JBA Long Tube Headers Review & Install Instructions
Discussion in 'Performance and Tuning' started by 05RedTaco, Nov 21, 2012.
  1. Jan 25, 2013 at 9:48 AM
    #41
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    So you found a leak, and now you got it all fixed up? Good job.
  2. Jan 25, 2013 at 10:16 AM
    #42
    rrh_2
    rrh_2 Well-Known Member
    Richard
    Devine texas
    05 tacoma 4x4 sr5 dc
    6" pro comp stage one lift ome 885's, 5100's,bhlm, billet grille, lights behind grille, k&n cai , tinted Led tails, tinted 3rd brake light, Lotek a pillar, color matched grille mirrors and door handles, trd seat covers, blacked out windows, color matched engine cover, in-dash flip out screen 2 10'' kicker subs
    I just tightened everything as much as possible.. I didn't get one of the nuts on the drivers side good enough the first time
  3. Jan 25, 2013 at 11:02 AM
    #43
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    That will do it. That exhaust tick is very annoying.
  4. Feb 7, 2013 at 5:39 PM
    #44
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    On the stock headers that connect to the y pipe...are the studs on the y pipe or the headers? I cant remnber....but mine are broken and stripped.
  5. Feb 7, 2013 at 10:08 PM
    #45
    rrh_2
    Richard
    Devine texas
    Headers
  6. Feb 8, 2013 at 4:38 AM
    #46
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The factory nuts for those studs are locking nuts. They destroy the threads. I was lucky one time. They came off with not much problem. Not the second time. Now I use a regular nut and a lock washer. Trying to remove the stripped studs is a PITA.
  7. Feb 16, 2013 at 11:26 AM
    #47
    Big O
    Big O Well-Known Member
    Owen
    Dallas , Texas
    ' 06 X Runner ( Red )
    K & N Air Filter , Magnaflow Muffler , Full Synthetic Oil R/P ,block,trans & differencial , New LED taillights, TRD Short Shifter, a Boulekos Sprint Booster !
    What a Good/Inforative post.
    Something that is Sadly, way Too Rare on This Site.
  8. Apr 24, 2013 at 10:49 AM
    #48
    toniodiaz
    toniodiaz Crazy and lovely member
    Maruko
    Southmerica
    2011 SR5 TRD Sport Silver Double Cab and now 2013 SR5 TRD Sport Red Double Cab
    TRD Supercharger, TRD Catback, aFe Cold air intake system, HELLA Rallye 4000 Celis lamps, Spyder Smoke CCFL Halo projector Headlights, JBA Ceramic Coated Long Tube Headers, Centric Cross Drilled Front Brake Rotors, URD smaller diameter S/C pulley, Roof Rack, Recon Tail light bar, 3" OME Leaf pack at the rear with 5100 Bilsteins and Regulable 2.75" Toytec Red Springs with 5100 Bilsteins in the front, Total Chaos UCA, Front TRD Skid Plate, Black Tube Step Bar, Black Emblems and TRD Sport Stripes decal, I JUST FINISHED MY MOD TO THE PARKING, DTR AND TURNING LIGHTS, When you hit the turning switch, DTR ad Parking lights turn of on the side the Turn signals are flashing, so they don't disturb their intensity. Everything installed with my own little hands and help of my dear friend and of course, your mods.
    Hi,
    Just to make sure I got it the right way. So you mean that I have to install both sensors to the ports near to the Engine block and the plugs to those near to the Y pipe coupler?
    How needs the o2 simulator to be wired? To the passenger or to the drivers side sensors?
    Thanks a lot,
  9. Apr 24, 2013 at 10:56 AM
    #49
    toniodiaz
    Maruko
    Southmerica
    Hi,
    Thanks a lot,
  10. Apr 24, 2013 at 12:13 PM
    #50
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    If you purchased the O2 simulator from URD, then it is plug n play. No wiring. That is for the rear two sensors.
    The front sensors are called WRAF sensors. They go into the holes (actual name is bungs) closest to the engine. Unless, you also purchased the extension harnesses. Which then you would put the WRAF sensors into the collectors of the headers. Right before the Y-pipe.
  11. Apr 24, 2013 at 1:15 PM
    #51
    toniodiaz
    Maruko
    Southmerica
    Thanks a lot. That's exactly what I needed to have clear. Yes I have that sim. Let's start working. ;)
  12. Apr 25, 2013 at 2:20 PM
    #52
    HAZARDOUS.ADDICTS
    HAZARDOUS.ADDICTS Active Member
    MIKE
    Scottsdale
    08 long travel tacoma
    Total Chaos long travel, king shocks, strapped front and rear, color matched fiberworks fenders.
    Do you have a video of what it sounds like? I want to get some headers but don't want it to sound like a ricer! Ha
  13. Apr 25, 2013 at 2:29 PM
    #53
    LoadedTaco
    LoadedTaco Kick A$$ Member
    Peter
    Burr Ridge Il
    2012 Red Baja
    I have heard that anytime headers are installed. You have to keep going back and tightening the bolts for the headers for the life of the truck? What are the downsides to headers? So lets pretend I am a complete idiot...:anonymous: Could you explain what is going with the o2 sensors? Is it because the cats are gone and the engine needs to be tricked into thinking something is wrong?
  14. Apr 25, 2013 at 9:16 PM
    #54
    toniodiaz
    Maruko
    Southmerica
    They are on.... :) :) :) We've just finished installing them and as far as I can see they are awesome. The fitting is just as described and following the directions is easy.
    I can hardly notice that sound changed, maybe it's because of the S/C. Now I'll make some tests to feel the improvement.
    Oops, I found some trouble with the 02 sim that URD shipped. Everything was ok, but the connectors are DIFFERENT %&*#Q(!@# No MIL on, but I guess that it will light up suddenly when the ECU finds there are no catalytic converters.
    Anyone had that problem?
    MightyMouseTom likes this.
  15. Apr 26, 2013 at 12:45 AM
    #55
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    They wont connect at all, or have u tried hard enough?
    I was on the list of ppl getting the last batch that were made up......fit was snug and u gotta press hard for the "click"......do your ends match up at all?
    They are only gunna fit 1 way iirc.
    Pics?
  16. Apr 26, 2013 at 4:24 AM
    #56
    toniodiaz
    Maruko
    Southmerica
    I'm going to try once more on daylight, and of course with pics...
  17. Apr 26, 2013 at 5:54 AM
    #57
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Just to be clear, you tried to plug it into the sensors in the Y-pipe, and not the headers correct?
  18. Apr 27, 2013 at 3:41 AM
    #58
    toniodiaz
    Maruko
    Southmerica
    :Frusty: You are right, that was the problem.:eek: We were working at the wrong sensors, maybe because of the time at my pal and I finished the job, we did not notice that issue. :rolleyes:. You know, by then, and after two long days under my sweet Taco and covered by grease and dirt, all we wanted was to :yay: and go to bed. :) Now all work is done are working awesome. Now the engine revs went back to normal, (they were over 1200rpm at idle w/o the sim) That the only symptom I noticed.
    I can't tell there's a noticeable sound increase. Maybe it's the S/C, since it changes radically the engine's sound.
    The power gain is great and of course looks incredible, :burnrubber: now I'm waiting my TRD cat-back and URD SC pulley to get here.
    Thanks a lot you guys, ;)
  19. Apr 27, 2013 at 5:16 AM
    #59
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Tor ftw......glad u got it sorted out
  20. Apr 27, 2013 at 9:36 PM
    #60
    TigerTheory
    TigerTheory Member
    Washington
    05 4x4
    Toyotec lift, Doug Thorley Long Tube Headers, URD Y Pipe, URD Exhaust
    All the white smoke and smell is the chemicals burning out of all the new pipes and headers from the welding. It should go away after a half an hour or so of constant running.
    Remember to re-torque the headers after about 100 miles.
    And NO it sounds nothing like a "ricer". Almost like a V8 but not, it's pretty unique sounding IMO. I have DTLT headers, off road Y pipe, and magnaflow system. Sounds best at 3500 plus RPM. Nice tight quiet rumble at idle. Hardly noticeable even without the Cats.
