JB Welding Radiator (my conclusion: don't do it lol)
Discussion in '1st Gen. Tacomas (1995-2004)' started by ThunderOne, Oct 7, 2020.
  1. Oct 8, 2020 at 11:50 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Since you've made the repair, does it leak? That's how you know if it's a workable repair.
    But it is definitely not permament. JB weld is a good trail fix, or if you're on an extreme budget.
    If it's not leaking, great, but it's still a ticking time bomb. Go to Rock Auto or some other place, spend the $100 and get a new one. Last thing you want is a pink milkshake, which is a distinct possibility with a rad that you already know has failed.
    tacomataco2 and Wyoming09 like this.
  2. Oct 8, 2020 at 1:15 PM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    No clue I seldom use any of that type of product if it can`t be welded I stay far away .
    Most times I am repairing the failed attempt to glue something back together
  3. Oct 8, 2020 at 1:17 PM
    coldaccord
    coldaccord Well-Known Member
    André
    Buffalo, NY
    2000 Tacoma 3.4L 4x4
    I would not trust that repair nor risk it by any means, but if you do, best of luck to you
    Wyoming09 likes this.
  4. Oct 8, 2020 at 1:18 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    Bonding non-ferrous materials happens.
    phoenix ray likes this.
  5. Oct 8, 2020 at 1:26 PM
    Broke Okie Ty
    Broke Okie Ty Well-Known Member
    Ty
    California/Oregon/ Now in Montana
    01 trd with some stuff
    Armor, winch, other stuff
    That just means you don't know what you're doing...
    Abeyancer likes this.
  6. Oct 8, 2020 at 2:21 PM
    coldaccord
    André
    Buffalo, NY
    interesting thing to say to a person, but hey, it's the internet. There is rudeness everywhere.
    Rachelsdaddy and Wyoming09 like this.
  7. Oct 8, 2020 at 2:30 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    If it's cracking now and you have sealed it, it's a ticking time bomb before the crack begins to spread further. If you used the putty style JB weld it probably won't hold for incredibly long but if you used the liquid type 2 part resin you may be okay.
    Trouble is that since it a system which deals with not only pressurizing things within the cooling system but there is water running through it, it's only a matter of time before it busts and at that point it would leave you stranded since water leaks out quickly. Around town I would probably say okay, it can probably hold you for some time, but long trips, nope. Replace it. Regardless, replace it when you get the chance. Sooner rather than later. As others have mentioned it's a temporary bandaid.
  8. Oct 8, 2020 at 4:31 PM
    Broke Okie Ty
    Ty
    Lol, well do you? Do you know how to properly mix and apply jb weld? Have you successfully done it? I did. It held for 3 years. I put 20k miles on my jb weld fix. Have you? Also, the internet has nothing to do with it. I'd say it to your face just as soon as type it.
  9. Oct 8, 2020 at 4:51 PM
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    I think there's an opportunity to learn if @ThunderOne , who's not a noobie by any means, wants to give it a try. Obviously heading out into a remote place isn't advisable, but that's probably not what he's thinking of.
    Worst that happens is 2 gallons of antifreeze go into a sewer which, as angry mobs of keyboard protesters will say is abhorrent, truly isn't the worst of ecological disasters we already contribute to in America.
    Best that can happen is a legitimate experiment that we and others can learn from and possibly save someone's last pennies down the line or get them off a trail on their own power.
    Just my 2¢.
  10. Oct 8, 2020 at 11:00 PM
    ThunderOne
    ThunderOne [OP] Well-Known Member
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    To the questions asked, yes I used the 2 part resin, and even though I love JB Kwik and use it on all sorts of things, I used the original version knowing that it is far more heat resistant than its "Kwik" counterpart. I don't normally use Steel Stik but it does have a few applications that I have used it for in the past, including my retrofitted headlights.
    I looked at a few other threads on the interwebs with similar people throwing hyperbolic arguments about JB weld patching a radiator, only to see the OP come back years later and say the patch still held. There are also several articles on JB welding a radiator crack.
    That being said, the point about the radiator being old and thus susceptible to cracking in *other* areas due to its age is completely valid and I do plan to keep a closer eye on the condition of the radiator going forward. I had to add about 1/3 gallon of distilled water to the rad and a little bit to the overflow resi. I haven't driven it yet so I cannot report on the fix yet, but I did apply a little more JB weld over the existing patch just as an extra layer of security since I do know I am dealing with a pressurized system. Even so, JB weld does have a working pressure rating far beyond anything the radiator is designed to withstand, so I am not worried about that at all. I will be keeping an eye out for new cracks and if another pops up in short order, a replacement will be promptly purchased.
    Dalandser likes this.
  11. Oct 8, 2020 at 11:15 PM
    ThunderOne
    Mitchell
    Nashville
    1ST GEN OR GTFO
    Toyota NERD
    In case anyone is curious about the applications for JB weld, here's a good video. Project farm has other more crazy videos with JB weld also.
    https://youtu.be/XObmZIbHOzY
  12. Oct 9, 2020 at 6:39 AM
    Indy
    Indy Master of all I survey.
    I was modding a grill once and removing cross bars with a sawzall. Turned out the blade was 1/4 longer than I thought it was.
  13. Oct 9, 2020 at 6:41 AM
    Indy
    I used the liquid, it will flow into cracks and holes a bit.
    GQ7227[QUOTED] likes this.
  14. Oct 9, 2020 at 12:25 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    One does what one can to get by.
    Myself it would fail in the worst possible place the way my luck goes.
    To get off the road I would most likely drive far enough to take out the head gaskets and a few hundred dollar towing bill .
    This happened with a failed hose not even a radiator
  15. Oct 9, 2020 at 2:57 PM
    #35
    Parkvisitor
    Parkvisitor Do you know midnight?
    Juan
    So Cal
    It’s a truck
    stuff
    well said Dalandser!!
    Dalandser[QUOTED] likes this.
  16. Oct 9, 2020 at 4:27 PM
    #36
    shawnster88
    shawnster88 Well-Known Member
    Shawn
    Defuniak Springs, FL
    96 Tacoma Reg cab 2.7 5 speed
    OME 881 coil springs, OME nitrocharger sport shocks front and rear. Nitro 4:56 gears. ARB rear locker. Shrockworks front bumper with Warn M8000S winch. 17x9 SCS Ray 10 wheels w/ 285/70/17 Toyo Open Country RT Trail tires. Corbeau Trailcat bucket seats. Go Rhino roll bar w/ KC Daymaker lights. GMRS Radio. Ham Radio.
    Mine cracked in the same place and I put jb weld all over it. I drove it like that for about 6 months. I wasn’t off roading or towing during that time. I blew a head gasket and jacked my head all up so I put a new engine in. Replaced the radiator while I was swapping engines.
    Abeyancer and Dalandser like this.
  17. Oct 9, 2020 at 4:40 PM
    #37
    Rachelsdaddy
    Rachelsdaddy Well-Known Member
    Southern NH
    99 PreRunner 4x4 2.7
    I did the same thing, ground out the crack a little, filled it in, sanded down and did a couple more coats. Lasted nearly 3 years :)
  18. Oct 10, 2020 at 3:17 AM
    #38
    ROlla-Xrs
    ROlla-Xrs Well-Known Member
    Roman
    Elk,WA
    1st gen Trd Tacoma
    I ran jb welded radiator for 8 years
    0 leaks and sold the vehicle
    Rachelsdaddy likes this.
  19. Oct 10, 2020 at 3:48 AM
    #39
    Wyoming09
    New Tripoli Pa
    Super Springs
    I think quite a lot of the success has to do with where you live .
    How often you see massive thermal changes from lets say 0 degrees F to coolant temp of 180 degrees a few times a day 7 days a week.
    It works or it does not .
  20. Oct 10, 2020 at 4:00 AM
    #40
    koditten
    koditten Well-Known Member
    Kirk
    Central Michigan
    04 trd x-cab 4 x 4 3.4l
    Reserected from the dead.
    I've always replaced my rads at 200k. I figure the rad needs flushed about that time anyways.
    A rad flush is $125 most places.
    A new rad is $85 and 2 gallons of coolant is $20.
    I figure you are ready for a rad, but am curious to see how long the JB Weld lasts.
