JBA Long Tube Headers Review & Install Instructions
Discussion in 'Performance and Tuning' started by 05RedTaco, Nov 21, 2012.
  1. Apr 27, 2013 at 11:06 PM
    #61
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    No rasp above 2k?
    The dtlt, urd y, urd 3" exhaust has terrible rasp n/a imho and many others.
    what magna system did u get?
    Mine sounded like it had a massive fart can on a civic imho.....sounds like u got a better muffler.....size/part # would help others possibly :)
    I know with the urd 3" system, many ppl run 2 mufflers or a resonator.
    Do u have sound clip?
  2. May 1, 2013 at 3:39 PM
    #62
    yota243
    yota243 Well-Known Member
    E.J.
    north Alabama
    turbo 05 prerunner trd off road DC
    Bw s256 turbo with 3 in glass pack dumped pre axle raptor liner bed and top rails and fenderflares and rocker panels. Hunter side steps. Plasti-dipped upper fenders and emblems. satin black spray paint here and there inside and out. 5100's set to 1.75" up front . C channel front bumper. Maxxis bighorn 255/85/16
    Excuse my ignorance, but the stock manifold looks relitively efficient. Has anyone just deleted the cats and compared those gains to these since would be the fairest way. I'm debating on cutting the back two cats out my self is why i ask to see what gains are to be had if any.
    jonahJohnson likes this.
  3. May 7, 2013 at 2:35 PM
    #63
    yota243
    E.J.
    north Alabama
    anyone have an answer for the aforementioned question about the cats? i did see a write up by chris4x4 i think, on scavenging, and how everything in the stock exhaust is harmonious and such, but it would reduce the back pressure quite a bit to remove some cats and as long as the pipe size and shape is the same should be beneficial in theory.
  4. Apr 20, 2015 at 5:47 PM
    #64
    Randolph
    Randolph Member
    Randolph
    Marietta, SC
    02 4WD TRD SR5 V6 Stepside
    Single Magnaflow Cat, Bilstein 4600s, deckplate airbox mod,
    Hi, I know this is an old thread but I hope you are still getting these posts.
    I just had a manifold cat go bad on my 2006 Tacoma. I replaced it with the MaganaFlow direct fit unit and my truck still has the inefficient cat code.
    I paid $557 for the Magna flow and then I find out I can get the same set up as you for less money (and BOTH) sides. O'Reilly's say they will take the MagnaFlow back so I'm getting the JBA long tubes.
    My question: have you noticed any heat problems from the headers and would you pay $90 more for the ceramic coated versions if you had to do it over? (URD says ceramic coatings reduce the radiated heat).
    Thanks,
    Randolph
  5. Apr 21, 2015 at 11:03 AM
    #65
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    If you plan on getting the long tubes, get the URD Spec-U. Much better gains and sound from them. I have posted the dyno chart in a couple posts. One being in my N/A dyno link in my Sig.
  6. Apr 22, 2015 at 4:38 AM
    #66
    Randolph
    Randolph Member
    Randolph
    Marietta, SC
    Out of stock and I have to install something now since I have a bad front cat
  7. Mar 11, 2016 at 9:10 PM
    #67
    Randolph
    Randolph Member
    Randolph
    Marietta, SC
    Hello if anyone is still reading this. I got the JBA long tube, SS, ceramic coated headers installed last April after a lot of swearing at the tight fit.
    I installed the "URD Dual Rear O2 Sensor Simulators" also.
    I still get the Check Engine code and my gas mileage dropped from 18-city, 21-highway(best recorded) to 15-city and 18-highway.
    It has been that way ever since I installed the headers.
    Any ideas?
  8. Mar 13, 2016 at 12:16 AM
    #68
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    What is the specific code number?
    Have you visually inspected around the flanges for soot deposits? That would mean either your hardware is loose or your gaskets are bad.
    Did you make sure to have the o2 sim properly installed? One plug wire is long whie the other is shorter. The must be installed into the proper side or bank.
  9. Mar 13, 2016 at 7:23 AM
    #69
    Randolph
    Randolph Member
    Randolph
    Marietta, SC
    I didn't write the code down. I will get it read again tomorrow and post back.
    There are no leaks anywhere.
    Since it has been several months, I don't remember where the long and short wires are. I can inspect and find out.
    Which is the proper side for the long wire?
  10. Mar 13, 2016 at 9:24 AM
    #70
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Don't quote me, as I only remember that they are length dependant. I think the long is on the driver side. You should contact URD and verify to be certain.
  11. Mar 13, 2016 at 8:18 PM
    #71
    Randolph
    Randolph Member
    Randolph
    Marietta, SC
    Thanks. I have contacted them. Waiting for reply. They answered my first question overnight.
  12. Mar 14, 2016 at 5:17 AM
    #72
    glorifiedwelder
    glorifiedwelder IG= @Liquid_Torch
    jason
    Santa Clarita, ca
    double cab trd sport
    Is the code p0158? That's the code I've been getting since I installed my Urd o2 sim
  13. Mar 14, 2016 at 12:00 PM
    #73
    Randolph
    Randolph Member
    Randolph
    Marietta, SC
    I don't have the code yet. I just today had time to disconnect the battery cable for 15 minutes as URD suggested. I will get the code read when it comes back (as I assume it will again).
  14. Mar 20, 2016 at 8:42 PM
    #74
    alphabravo
    alphabravo Well-Known Member
    Christopher
    Canada via FL
    2003 Tacoma TRD
    Supercharger AntiDark Hood Light Redline Tuning Hood Struts Morimoto Projectors Grey Wire Mod Tundra 13WL Brake Conversion EBC ED Pads and GD Rotors Mean Green Starter DC Power 250A Alternator Odyssey PC2150 Battery, Artec Cage ADS shocks Total Chaos UCA ComeUp Winch, Factor 55 Splicer Relentless bumpers OTRATTW Switches, Bussman 15304-2-2-4 RTMR, Paranoid Fabrication switch brackets Jensen JHD3630BT Morimoto XB LED Fogs Deaver Custom Springs Ivan Stewart TRD Wheels, Pro Series TRD Wheels
    I was looking for a sound clip. Did I miss it somewhere?
  15. Aug 11, 2016 at 1:19 PM
    #75
    zkdawg
    zkdawg Greenville Taco
    zach
    Mauldin, Sc
    06 DCLB TRD Sport
    Fog light mod, JBA LT headers, drop-in k&n filter, energy bushings, tried fold topper, 2nd air filter removed, all new stereo system minus subs, plastisol the wheels.
    Bump
  16. Dec 29, 2018 at 3:02 PM
    #76
    Difflockdave
    Difflockdave New Member
    Will
    2005 tacoma v6 manual 2wd
    Wheels off of a third gen
    Just got my jba long tube headers in and they came with the 02 bung plungs
  17. Jan 16, 2019 at 10:09 AM
    #77
    JLink
    JLink Well-Known Member
    Josh
    Ocean, NJ
    Lifted, Locked, Armored. Ready To Wheel.
    Any updates on the check engine light issue?
  18. Jan 27, 2019 at 12:42 PM
    #78
    rmepilot
    rmepilot Well-Known Member
    Rob
    Huntsville, AL
    '23 LR DCSB TRD OR 4x4 Premium Pkg
    2019 Jeep GC Summit 5.7l '15 DCLB S/C 4x4 Limited Pyrite Mica - Deceased
    What year is your truck?
    I think it’s only 2015’s that have issues with the sims.
    EDIT: disregard, I looked it up in your build thread.
  19. Mar 29, 2019 at 9:24 AM
    #79
    Cruzordie
    Cruzordie Member
    2015 black Tacoma 4.0 liter
    Does anybody ever run JBA shorty headers, I like the whole idea of long tubes but the headache of throw lights and codes seems a little much and also annoying. I currently have a K&N 57 series C.A.I. with the URD M.A.F. recalibrator sensor, URD Y-PIPE, and a Flowmaster super 44 3" cat-back system. Any info on anybody running shortys with a similar setup please let me know, have a good one yall.
  20. Mar 29, 2019 at 9:33 AM
    #80
    rmepilot
    Rob
    Huntsville, AL
    I’m running URD headers with zero issues.
