Jba control arm questions
Discussion in '2nd Gen. Tacomas (2005-2015)' started by 98tacojunky, Nov 15, 2019.
  1. Nov 15, 2019 at 2:42 AM
    98tacojunky
    98tacojunky [OP] Well-Known Member
    Upstate NY
    2019 TRDOR double cab
    I currently have a 2012 double cab trd sport with a 6” bds lift and fox coilovers. I get a little bump steer from time to time and I’m suspecting my caster is out. I want to order a new set of UCA and have decided JBA is probably where I’m going. I just don’t know How much the high caster option changes the caster and I don’t know what my caster is currently.
  2. Nov 15, 2019 at 7:56 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    2 degrees of built in caster. You can also txt marlin and he’ll confirm.
  3. Nov 15, 2019 at 9:39 AM
    98tacojunky
    Upstate NY
    Tried to call and text, no answers
  4. Nov 15, 2019 at 9:55 AM
    LAMCKMA007
    LAMCKMA007 Well-Known Member
    San Diego county
    2006 DCLB 2WD
    I am unfamiliar with a BDS lift, if it uses a drop bracket you'll probably want JBA's UCA's designed for a stock setup. JBA's High Caster UCA's are for 3-4* caster and are intended for a 2-4" lift.
    The customer service I received was OUTSTANDING. He was at SEMA and stated he didn't know when he'd get the chance to reply and then a few minutes later he replied anyway. I've never called, I only sent a text and an email. He didn't reply to the email, probably because he was at SEMA, and I got impatient so I sent a text which he replied to. JBA calls: 215-839-1700, JBA texts: 855-533-7437.
    By the way, JBA UCA's are available in red powder coat assembled and unassembled in a raw finish.
