JB Weld
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ThePanda, Jan 22, 2022.
  1. Jan 23, 2022 at 6:20 PM
    crazysccrmd
    crazysccrmd Well-Known Member
    Alaska
    Aprilia Tuareg 660
    https://www.lowes.com/pd/Hillman-2-Pack-3-7-in-White-Plastic-Hole-Plug/3013242
    https://www.lowes.com/pd/Phifer-3-ft-x-7-ft-Silver-Aluminum-Replacement-Screen/5001638553
    https://www.loctiteproducts.com/en/products/build/epoxies/loctite_epoxy_weldbondingcompound.html
    Get an appropriate size plug, smear a bead of epoxy around it and stuff it in the hole. Cut a piece of metal screen, put it overlapping the plug and tank and smear all of it with epoxy. Should get you by for a while until you find a new tank.
  2. Jan 23, 2022 at 6:23 PM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Probably the best method, though I believe OP has a plastic gas tank so he'd need a version of this for plastics.
  3. Jan 23, 2022 at 6:30 PM
    INSAYN
    INSAYN Well-Known Member
    PNWet, Oregon
    '17 TRD OR DCSB 6MT 4x4...'97 Taco XtraCab 5MT 4x4
    DIY Fabricobbler.
    G-Flex?
  4. May 16, 2022 at 9:09 AM
    ThePanda
    ThePanda [OP] Well-Known Member
    Kaelan
    Colorado
    6-Speed Manual 2010 Magnetic Grey Tacoma SR5
    Procomp 6" Lift ARB Front Bumper Brute Force Fab's High Clearance Swing Arm Rear Bumper Relentless Fabs Bed Rack Gen 2.5 Face-Lifted Exterior and Interior (mostly) -Fleabay Headlights -Heritage Grille -Scooped Hood Alpha Rex 3rd Gen Pro-Series Taillights Joying 10.5" Android head unit URD Short Throw Shifter Advanced Fiberglass Front and 3rd Gen Rear Fenders 3rd Gen Tailgate RSG Metal-Works Sliders ARB Simpson III RTT Panels Lined w/ Closed Cell Foam (In Progess...) QTP Reverse Screamer muffler TRD CAI SPC UCAs S.S. Brake lines front and rear S.O.S. Performance rear Disk Brake conversion w/PowerStop performance calipers, rotors and pads KMC Tank 17" beadlocks wrapped in 35x12.5" KO2s Long Range Offroad Extended Range Fuel Tank ATO Dual Battery tray w/ 34D Optima Yellow tops and Blue Sea ML-ACR ClutchMasters Hydraulic Throwout Bearing
    I appreciate y'alls responses, I just ended up having thr truck sit until the Long Range Automotive tank came on the slow boat from down under. Decided it wasn't worth the stress of whatever patch I ended up using failing and potentially making me a bit more crispy than desired. From the last few months of driving, the new tank is great and thankfully I didn't have to fill up much when gas hit stupid highs. The true test will be my 1800 mile trip to Montana this week. Hopefully it's "worth it" lol....
    Raylo and Rick's 2012 like this.
  5. May 16, 2022 at 9:32 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    FYI, plastic welders (at least the ones Ive used) are just soldering irons with broad flat tips. (I wouldnt use them around anything with a listed flash point.)
    They are essential for patching a polyethylene canoe after bashing it one too many times on the rocks. :anonymous: For fiber resins (such as gas tanks and truck beds), they won't be a good repair solution.
  6. May 16, 2022 at 12:14 PM
    Raylo
    Raylo Well-Known Member
    MD, USA
    2023 Tundra SR5 OffRoad; (2009 Tacoma - sold)
    All stock, except for audio and convenience add-ons
    I always say there ain't much in the world you can't fix with a little duct tape, a hammer, and some JB Weld. But a gas tank might be one of them. If you use any kind of sealer or epoxy use some fine metal screen to provide a matrix for it to hold to across the hole opening. Lowes sells a LocTite brand epoxy specifically for plastic that might be better for the tank, but I am not sure it resists gasoline. Need to check the fine print. Maybe also look at marine epoxies. Best to just get a new tank. Obviously.
  7. May 16, 2022 at 9:04 PM
    Rick's 2012
    Rick's 2012 Well-Known Member
    Rick
    Costa Rica
    2012 Double Cab 4x4 Grey with leather
    Stock
    Thanks for the update OP :thumbsup:
    So many just leave us hanging .....
    ThePanda[OP] likes this.
  8. May 17, 2022 at 9:41 AM
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    So….was this some type of petty revenge by an ex or someone stealing gas? Also wondering where the,” get a gas tank skid to prevent possibly happening in future” Crowd is at .
    In reality, just glad to see OP got rolling again.
  9. May 17, 2022 at 10:41 AM
    ThePanda
    Kaelan
    Colorado
    To quote Garth Brooks "All my exes live in Texas..." so it was prolly some crackhead needing gas because he spent all his cash on dumb shit. Jokes on him. He probably got like 3 gallons of gas at most. The LRA tank is metal so at the very least it'll take the fuckers longer next time.
    Chris(NJ)[QUOTED] likes this.
