JBA Offroad Upper Control Arms And Suspension MEGA Thread BS thread
Discussion in 'Suspension' started by tcBob, Feb 24, 2015.
  1. Apr 3, 2019 at 6:12 AM
    #3021
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    I'm not sure, I know the set that is on my truck currently has the OEM Bushings, not sure if the set I have new in the box.
  2. Apr 3, 2019 at 6:36 AM
    #3022
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    OP was wondering if you new for sure if these are still running the OEM Toyota bushings ?
  3. Apr 3, 2019 at 6:39 AM
    #3023
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    My new ones in the box have zerks where the bushings are, and the ones in my truck so not. But they are both OEM Bushings.
  4. Apr 3, 2019 at 7:30 AM
    #3024
    Sterdog
    Sterdog Offline
    I am Groot
    People's Democratic Republic of Canuckistan
    15 FoST
    I bought my JBA arms last year and they have never squeaked. If UCA's, even my old uniball allpro arms, are properly maintained and greased they wont squeak. If the JBA arms are squeaking they were either incorrectly installed, they were not properly greased during install, and/or they have not been regularly greased.
    Even the SPC and OEM arms will squeak if they are not properly greased before installing.
    Blackout14 likes this.
  5. Apr 3, 2019 at 7:33 AM
    #3025
    Matmo215
    Matmo215 Well-Known Member
    Matthew
    Waco, TX
    2015 Sport DCSB
    I second this, mine have never squeaked nor have I had any issues whatsoever since installed
  6. Apr 3, 2019 at 9:26 AM
    #3026
    tacoma guy
    Joe
    Phoenix Az.
    Sounds good. Thank you
  7. Apr 3, 2019 at 9:32 AM
    #3027
    tacoma guy
    Joe
    Phoenix Az.
    That is all very good news . Theses are my next purchase . Thanks a bunch for the replys guys !
  8. Apr 5, 2019 at 9:05 AM
    #3028
    JARStacoma
    JARStacoma Well-Known Member
    Alaska
    17' inferno TRD OR MT
    Just ordered a pair of these and am planning on the install. I have read both cutting the bolt and bending the fender. Anyone have pros and cons for both? Fairly new truck and am not totally sold on bending flimsy metal. I will also be attempting solo any tricks for that? Thanks for all the help.
  9. Apr 5, 2019 at 9:47 AM
    #3029
    BlakeyD
    BlakeyD Well-Known Member
    Blake
    CA
    2012 Tacoma TRD Off Road "Tyra"
    I bent mine, bent it back and the inner liner flap covers it. It is a 2nd gen though, not sure if the same would apply to a 3rd.
  10. Apr 5, 2019 at 10:24 AM
    #3030
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Bending it is pretty darn easy. Get the sheet metal vice grips I linked that are in the bottom under “products discussed”. That, a second person and some patience is all you need. And a pry bar.
  11. Apr 5, 2019 at 10:56 AM
    #3031
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    Ordered mine last week! Got tired of the squeaks on the Total Chaos UCAS regardless how many times I properly lube them with the PFTE lube they recommended....:bananadead:
  12. Apr 5, 2019 at 4:41 PM
    #3032
    Lord Helmet
    Nick
    '24 X3 M40i
    The 4Runner TC UCAs hasn't squeaked just yet.....:fingerscrossed: Only on the Tacoma :annoyed:
  13. Apr 6, 2019 at 9:07 AM
    #3033
    jross20
    jross20 Well-Known Member
    Georgia
    2000 4Runner SR5 4x4 | V6 | Auto
    Tundra 5100s F+R, OME 880s+890s, duro bumps, etc
    Ordered the JBA high caster arms... hoping to GOD they will go fine with 884 springs... Sick of having 4.0+ degrees of caster :bananadead:
  14. Apr 6, 2019 at 2:13 PM
    #3034
    tacoma guy
    Joe
    Phoenix Az.
    A second person and pry bar ? Are these that big of a PITA to install? :confused: was thinking of doing it myself but now I'm wondering if I should get a friend to help.
  15. Apr 6, 2019 at 2:23 PM
    #3035
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Prybar is for spreading the uca a little bit to get that inner washer in. Second person is nice for tapping the bolt in from the engine bay, while a second person guides it through the uca. On a second gen it’s easier. I did it alone.
  16. Apr 6, 2019 at 3:06 PM
    #3036
    tacoma guy
    Joe
    Phoenix Az.
    Oh OK yeah I see what your saying . Thanks bud I appreciate any idias I can get ! I want to install the Toca lean spacer at the same time.
    EatSleepTacos[QUOTED] likes this.
  17. Apr 6, 2019 at 4:20 PM
    #3037
    JARStacoma
    Alaska
    I will be doing this on my own as well. Don’t have a lot of options. I will also be swapping out some coils using the floor jack method. I guess I will switch out UCA then separate lower a arm to decompress coil. Seems like a two step process sense I don’t have an assembled coilover.
  18. Apr 6, 2019 at 6:16 PM
    #3038
    tacoma guy
    Joe
    Phoenix Az.
    Sounds like you have some work ahead of you. Keep me posted on any tips of how you get the arems in on your own . Good luck. ;)
  19. Apr 6, 2019 at 6:26 PM
    #3039
    JARStacoma
    Alaska
    Yah. I installed the lift about a month ago and decided I wanted taller coils and uca’s. Probably a few weeks out on attempt. We shall see.
  20. Apr 7, 2019 at 2:49 AM
    #3040
    Dirtridercrf250
    Dirtridercrf250 Well-Known Member
    Did mine solo yesterday. I found that folding the fender metal back helps a ton on the upper bolt. I used a ratchet strap to hold the spindle in place. Next was holding the arm with one hand. Slid the thick washer on the bolt and jammed it in between the body and ac line. Took a screw drive and wedged it in the bushing and pried out to get the bin washer line up and pushed the bolt thru the Bush and first thin washer. Same for the next yhin washer just pry on the Bush with out causing damage just enough to get the washer stuck in between the mount and bushing then you can just squeeze it till it lines up.
