JBA high caster
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dr. Emmett Brown, Jan 10, 2020.
  1. Jan 10, 2020 at 7:52 PM
    Dr. Emmett Brown
    Dr. Emmett Brown [OP] Well-Known Member
    So I did a thing ..
    After about 8 months of being on a 2.5" lift I finally ordered some UCAs. I decided to go with JBAs with high caster because I've only heard good reviews, I'm planning on going to 33s this year and don't get me wrong, they're sexy red. Lol but seriously.
    I do all installs myself so I need some advice on time frame after install.
    How long can I drive without an alignement? Say I put them in on a Saturday, if I can't get an alignement till the following Saturday due to work and scheduling for the week, will I be okay?
  2. Jan 10, 2020 at 7:57 PM
    Ccrames2018
    Ccrames2018 Jack of some trades.
    Caden
    Nor Cal
    06 DCLB TRD Sport
    -Bilstein+OME suspension, ARB bumper w/Smittybuilt XRC winch, Aero exhaust, CMC, oddball size 275/70R17 General Grabber ATXs on 17x8 0 offset Pro Comp wheels, etc.
    It would be best if you could wait until you can get it done right away. When I did mine it pulled hard to the right until I got to the shop. Must have messed with the toe adjustment or something. If you have mud tires a week of that could put some wear on them too.
    Also an install tip, just loosen the bolt up, cut the old bolt head off, and put a new bolt and hardware in from the rear so you don't have to spend hours trying to bend the inside of your engine bay enough to get the old one out. I wished I had just bought new bolts by the time I was done.
    Rockefelluh likes this.
  3. Jan 10, 2020 at 8:00 PM
    Dr. Emmett Brown
    Good info and thanks for the tips. Where do I get s new bolt from?? I've seen videos suggesting reversing the way it goes in so I definitely will do this
    Ccrames2018[QUOTED] likes this.
  4. Jan 10, 2020 at 8:01 PM
    Ccrames2018
    Caden
    Nor Cal
    06 DCLB TRD Sport
    You can get them from the dealerships but they're a bit expensive. I'll take a look and see what I find.
  5. Jan 10, 2020 at 8:02 PM
    Taco-Grinder
    Dan
    Fond du Lac, WI
    I do believe Wheelers Off Road has them.
  6. Jan 10, 2020 at 8:03 PM
    Ccrames2018
    Caden
    Nor Cal
    06 DCLB TRD Sport
    Taco-Grinder likes this.
  7. Jan 10, 2020 at 8:04 PM
    Dr. Emmett Brown
  8. Jan 10, 2020 at 8:06 PM
    Ccrames2018
    Caden
    Nor Cal
    06 DCLB TRD Sport
    Haha no prob. I think my dealer wanted $20 a bolt but it would've been worth it even then to me.
  9. Jan 10, 2020 at 8:49 PM
    Dr. Emmett Brown
    Wait so do I need two or just one? Are they both installed facing down towards the rear of the truck?
  10. Jan 10, 2020 at 8:52 PM
    Bertw192
    Bertw192 Well-Known Member
    Bert
    Seattle, WA
    2017 TRD OR DCSB
    All the things!
    You need 2.
    Both sides face the same way, so you'd cut the heads off of both.
    synaps3 likes this.
  11. Jan 10, 2020 at 8:57 PM
    Ccrames2018
    Caden
    Nor Cal
    06 DCLB TRD Sport
    You'll need 2, one for each side. And yeah put both back in from the rear. The nut will go on the front instead. Grease them before you torque them down.
  12. Jan 10, 2020 at 9:00 PM
    calebc
    calebc Well-Known Member
    Honestly, the bolts are a pain to remove the first time, once you get them out once, doing it again is really easy. You shouldn’t have to touch your toe for the install so it shouldn’t be far off. If all you’re doing is upper arms, total time is probably 30-40 mins a side.
    Just jack up under the lower arm, this will remove the pressure on the upper arm. You can then remove the bolt, pull the arm, out the new ones in, sip the bolt back in and you’re done. Super easy to do. I did the install on mine a couple months ago and just got it aligned today. I went with them SPC arms and I just made sure the little flat nub on the steering knuckle was at 0* and that resulted in mine not being far off. You won’t be able to adjust them so put them in, take it for a spin and see if if feels off, if it does get it aligned ASAP. If if feels fine, you should be ok taking a couple days before getting it done.
  13. Jan 10, 2020 at 9:07 PM
    m603holden
    m603holden @Koditten Pirate Radio member #063
    Marteeen
    New England
    2017 Tacoma DCSB OR MT
    Lots of sail boat fuel
    @Dr. Emmett Brown it's a non issue. Take some channel locks, bend the sheet metal, slide it out, install, replace. Not that big of a deal. I suspect most off the issues come from those who don't want to hurt their trucks or aren't mechanically inclined.
    About two years running JBA uca. You'll be very happy with your purchase. I push mine at a reasonable limit and am very happy with them.
    Ps, you might want and a second set of hands and a giant flat head as a spreader bar to install them. Getting them on with the bushings can be tight.
  14. Jan 10, 2020 at 9:10 PM
    calebc
    Exactly! Just get some channel locks on the sheet metal and bend it. It would be harder to cut the bolt than to just slide it out.
  15. Jan 10, 2020 at 9:18 PM
    m603holden
    Marteeen
    New England
    Yup. Agreed.
    Took me all of an hour to do both sides with my brother.
    Dr. Emmett Brown[OP] likes this.
  16. Jan 10, 2020 at 9:21 PM
    Dr. Emmett Brown
    Will I need new bumpstops?
  17. Jan 10, 2020 at 9:23 PM
    m603holden
    Marteeen
    New England
    Eh. Probably not.
    If you start feeling guilty about how Hard you wheel, then maybe.
  18. Jan 10, 2020 at 9:24 PM
    Dr. Emmett Brown
    UCAs mainly help with droop right?
  19. Jan 10, 2020 at 9:28 PM
    calebc
    Yes, but if you don’t have extended Kings or similar then I doubt you’ll need new bump stops.
  20. Jan 10, 2020 at 9:30 PM
    Ccrames2018
    Caden
    Nor Cal
    06 DCLB TRD Sport
    I've trimmed my cab mounts and the metal part of my front quarter panels as well as my fender flares, took a sledge hammer to the pinch welds, and have only 1/3 of the plastic left in my front wheel wells. I also have done all necessary work on my truck myself except oil changes because I'm lazy in that respect.
    Even so, it was a pain in the arse with my truck because the bolt head hit the sheet metal all the way until the end was out of the arm. The only reason I didn't cut it was that I didn't have a replacement. Took me a good hour per side with a ball peen hammer and channel locks to make enough room for the bolt. If they're only $10 per bolt it makes sense to just get new ones, no?
    It could be different truck to truck though obviously so maybe it isn't always in the way so much. Not trying to say you're wrong, just my experience:thumbsup:
    synaps3 likes this.
