japjoe7 audio build thread
Discussion in 'Audio & Video' started by japjoe7, Apr 8, 2022.
  1. Jun 14, 2022 at 7:22 AM
    #81
    japjoe7
    japjoe7 [OP] Well-Known Member
    Joey
    Pike County, PA
    21 Barcelona Red Sport DC AT
    Glad you asked! I just have a hole drilled through the sail panels right now and they are attached on the outside with hot glue. I will eventually created 3d printed rings and bond them to the sails. They will not be flush but will be at an angle half way through the panel. Similar to how Mark from CAF made his.
    Edit: Don't mind all the pollen all over my truck, had the windows open all day lol.
    For the firewall and grommet I used a step bit to drill a hole though the firewall and then put on a PG21 cable gland. In the spot I used I needed to cut a flap in the carpet for the cable to come thrugh.
    MGMDesertTaco[QUOTED] likes this.
  2. Jun 14, 2022 at 8:13 AM
    #82
    japjoe7
    Joey
    Pike County, PA
    Got the amp fired up. I have some static hiss coming from all speakers. Thought it might be the RCA's or the head unit but after unplugging the RCA's from the amp the hiss is still present. I swapped the ground to a cable with no dis. block and to another seat bolt but still getting the hiss. The speaker wires may look like they are sitting on the power cable but they are not, they are a good inch away from it. I'm thinking it's the the amp gains but I have to work on that. Started messing with the DSP settings and it's complicated. Just going to take some time to run all the mic tests.
    soundman98 and MGMDesertTaco like this.
  3. Jun 15, 2022 at 5:58 PM
    #83
    81malibu81
    81malibu81 Well-Known Member
    '21 TRD OR DCSB 6MT S/C
    Glad to see you're still plugging along. I'm assuming you ran your RCA inputs away from your power wire and sanded the paint at grounding points?
    Side note: Are you using a RTA? If so which one did you go with?
    I am finally going back together with my interior so tuning is just around the corner. Figured I'd try the autotune and go from there but my buddy who just installed this said it will need a mic to do this. I already know this ends with me paying Nick for a remote tune but trying to be optimistic here.
  4. Jun 16, 2022 at 6:13 AM
    #84
    japjoe7
    Joey
    Pike County, PA
    Yes, I have my RCA's running on the right side of the center console and my power wire is run down the left side doors, so they are not close together at all. Yes, even sanded down area where I have the ground attached. Ground wire is about 17" long. Next I'm going to run a ground to the battery directly and see what that does.
    I have a miniDSP UMIK-1 mic that I'm going to use with REW. Also, I'm using the Helix DSP PC-Tool software to configure ATM, ISA, RTA, and auto tune. Been playing with it a little and I'm slowly getting use to it. It's still very complicated and cumbersome, not for beginners for sure.
    soundman98 likes this.
  5. Jun 22, 2022 at 1:58 AM
    #85
    lacab100
    lacab100 Well-Known Member
    Caleb
    '20 TRD OR M/T, Maggy S/C
    Ive had the same static/noise floor issues with an Audio Control D-6.1200, mitigated with gain adjustment but still present. Audio Control even replaced the amp under warranty (bought on Amazon im surprised they did)
    I figured it was just the AC amp...glad i didn't waste money changing it!
    I even ran 0 AWG positive and negative almost direct to the battery, didn't seem to help much. ymmv
    When i was T/S for the warranty i even ran the amp from a completely isolated spare battery, not a power/ground loop issue
    Nice back wall amp board setup!
  6. Jun 22, 2022 at 10:02 AM
    #86
    japjoe7
    Joey
    Pike County, PA
    Nice to know, thanks for the info. I ran a ground directly to my battery and it did the same. Never had this issue with past D amps.
  7. Jun 28, 2022 at 10:30 AM
    #87
    japjoe7
    Joey
    Pike County, PA
    Been playing with the DSP the past week. Once I got use to it it's not so bad but a steep learning curve, definitely not for a beginner. Also, been modelling a box that has the exact measurement I need to meet the volume requirement for the 10TW3. I used what I got from MrMarv and tweaked it a bit. Sorry, will not be providing measurements as I don't think that would be fair with the amount of time I've put into doing this and what MrMarv has helped with.
    NavyDiver72 and MGMDesertTaco like this.
  8. Jun 28, 2022 at 7:31 PM
    #88
    81malibu81
    I finally have the two Helix amps up and running. My grounds are nothing crazy just 12" 4 gauge attached to the humps under the front of the seats (each has there own/ no distro). These amps have little to no noise at all from what I can tell (yet) but I am using an optical connection to an android h/u. Makes me wonder if it may have something to do with your h/u or your rca's sense those are the 'x' factors. The m six dsp gets very hot, the m one x is barely warm.
  9. Jun 29, 2022 at 7:18 AM
    #89
    japjoe7
    Joey
    Pike County, PA
    I have a Topping D10s coming soon that I will use optical with the Helix, I'll see how it sounds with that. I did notice when I was adjusting the input gain on the DSP that the noise would change so I have a feeling that has something to do with it. I have it set to RCA @ 4.0Vrms. If I go any lower than that the static gets louder. I'm taking off these caps on my tweeters too, the pops are annoying me. Mine runs warm as well. The other day when it was in the 90s outside it was so hot I couldn't keep my hand on it, didn't shut off though so it couldn't have been too warm to run.
  10. Jul 1, 2022 at 9:37 PM
    #90
    soundman98
    soundman98 Well-Known Member
    NW Indiana
    '18 Taco Sport, '14 Ranger
    Not too much leeway with boxes in these trucks anyways!
    Is the top just above the child restraint tie downs?
    The step-in near the top for the cross member looks almost double what it needs to be
  11. Jul 2, 2022 at 8:03 AM
    #91
    japjoe7
    Joey
    Pike County, PA
    Took the child restraints off but it’s to clear the window motor. Starting the box in an hour so I’ll be double checking fitment as I go.
    soundman98[QUOTED] likes this.
  12. Jul 2, 2022 at 3:26 PM
    #92
    japjoe7
    Joey
    Pike County, PA
    welp, @soundman98 you were right. I made that step too wide. I end up moving it out 3/4” so it will fit the sub.
    MGMDesertTaco likes this.
  13. Jul 2, 2022 at 7:59 PM
    #93
    soundman98
    NW Indiana
    that looks better ;)
    oh, and fyi; the factory threaded holes underneath the crossmember re-thread to 1/4-20 really nice(with enough meat yet for the oem bolts to catch as well) for a clean spot to bolt the box to
    japjoe7[OP] likes this.
  14. Jul 2, 2022 at 9:46 PM
    #94
    japjoe7
    Joey
    Pike County, PA
    Nice! I’ll look for them.
  15. Jul 3, 2022 at 8:50 AM
    #95
    soundman98
    NW Indiana
    it's a typical metric thread from the oem, but i had 2" 1/4-20's and washers on hand, where i didn't have the metric hardware.
    as far as sealing the bolt, i found something similar to this at my local hardware store in the plumbing/hvac section. works really well, i just stick some on the wall and run the bolt through it, with another layer on top of the bolt. works way better/re-usable than globbing silicone over the top of the installed bolt!
    https://www.armacell.us/products/armaflexinsulationtape/
  16. Jul 3, 2022 at 8:59 AM
    #96
    japjoe7
    Joey
    Pike County, PA
    Awesome thanks, def. doing this!
  17. Jul 6, 2022 at 4:19 PM
    #97
    japjoe7
    Joey
    Pike County, PA
    Got a new toy delivered today. JL 10TW-D4 will be wired in 2ohm.
  18. Jul 11, 2022 at 7:08 AM
    #98
    japjoe7
    Joey
    Pike County, PA
    Got a little more done on the box yesterday. Routed the edges of the side pieces for the carpet to sit in cleanly. Glues and nailed the sides on.
    Circle jig and post came in so now I can cut of the circle and add the post. Also got the threaded inserts and stainless hex bolts(10-24).
    MGMDesertTaco and SuperAir like this.
  19. Jul 13, 2022 at 7:30 AM
    #99
    japjoe7
    Joey
    Pike County, PA
  20. Jul 13, 2022 at 5:36 PM
    #100
    soundman98
    NW Indiana
    Just watch those binding posts. I think I got a cheaper version through a prebuilt box deal, but the 'banana plug' connections were drilled all the way through, representing a major box leak!
