JBA Offroad Upper Control Arms And Suspension MEGA Thread BS thread
Discussion in 'Suspension' started by tcBob, Feb 24, 2015.
  1. Jul 21, 2015 at 3:56 PM
    #181
    Anzy
    Anzy Well-Known Member
    Eric
    Pennsylvania
    So did the alignment problem get figured out? I really need uca, as I just had 887's installed. It aligned ok, but I want to get these control arms.
  2. Jul 21, 2015 at 5:00 PM
    #182
    M192
    M192 Well-Known Member
    Dan
    Cambria county PA
    06 Tacoma trd sport, 88 4runner
    Alot
    I really like mine. My numbers aren't ideal though. But like I said that's because for my bolts being locked up
  3. Jul 21, 2015 at 7:15 PM
    #183
    Anzy
    Eric
    Pennsylvania
    Thanks for the heads up!
  4. Jul 21, 2015 at 8:13 PM
    #184
    M192
    Dan
    Cambria county PA
    Alot
    I love mine. But I don't thank they are adjustable I think they add more caster? Don't quote me on that though.
  5. Jul 22, 2015 at 5:52 AM
    #185
    M192
    Dan
    Cambria county PA
    Alot
    Ok. Didn't know that. I was thinking adjustable like the LR ones.
  6. Jul 22, 2015 at 6:03 AM
    #186
    TacoBurrito07
    TacoBurrito07 Well-Known Member
    Jake
    Arizona
    07 SWB Dbl cab TRD Sport 4x4
    The camburgs do get your truck back into alignment. As seen here:
    "These arms also correct the suspension geometry on lifted vehicles by increasing much needed caster which improves handling and allows for a wider range of alignment adjustment."
  7. Jul 22, 2015 at 6:33 AM
    #187
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Wuut? UCAs dont have to be adjustable to correct low caster. LR is the only brand I can think of that offers adjustable UCAs (there may be others). All the others are built in a manner that by adding them you gain a predetermined amout of caster. You then use the truck's caster adjustments to dial in what you want.
  8. Jul 22, 2015 at 7:44 AM
    #188
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Please don't state that the JBA's are adjustable. You'll only cause confusion. There is nothing to adjust--product is fixed at fab time. When they were built at the fab, the +2* of castor should have been built into arm.
    DoorDing likes this.
  9. Jul 22, 2015 at 7:48 AM
    #189
    Goosed
    Goosed Well-Known Member
    07 DC TRDOR
    None
    I'll correct then.
  10. Jul 22, 2015 at 8:03 AM
    #190
    Crom
    Nick
    San Diego, CA
    Millions
    Thank you.
  11. Jul 23, 2015 at 7:49 PM
    #191
    Goosed
    07 DC TRDOR
    None
    Any updates Crom?
  12. Jul 23, 2015 at 8:31 PM
    #192
    Crom
    Nick
    San Diego, CA
    Millions
    I was reassured yesterday that he's actively investigating the alignment issue. I'm going to be patient and wait. Meanwhile I can tell you that the HD arms are fantastic off road with my OME suspension. Truck was carrying 1,150 lbs. I wheeled in Inyo Natl forest, and truck did great! Full range of motion compression / flex.
    EODwick likes this.
  13. Jul 30, 2015 at 11:48 AM
    #193
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    I'm interested to see what the alignment numbers come out to with the new arms. I want to order a set in the next few weeks but want to wait and see if they got the bugs worked out yet.
  14. Jul 30, 2015 at 1:34 PM
    #194
    White Bear
    White Bear Well-Known Member
    Louisiana
    Probably have the only 2nd Gen with an 8274 in the world.
    So is it only the updated HD's or is it both versions of the updated arms that are low on caster? I've got the updated regulars and I have not gotten my truck aligned as I'm making a decision on tires at this time, and am still needing to add a leaf or two to the rears. I appreciate it.
  15. Jul 30, 2015 at 3:19 PM
    #195
    White Bear
    Louisiana
    Thanks man. I need to get off my butt and get it aligned.
  16. Aug 1, 2015 at 6:37 AM
    #196
    Crom
    Nick
    San Diego, CA
    Millions
    I sure hope so. Don't know who is going to do your alignment, but it's wise to explain to the tech that your looking for stock alignment values and not to assume that with your lift it can't get there. Specifically, tell them to get camber into spec, and then adjust for as much castor as possible.
    I really liked how my truck drove with 2.2-2.4* castor.
    I'm hoping for good news.
  17. Aug 1, 2015 at 6:58 AM
    #197
    Crom
    Nick
    San Diego, CA
    Millions
    That sounds good. 0,0,2 would be good for you then. They should be able to tell if there is room to go higher on castor but still torque it down at 2.0* for you.
    Blackout14 likes this.
  18. Aug 2, 2015 at 10:43 AM
    #198
    Big Tea
    Big Tea WOOOOOOO!!!
    Chesterfield, VA
    08 TRD Sport DCSB 4x4
    I just got finished installing the regular JBA UCAs (i.e., not the HD ones). They are the updated ones (think they're called version 7.0.10). Install took about 3 hours which also included installing wheeler's 3/8" top plate spacers, so uca install was probably a little over 2 hours.
    I know the biggest issue with these (aside from the current caster mystery) was the clearance on the top spring perch. I can assure you that these definitely clear the perch as I cycled them up and down prior to tightening everything up just to make sure. Eyeballing it looked to be about 1/2-3/4" clearance around the perch.
    I've got an OME lift with 885's in the front and was using original UCAs. Alignment was ok, but like others have stated with a similar setup, it felt twitchy. Immediately after installing the JBA UCAs I felt little to no twitchiness and it seemed to resembled how the truck handled prior to the OME lift install.
    I will be getting an alignment this week and will post those results once I do. Keeping my fingers crossed I can get within the 0/0/2 to 0/0/2.5 target zones.
    EODwick, Blackout14 and Crom like this.
  19. Aug 5, 2015 at 6:11 PM
    #199
    loosnut
    loosnut Well-Known Member
    jerry
    feasterville pa
    06 dbl cab long bed
    ome 2.5lift leer cap
    ill pick u up and take u to work.FRIENDS DONT LET FRIENDS DRIVE jeeps
    Bastek and Blackout14 like this.
  20. Aug 6, 2015 at 6:32 AM
    #200
    Crom
    Nick
    San Diego, CA
    Millions
    Not sure... Is Marlin doing your alignment or in an independent shop?
    On the values, You want: 0 camber, 2-2.5 castor, 0 toe. :D
