 27, 2013.
  1. Jan 28, 2013 at 9:20 AM
    #61
    OverRated
    OverRated Well-Known Member
    David
    San Jose, CA
    12 Tacoma / TRD-OR / DCSB
    It's all good I had fun :D
  2. Jan 28, 2013 at 9:45 AM
    #62
    Jbcm12
    Jbcm12 Well-Known Member
    Joshua
    Bay Area
    Them wheels look clean tho
  3. Jan 28, 2013 at 9:53 AM
    #63
    Baoser
    Baoser Well-Known Member
    George
    Pittsburg, CA
    2012 DCSB Offroad
    Thanks, and thanks for giving me a ride :D
  4. Jan 28, 2013 at 10:39 AM
    #64
    whiteboy
    whiteboy Well-Known Member
    Cody
    Glendale, AZ
    '06 TRD sport
    Kings, alcans, 33's blah blah read my build thread in sig
    What are you talking about! We flew through that place hahaha.
  5. Jan 28, 2013 at 12:12 PM
    #65
    MJonaGS32
    MJonaGS32 MJ on a GS
    MJ
    SF Bay Area (East)
    07 LT 4x4 DCSB 6spd Vagabond
    Drifter wedge camper, Dual battery, OBA, ARB locker, 4.56 gears
    Hey Jeremy - Did you end up picking the parts up at O'reilly? Did you fix it yet?
  6. Jan 28, 2013 at 12:16 PM
    #66
    ian408
    ian408 Well-Known Member
    Ian
    Santa Clara, CA
    09 Tacoma
    Did you need any help?
  7. Jan 28, 2013 at 12:24 PM
    #67
    MJonaGS32
    MJ
    SF Bay Area (East)
    Yeah I'd like to learn exactly how to do this. Maybe even carry some spare parts and fix it on the trail if it ever happened to me
  8. Jan 28, 2013 at 12:24 PM
    #68
    audi0phile
    audi0phile Active Member
    Karl
    SF Bay Area
    06 Acs 6spd
    You know, I've been thinking about it, but maybe one reason why you and Jeremy were getting hung up trying climb up Fremontina was due to the electronic "aids" on your guys Tacos? I know at some point you either engaged something (ATRAC?) or disengaged something, but I seem to recall that if you don't turn off VSC you can run into issues with throttle control as you try to ascend obstacles due to lack of traction and the computer overriding manual input. Just some thoughts, it was super fun though!
  9. Jan 28, 2013 at 12:42 PM
    #69
    sytfu510
    sytfu510 Instagram: tacoma510
    Alex
    Bay Area
    06 DBL Cab Long Bed TRD Sport
    Dirt Designs LT kit front and 3 link kit rear SCS Wheels BAMF rack, bumper ,sliders
    Jeremy's truck is a TRD Sport, no locker, no A-trac, etc. Just 4wd Open/Open. I also would like to learn how to fix/repair the u-joint so should it happen we can fix.
  10. Jan 28, 2013 at 12:49 PM
    #70
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    The upper half of Fremontia trail is quite difficult.
    Jerry and Bruce are the only guy's I've seen drive it successfully.
    I've watched an experienced driver in a capable but open/open tacoma get cross axled and have to give up after repeated attempts.
    Now that my truck's locked front and rear, I've been wanting to give it a go - but couldn't make this trip due to schedule.
  11. Jan 28, 2013 at 12:51 PM
    #71
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    U Bolt reversal. :eek:
  12. Jan 28, 2013 at 12:57 PM
    #72
    MJonaGS32
    MJ
    SF Bay Area (East)
    Alex, John, and Vin were among the few that got up Fremontia. I should have gone back and at least tried it :(
  13. Jan 28, 2013 at 1:13 PM
    #73
    bjmoose
    San Jose CA
    '11 Std Cab 4x4 5sp
    Yeah - I wasn't there but I know the spot and I saw the pix.
    I think your suggested approach of one truck with winch, the other as anchor, and a snatch block on the front of the truck being raised sounds like a good approach to try - up to a certain point.
    I think it'll stop working and the trucks will start being pulled towards each other once the angle at the snatch block gets wider (bigger) than about 90 degrees.
    EDIT - the closer the trucks can be to each other - the better the angle will be. But the more the winch will be pulling sideways against the fairlead, increasing friction.
    Another idea:
    I also carry a "pull pal" which could possibly be set on the uphill side of McCray or (maybe? on the bank above it maybe??) and set up with a snatch block to be used as a turning block. Not absolutely positive though, as that mountain side is pretty rocky. Wouldn't know if we'd actually be able to set it there without actually trying it. Until then, this idea is pure "web wheeling." ;-)
  14. Jan 28, 2013 at 2:16 PM
    #74
    ian408
    Ian
    Santa Clara, CA
    09 Tacoma
    The snatch block would be on a tug strap attached to the downhill vehicle. In an ideal situation, you'd secure the block to a tree or some other solid point (there are quite a few winch points throughout HH). Just not there :)
    I looked at the PP video. Looks like you need a lot of room for that. McCray isn't wide enough and I'm not sure how high you'd want to put that (above the load and keeping in mind that 'above' is relative to the angle of the load). For the PP to work correctly, it looks like the frame and the shovel need to contact the ground during the pull--if the frame is too high, it looks like it will plow. Too low and it might not dig correctly. Looks like a great alternative to a solid anchor point too.
  15. Jan 28, 2013 at 5:18 PM
    #75
    DangerTaco
    DangerTaco The older the bear, the sweeter the juice
    Max
    Peninsula and the Delta
    '03 Tacoma TRD
    OME shocks/springs, Dakar leafs, Brembo Blanks, Hawk LTS pads, FJ steelies
    Jeremy, did you get that tiny rock off your tire?
    That bastard still bugs me.
  16. Jan 28, 2013 at 5:33 PM
    #76
    OverRated
    David
    San Jose, CA
    I think that was Karl (audi0phile)
  17. Jan 28, 2013 at 5:35 PM
    #77
    Baoser
    George
    Pittsburg, CA
    2012 DCSB Offroad
    Cody again...haha Jeremy had the broken white DCLB
  18. Jan 28, 2013 at 6:00 PM
    #78
    DangerTaco
    Max
    '03 Tacoma TRD
    My bad, im terrible with names, ill just refer to him as "whats his face"
  19. Jan 28, 2013 at 6:07 PM
    #79
    sytfu510
    Alex
    Bay Area
    a sick photo thanks to George!
  20. Jan 28, 2013 at 6:11 PM
    #80
    SportyHeretic
    SportyHeretic Well-Known Member
    Jeremy
    Wyoming/South Carolina
    2010 Sport
    Icon Stage 3 Suspension, Diff Drop, MagnaFlow Cat-Back Exhaust, Tonneau Cover
