JBA header installation experience
Discussion in 'Performance and Tuning' started by Light-tower, Sep 21, 2007.
  1. Sep 21, 2007 at 4:02 PM
    Light-tower
    Light-tower [OP] Well-Known Member
    Going with Magnaflow exhaust and the Volant intake, but it seems that JBA owns the market for the headers. Would like to see an install guide to this so I know what to expect.
    In inspecting the truck, it looks like it will have to be welded to a pipe extender to the catalytic convertor?
    Going to talk the service guy at Toyota. Seems like a cool cat and maybe I can make him install the headers at least. The Mag and intake are very easy:)
  2. Sep 21, 2007 at 4:44 PM
    Spyder327
    Spyder327 Well-Known Member
    Phoenix, AZ
    2005 X-Runner
    Aquamist 2D meth/water injection kit, URD Exhaust, DT Long Tube Headers, Hood Struts, and lots of other miscellaneous stuff...
    Yea the JBA headers require that you cut the front cats off of the stock manifold and weld them to the headers.
    There's also long tube headers out there, but they take out the front set of cats. Benefit to these is higher power and all bolt-on.
  3. Sep 21, 2007 at 7:11 PM
    Light-tower
    How are these for leaks in the cold winter. I live in Ontario, Canada and it can get friggid.[​IMG]
  4. Sep 24, 2007 at 10:24 AM
    Spyder327
    Phoenix, AZ
    2005 X-Runner
    I live in Arizona, so i definitely cant answer that ;)
  5. Sep 24, 2007 at 5:18 PM
    Light-tower
    Nope...you definitely can't:D
  6. Oct 5, 2007 at 6:39 AM
    thenrie
    thenrie Well-Known Member
    Stafford, VA
    2000 Tacoma, SR5, TRD, 2.7L (LEV), 4wd, 5sp m
    Magnaflow cat and cat-back exhaust, AFE Stage 2 cold-air intake system, 2.5" lift via Skyjacker leaf packs, Bilstein 5100s.
    Does taking out the front cat violate emissions laws? I have to get an inspection every year in PA for emmissions.
  7. Oct 5, 2007 at 9:03 AM
    Spyder327
    Phoenix, AZ
    2005 X-Runner
    Yes, im sure it would violate emissions, but on the bright side, when it comes time for emissions you can always put the stock manifolds back on.
  8. Oct 5, 2007 at 11:54 AM
    lsocoee
    lsocoee My hair is all natural Moderator
    Hotdog
    2007 PreRunner SR5 Double Cab
    Wet Okole Underwear
  9. Oct 6, 2007 at 6:05 PM
    thenrie
    Stafford, VA
    Apparently that header is only for the v6.
  10. Oct 7, 2007 at 7:57 PM
    My68ur8trd
    My68ur8trd Well-Known Member Vendor
    Justin
    Williamsburg, VA
    2007 TRD OR Dcab 4x4
    URD Catback | TRD CAI | TRD S/C | APR X-1 | DTLT | APR 2.85" Pulley |Fabtech 6" | Icon C/O | Alcan Leafs | 33 Grabber AT2 | 17" XD Addicts
    Ill let you know I have them sitting here in a box :thumbsup:
    Justin
  11. Oct 7, 2007 at 8:07 PM
    07TRDsport
    07TRDsport Carolina Alliance
    i believe theres 2 sets of cats up there and you could get away with taking out the set closest to the headers.. maybe.
  12. Oct 7, 2007 at 8:20 PM
    My68ur8trd
    Justin
    Williamsburg, VA
    taking the first set out would throw a CEL without and O2 SIM. Those are the only ones that are monitored by O2 sensors. you could pull the rear two and get away with it. I do in VA:thumbsup:
    Justin
  13. Oct 8, 2007 at 6:34 PM
    07TRDsport
    you have a nice taco my68... hows yer mpg with the supercharger? tight little setup though.
  14. Oct 9, 2007 at 3:52 PM
    My68ur8trd
    Justin
    Williamsburg, VA
    I got 24 mpg on the way back from Atlanta. ( best ive gotten) I generally get around 18-19. except when im playing alot. the worst ive gotten was 15
    And thanks for the compliments :)
    Justin
  15. Oct 18, 2007 at 1:28 PM
    m3dragon
    m3dragon Well-Known Member
    Sacramento
    Anyone know what the HP/TQ increase is with running the JBA headers and a full custom exhaust with Hi Flow cats? Dang Smog rules...
    Also save money and do not ceramic coat them. That is a old hot rod trick to keep motor temps down. all new cars use heat scavenging so as you move the heat is sucked out of the motor bay. Last the ceramic coat make the headers not last as long as all the head is forced in the metal. Just a little $$ saving FYI...
  16. Oct 18, 2007 at 1:33 PM
    m3dragon
    Sacramento
  17. Nov 3, 2007 at 5:16 PM
    m3dragon
    Sacramento
    Off topic a bit but how do you like the Volant and Head Combo? Still am torn between AFE and Volant for the intake but plan on doing the JBA headers.
