Jba headers making weird sounds on acceleration
Discussion in '1st Gen. Tacomas (1995-2004)' started by Skillet, Feb 23, 2011.
  1. Feb 23, 2011 at 9:20 PM
    Skillet
    Skillet [OP] Well-Known Member
    Caleb
    Palmdale,Ca
    99 tacoma prerunner 3.4 auto trans trd,
    Trd edition,black powdercoated wheels,king Coils front, king double bypass rear, k&n cai, jba headers,borla exhuast,optima batt,xenon hid,crystal headlights,rewired entire car to four guage wiring on big stuff alt starter etc.,alpine screen,focal honeycomb components,JL four channel amp,dynamated entire inside of truck and hoodliner,limo tint all rear windows,LEDs everywhere possible dome light, tails,fronts,04 tailights,
    Put on a set of jba headers on my 3.4 taco took 9 hours for what I would call a perfect install but... Even though I took my truck to my trusted exhuast mech for exhuast leak check and everything passed flying colors my truck sounds like I have an exhaust leak, even though things are completely torqued ! My question is could there be a exhaust leak under load only sometimes? Is this a rattle that may need to be found on a dyno cause it won't rattle or make a leak noise unless the engine is under load... I checked every bolt on the whole truck for looseness still no fix.. It happens around 2000-3500 rpm under load anyone have this happen with there bolt on jba headers ? Thanks for any help Im losin hair over this. + forgot to mention it comes from the driver side mainly where jba has you removing permanently the return throttle cable support, so I secured the cable very well so it won't rattle ( very confused ) and don't like grease monkey pos mechanics to look at my truck so I need dire help. Thanks guys
  2. Feb 24, 2011 at 12:06 AM
    subtleshift
    subtleshift Noob
    Dallas
    Irvine, Ca
    01 Tacoma TRD
    K&N high flow filter, 2x Yakima bike mounts
    really easy diagnostic...seafoam your taco and see if you see any smoke leaking out...
    might help to have someone cycle your throttle while you watch
  3. Feb 24, 2011 at 2:28 AM
    4WD
    4WD cRaZy oLdmAn
    Doug
    Lakeside, Ca / Gardnerville, Nevada
    2004 DC TRD 4x
    Grey wire MOD, deck plate, diff breather MOD, 2nd gen. OME 883# on Tundra 5100's, OMD custom 3" leafsprings, rear shock relocation, Ivan Stewart TRD rims w/285/75/16's, '02 bumper MOD, Famous Fabrications sliders , LED interior/exterior lights, bed bar, Custom tube bumper, Old school KC day lighters,Red Ring 8" HID flood, Kenwood vhf 2M.. umm some other shit I'm forgetting right now
    So is it a rattling (like sheet metal ?) or maybe it sounds like a "tick", most exhaust leaks I've encountered sounded like more of a ticking sound
    or sometimes it'll sound like a rapid release of air, depends on leak, try crawling underneath your truck with a good light & carefully check each flange, each connection, wherever connection surfaces are look closely for sooty black (or white) blowouts around where surfaces meet, if you find these more than likely this will be the location....
  4. Feb 24, 2011 at 10:20 AM
    Skillet
    Caleb
    Palmdale,Ca
    I'll look harder for a leak and I'll try seafoam and see if smoke comes out , Ive had exhaust leaks before and it sounds like a leak but it sounds also like a rattling exhaust shroud but the exhaust shrouds/covers have been checked for tightness it's a tappin/rattle + do I need to change plugs after seafoaming it?
  5. Feb 24, 2011 at 4:14 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    I've never seafoamed but yeah you'll have to change plugs cause they're gonna pick up alot of shit getting loosened up ...;)
  6. Feb 24, 2011 at 5:02 PM
    shitroc
    shitroc Master of War
    Ant
    New Brunswick, Canada
    2002 Tacoma TRD 4X4
    Listed in sig.......
    maybe there is a warp in the header around a flange not allowing it to make sufficient contact with the gasket.
  7. Feb 24, 2011 at 10:04 PM
    4WD
    4WD cRaZy oLdmAn
    Doug
    2004 DC TRD 4x
    yep, wouldn't be the first time aftermarket headers did this....;)
  8. Feb 25, 2011 at 12:09 AM
    Yamaha Dave
    Yamaha Dave Well-Known Member
    Another thing you might want to check is when I added some headers to a Mustang I had a few years back, after the install it sounded like I had a leak. We put it back on the lift checked every nut and bolt and found out the "leaking" sound I heard was actually the sound of 1.) more exhaust gases flowing 2.) the headers were a light weight aluminum header and the metal was thinner so you could "hear" it easier. Make sense?
  9. Feb 25, 2011 at 12:01 PM
    Skillet
    Caleb
    Palmdale,Ca
    I see what you guys are saying It might just be me overanalizing it might be the sound of more flow under load resonating off of the engine bay,( all the bolts are torqued to spec) so the last step would be to upgrade the head to header gaskets with the copper embossed gaskets from summit..Well see what it is this weekend as soon as the gaskets come in. Thanks!
  10. Mar 5, 2011 at 4:55 PM
    Honey badger
    Honey badger Honey badger hits whatever tree he wants to hit!!
    Bon
    Kinder, Louisiana
    02 DC BLACK 3.4
    I just unsealed the DT headers and like the guy above said there us an odd sound that may be more flow. I have checked all bolts, flanges, and gaskets all are good even had a Toyota tech look at them. Sound is still there:confused:
  11. Dec 17, 2011 at 9:15 PM
    dark tangent
    dark tangent Well-Known Member
    Madison, WI
    Rigid Dually D2 Amber Driving LEDs mounted on CBI Offroad ditch light brackets.
    I have the same problem. Just installed JBA short headers and exhaust, and under load/acceleration there's a ticking noise that is driving me crazy. The exhaust sounds awesome, but the tick....not so much.
    I've read a couple possible areas that are to blame. 1) it's the normal ticking noise coming from the heads and the new headers are funneling that noise through the tubes louder than the stock manifolds did, or 2) there's a leak somewhere. Does anyone have any insight on this ticking BS from JBA?
  12. Dec 17, 2011 at 10:09 PM
    hayabusa3303
    hayabusa3303 Well-Known Member
    florence sc
    95.5 taco 4x4
    ARB bumper, warn 9.5 winch. carbon fiber hood. Leer top with thule racks and MOAB from thule. Electric fans, blue sea fuse block, Sony dvd Head unit, Xm tuner and HD tuner. New carpet and new racing seats. ( other half doesnt like them i think). Nwor springs and adjustable coil overs. Sky jacker rear shocks. Slot and drilled rotors. Engine Titanium ceramic coated headers, no cat, jba cat back. URD Rear Sensor Simulator. Leds all around and inside cab and HID H4 hi/lo beams.
    Mine does the same thing. I traced it down to a valve on mine. Its not leaking it just the way i have my head set up from the machine shop. Heads are setup for a supercharger.
    Check your valve clearance to be sure. I did mine was ok.
