JayMac's Booze, Bullets, BS, & Bacon Thread. Now with Build!
Discussion in '2nd Gen. Builds (2005-2015)' started by JayMac, Jun 4, 2017.
  1. Jun 5, 2017 at 1:32 PM
    #261
    ChadsPride
    Sponsored by TacomaWorld.com
    Pumped af for you!!! :benchpress:
    vrod671[QUOTED] likes this.
  2. Jun 5, 2017 at 1:33 PM
    #262
    JayMac
    JayMac [OP] I'm not bad... I'm just drawn that way.
    Jessica
    Oregon
    2007 DCLBFTMFW
    YES! Today is my final day of work for 2 weeks. Then I'm on for 3 days and then in Bend for 4 days!! It's gettin' real!!
    I haven't washed it since February.
  3. Jun 5, 2017 at 1:33 PM
    #263
    vrod671
    vrod671 The Okayest Member
    Brandon
    2022 TRD Sport 4x4
    Stock
    :fistbump:
    How was Cabo? You drink enough Pacifico, Tecate, and Modelos?
    ChadsPride[QUOTED] likes this.
  4. Jun 5, 2017 at 1:35 PM
    #264
    vrod671
    Brandon
    2022 TRD Sport 4x4
    Stock
    :bananadance::dancingbacon::broccoli::jellydance::kona:
    :rockband:
  5. Jun 5, 2017 at 1:35 PM
    #265
    ChadsPride
    Had about 10p Margarita, maybe 50 Pina coladas, and about 100 Pacifico on ice lol.
    Throw in about 25 tequila shots late late night....I'm hurting
  6. Jun 5, 2017 at 1:35 PM
    #266
    Benzdriver81
    Benzdriver81 Making it fool-proof will just make a better fool
    Kevin
    PNW
    05 DCLB Sport
    FIFY :devil:
    MarX, ChadsPride and JayMac[OP] like this.
  7. Jun 5, 2017 at 1:39 PM
    #267
    Benzdriver81
    Kevin
    PNW
    05 DCLB Sport
    x100000000000000000000000000000000000
    Also, #bumpfire
  8. Jun 5, 2017 at 2:15 PM
    #268
    vrod671
    Brandon
    2022 TRD Sport 4x4
    Stock
    I hear you!
    I killed a bottle of tequila and did my best to help kill the 15 cases of beer we bought. Every place had bomb margaritas and pina coladas. Would definitely go back!
  9. Jun 5, 2017 at 2:18 PM
    #269
    ChadsPride
    So legit!!! :eek::eek::eek: :cheers:
  10. Jun 5, 2017 at 2:21 PM
    #270
    ThomasMore66
    Dallas/Fort Worth & Durango
    OMG! This thread is still operational.
    JayMac[OP], MarX and ChadsPride like this.
  11. Jun 5, 2017 at 2:37 PM
    #271
    Pigpen
    Dan
    Northwest Montana
    I was cleaning my dash on my lunch break today. Realized I should have taken a before pic for ya. Soooo much pollen and dust! Should have tagged you on it again.
  12. Jun 5, 2017 at 2:58 PM
    #272
    ChadsPride
    Haha!!!
    JayMac[OP], Pigpen[QUOTED] and MarX like this.
  13. Jun 5, 2017 at 4:16 PM
    #273
    MarX
    MarX Hotdogs, spam and skittles.
    Mark
    NE Kansas
    2013 DCLB Tacoma TRD sorta Sport 4X4, 2009 Tundra SR5 workhorse
    RETRAX bed cover, Tailgate lock, TRD exhaust. 887's, LR UCA'S, Bilstein 5100's and Deavers AAL.
    See this thread went viral in half a sec lol
    txtaco87, JayMac[OP] and ChadsPride like this.
  14. Jun 5, 2017 at 5:06 PM
    #274
    beertimecontinuum
    beertimecontinuum What's outside the simulation?
    Everett
    Ky,Earth,SolarSystem,MilkyWay,VirgoSupercluster
    10 Pyrite DCSB VEEEEEE 1.618
    FoxShox, Dirt King Heims, Chevy63s, 2UZ-FE V8 Flowmaster 40, Demello Front/DYF Rear w/Swigouts, BAMF sliders, DYFAF
  15. Jun 5, 2017 at 5:19 PM
    #275
    T4RFTMFW
    T4RFTMFW Well-Known Member
  16. Jun 5, 2017 at 6:07 PM
    #276
    JayMac
    Jessica
    Oregon
    2007 DCLBFTMFW
    Uh. Duh. Did you doubt it?
    I can't even think about what my dash looks like... that's the only part of the interior that I don't totally keep clean... usually.
    My soul sister has arrived. :cool:
  17. Jun 5, 2017 at 6:13 PM
    #277
    T4RFTMFW
  18. Jun 5, 2017 at 6:14 PM
    #278
    Pigpen
    Dan
    Northwest Montana
    It was at least this bad
  19. Jun 5, 2017 at 6:16 PM
    #279
    ThomasMore66
    Chaos. This thread is perfect for a Trump administration. Can we say that? What if we say it's safe for third gens here?
  20. Jun 5, 2017 at 6:36 PM
    #280
    JayMac
    Jessica
    Oregon
    2007 DCLBFTMFW
    But is it? IS IT SAFE HERE??
    ChadsPride likes this.
