JBA Long Tube Headers Review & Install Instructions
Discussion in 'Performance and Tuning' started by 05RedTaco, Nov 21, 2012.
  1. Nov 21, 2012 at 3:02 PM
    05RedTaco
    05RedTaco [OP] Nom Nom Nom
    Tony
    Scottsdale
    2000 Tacoma XtraCab 2.7L 4x4
    I pulled the trigger and ordered JBA long tube headers in stainless steel and URD o2 simulator from URD. I wanted to free up the exhaust in order to gain HP and TQ. By looking at the dyno graph there is only power loss below 2.8k rpm. Above 2.8k rpm the headers SHINE! By 3.68 rpm, there is a torque gain of 24WTQ and 17whp! The headers gain 4whp and 12wtq. I was especially intrigued by the gains between 2.8k rpm and 4.2k rpm which i thought could help when towing and getting up to speed or passing.
    For the price of $468 I paid shipped from URD for JBA headers, gaskets and o2 simulator, the headers are definitely the best N/A performance mod for the 1GR.
    Th JBA headers appear to be good quality. Fit is OK, I was unable to line up the headers with the header support brackets which bolt to the bottom of the header where the header connects to the midpipe.
    One thing to be aware of is that the headers come with four holes for the o2 sensors, you will only be using two holes. The headers don't come with plugs for the holes. The plugs have to be ordered online, they are impossible to source locally.
    Now for the install instructions. Below are Instructions which came with the headers just for reference. I didn't follow these instructions very closely, because many of the steps are unnecessary.
    Now for my instructions;
    Tools needed
    12mm wrench
    12mm socket
    3/8 ratchet
    14mm socket
    14mm wrench
    15mm socket
    15mm wrench
    1, securely jack the truck up and put on jackstands
    2, remove front wheels
    3, remove mud guards inside wheel wells
    4, unplug all oxygen sensors (total of 4)
    5, remove Y pipe - two 14mm bolts hold it to the exhaust and four 14mm nuts hold it to headers (two nuts on each exhaust manifold)
    6, remove 14mm bolt holding exhaust manifold to brace. Bolt located on the bottom of the exhaust manifolds same spot where the ypipe connects to the exhaust manifold
    7, remove nuts holding stock exhaust manifold to the heads of the engine all nuts are accessible through the wheel well (6nuts on each side)
    8, remove stock exhaust manifolds, it requires little twisting because the exhaust manifolds get hold up on the brace at the bottom
    9, remove brace held by two 14mm bolts on each side, my headers didnt line up with the brace
    10, remove old exhaust manifold gaskets
    11, install new header gaskets which came with headers
    12, instal headers and hand tighten all header nuts (6 on each side)
    13, tighten header nuts, work from inside out alternating top to bottom, once all nuts are tight, tighten them again in the same fashion to make sure the nuts are tight and the headers wont leak.
    14, re-install Ypipe, use the nuts & bolts which came with the headers. two bolts & nuts per side they are 15mm
    15, reinstall ypipe
    16, plug in all 4 o2 sensors
    17, install URD o2 simulator, i used zip ties to secure its harness and secured the unit to transmission mount
    18, re-install wheels
    19, safely lower truck & enjoy new headers!
    Now for some pictures of my headers;
    ARCHIVE and Camel51 like this.
  2. Nov 21, 2012 at 3:12 PM
    KalamaKid
    KalamaKid Well-Known Member
    Jason
    Socialist Republic of Oregon
    same shit as everyone else
    Nice write up :thumbsup:
  3. Nov 26, 2012 at 6:25 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Do you realize that the dyno you posted was for DT headers, not JBA.
  4. Nov 26, 2012 at 8:36 AM
    05RedTaco
    Tony
    Scottsdale
    Yes I do. Since they are both long tube headers, the gains should be very similar.
    JBA Headers;
    Doug Thorley Headers;
  5. Dec 2, 2012 at 9:13 PM
    FLtaco24
    FLtaco24 Just a man and his truck
    JJ
    Daytona Beach/South FL
    09 PreRunner SR5
    Stock for now
    How do you like them so far? I've heard good things about JBA.
  6. Dec 3, 2012 at 4:12 AM
    05RedTaco
    Tony
    Scottsdale
    I like them a lot! There is definitely noticeable power increase past 2.8K rpm. That said headers will make your truck LOUD! My truck has JBA headers, 2nd set of cats cut out and straight piped and 14" magnaflow welded in place of the stock muffler with turn down before axle. It is really loud, but sounds good. It is not too bad when I am easy on the throttle, but when I give it more gas all hell breaks loose :D Exactly how I like it :D:D
  7. Dec 3, 2012 at 8:39 AM
    Kolunatic
    Kolunatic dont tread on me!
    Texas
    07,2wd,DC,SRD,TRD Sport,because
    Can ya post pics of entire exhaust system please. I was wanting to do this next year but don't know what cats to get. Thanks
  8. Dec 4, 2012 at 10:01 PM
    TacomaGus
    TacomaGus Well-Known Member
    Gus
    Morgantown, WV
    08 White TRD Sport DC
    Tinted Tails, TRD Shift Knob, Kenwood Headunit, Ebay BHLM Lights, Trimmed Mud Flaps, 265/70/17 General Grabber AT2's, WeatherTech Mats, Black Badges, Sylvania ZXE Bulbs, AFE Stage 2 Si Intake, 17x8.5 Level 8 Guardian Wheels, URD SS, Custom 2.5" Catback with Aero 2525 and Vibrant Ultra Quiet Resonator, URD MAF CAL, JBA LT Headers, OME 884's, Nitrochargers, Dakars with 3rd lead removed, Light Racing UCA's
    Great post, I love my JBA headers. I honestly don't think I lost any power with them anywhere in the RPM range
  9. Dec 22, 2012 at 12:19 PM
    rrh_2
    rrh_2 Well-Known Member
    Richard
    Devine texas
    05 tacoma 4x4 sr5 dc
    6" pro comp stage one lift ome 885's, 5100's,bhlm, billet grille, lights behind grille, k&n cai , tinted Led tails, tinted 3rd brake light, Lotek a pillar, color matched grille mirrors and door handles, trd seat covers, blacked out windows, color matched engine cover, in-dash flip out screen 2 10'' kicker subs
    Was there a decent mpg increase?
  10. Dec 22, 2012 at 4:18 PM
    Christianson.USMC
    Christianson.USMC WOUNED WARRIOR MARINE
    Will
    Jacksonville, NC
    2011 4wd Sport 4.0 sbed JBL Dcab,3'' lift etc
    TRD Intake, Borla exhaust,JBA long tube headers, DT Y Pipe, Light Racing UCA's, Jet Throttle Body spacer, lifted 3.5" front 3"back. Grill guard w/ KC lights, Stepsides, Tint, hood protector, window visors, Caltrend neopreme seat covers, weathertech mats, HID fog and headlights, 1" wheel spacers front .5 rear, brakelight guards,265/70/r17 till they die and can get 33's, more to come
    I juat took my JBA long tube headers and DT Y pipe out of the box. There are two O2 sensor bungs on the header and one on the Y pipe on each side,6 bungs total.
    I was just going to use the top bung with stock O2 sensor on top of header and block the other and use the URD sim with the stock O2 sensor at the beginning of the Y pipe. Will that work fine/ is there a better way?????
  11. Dec 31, 2012 at 7:51 AM
    05RedTaco
    Tony
    Scottsdale
    That will work fine, thats how my o2 sensors are setup.
  12. Dec 31, 2012 at 8:03 AM
    rrh_2
    Richard
    Devine texas
    Just ordered my set
  13. Dec 31, 2012 at 8:34 AM
    05RedTaco
    Tony
    Scottsdale
    Make sure to get two o2 bung plugs, order them now off ebay... They are impossible to find locally...
  14. Dec 31, 2012 at 10:28 AM
    rrh_2
    Richard
    Devine texas
    Ok thanks
  15. Jan 4, 2013 at 2:37 PM
    rrh_2
    Richard
    Devine texas
    The two exhaust rings that urd sends are supposed to replace the two that come with the gasket kit right?
  16. Jan 4, 2013 at 6:48 PM
    05RedTaco
    Tony
    Scottsdale
    yes
  17. Jan 4, 2013 at 6:59 PM
    06 tacoma owner
    06 tacoma owner Well-Known Member
    Will
    Western KY
    2006 AC super white 4x4
    4 inch lift, 6000k HIDs, weathertechs, Pioneer head unit with bluetooth, 285/70 trail grapplers, aero turbine muffler w/ flowmaster 3 inch stainless tip
    Could you post a sound clip?
  18. Jan 5, 2013 at 8:35 AM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    MMVI 4.4L 4x4 Access Cab
    Torspd Custom Turbo kit [] Borg Warner 9180EFR Turbo [] ProEFI Pro128 EMS [] TiAL Q BOV [] TiAL V44 Wastegate @ 15psi [] CP Pistons [] CP Carrillo Rods [] ARP Head studs [] ARP Main Studs [] ARP Header - Head Studs [] Ported Heads w/ 1mm oversized valves intake/exhaust [] Brian Crower Forged Stroker Crank [] Darton M.I.D. Sleeved Block [] Kelford Camshafts [] Torspd 170* T-stat mod [] APR Large Fuel Rail [] Aeromotive Stealth 340 LPH Fuel Pump [] FueLab FPR [] APR T56 Conversion Kit [] KP RACING Built T56 [] McLeod Racing Custom Twin Disk Clutch [] One Piece Aluminum Driveshaft [] MGW Shifter [] Custom lowering kit [] Ohlins Front Coilovers [] QA1rear shocks [] Custom Ron Davis Radiator [] Dual SPAL Electric Fans []
    You can also order them from URD.
  19. Jan 21, 2013 at 7:49 AM
    rrh_2
    Richard
    Devine texas
    Why did u take the wheels off
  20. Jan 21, 2013 at 9:27 AM
    Torspd
    Torspd Tor-nication
    Tor
    Houston
    It can make it easier to get to the header flange nus.
