JBA Headers check engine light
Discussion in '1st Gen. Tacomas (1995-2004)' started by CaseyG_94, Sep 12, 2023.
  1. Sep 12, 2023 at 6:15 PM
    CaseyG_94
    CaseyG_94 [OP] Member
    Casey
    Toyota tacoma
    Installed JBA headers and check engine light came on.
    Would a 02 spacer clear the code or would I need a tune?
    have all sensors in and have a high flow catalytic converter. 2002 v6
  2. Sep 12, 2023 at 8:03 PM
    Glamisman
    Glamisman Well-Known Member
    what is/are the code(s) and are there any exhaust leaks.
    Wulf and Bivouac like this.
  3. Sep 12, 2023 at 8:54 PM
    v5ensx
    v5ensx CARB legal is not CALI legal
    Don't want to burst your bubble but all aftermarket header minus the TRD are JUNK! Even the legendary DT leak and have fitment issue.
    Stick with the factory. Headers without SC have minimum gain.
    SmoothTRD likes this.
  4. Sep 13, 2023 at 8:45 AM
    02hilux
    Planet: EARTH
    Knowing what the code is will help. Maybe you forgot to connect the front sensor back in after the installation?
    I'm not aware of a spacer for the sensor as our sensor are held in place with 2 nut. They're not like the older version that is screwed on and can use a non-fouler to assist. Plus, there's no tune available that I'm aware of.
  5. Sep 13, 2023 at 9:11 AM
    CaseyG_94
    Casey
    Toyota tacoma
    Code is P1135
  6. Sep 13, 2023 at 9:29 AM
    02hilux
    Planet: EARTH
    I would start with erasing the code with a scanner than DC the pigtail from the body harness and reconnect.
    CaseyG_94[OP] likes this.
  7. Sep 13, 2023 at 9:46 AM
    CaseyG_94
    Casey
    Toyota tacoma
    02hilux I’ll get on it. Headers wouldn’t throw that code would it?
  8. Sep 13, 2023 at 9:48 AM
    02hilux
    Planet: EARTH
    Nope. I'm running JBA also without any code
  9. Sep 13, 2023 at 9:49 AM
    CaseyG_94
    Casey
    Toyota tacoma
    Right on I’ll get on it. Thank you.
  10. Sep 13, 2023 at 9:52 AM
    02hilux
    Planet: EARTH
    -Check the body harness, make sure you didn't pull or damage the connector
    -inspect the sensor connector. Unless you somehow damaged the wires when trying to remove the sensor
    CaseyG_94[QUOTED][OP] likes this.
  11. Sep 13, 2023 at 10:43 AM
    CaseyG_94
    Casey
    Toyota tacoma
    reading 2.4 ohms on AF sensor. Should be around 1.2 correct?
  12. Sep 13, 2023 at 2:52 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Either just bad timing The heater Circuit quit in the sensor or you damaged the harness in some way.
  13. Sep 13, 2023 at 3:17 PM
    CaseyG_94
    Casey
    Toyota tacoma
    Check engine hasn’t came back on so far. I’ll keep you updated.
    Bivouac[QUOTED] likes this.
