JBA Offroad Upper Control Arms And Suspension MEGA Thread BS thread
Discussion in 'Suspension' started by tcBob, Feb 24, 2015.
  1. Jan 5, 2020 at 10:55 AM
    #3421
    FastEddy59
    FastEddy59 TTC #0061
    Eddie
    '13 Barc. Red Tacoma SR5 4X4
    It's a sneaky wild oat, I must say. :rofl:
    Shwankin407 likes this.
  2. Jan 8, 2020 at 9:54 AM
    #3422
    outxider
    outxider Never stop exploring. Rest in Paradise Big Bro.
    Sang
    East Bay, CA
    06 DCSB 4x4
    A few mods here and there and counting....
    Anyone here running here running these arms STD version with 16x8 ETA 0/4.5 offset/ wheels and 285/75R16? Want to know if there is sufficient clearance between the tire and uca before i replace the tires. Currently running 265/75R16s.
  3. Jan 9, 2020 at 7:12 AM
    #3423
    Duffman76
    Duffman76 Member
    Since you are running 16x8 could be ok. Could always give them a call. From the JBA website:
    Please Note: 32.7" and larger diameter tires need aftermarket wheels with less then factory wheel back space.
    • LT285/70R17 (32.7" x 11.2") tire on 17 x 9 wheel, -12mm offset (4.50" backspace)
    • LT285/70R17 (32.7" x 11.2") tire on 17 x 8.5 wheel, -9mm offset (4.30" backspace)
    • LT285/70R17 (32.7" x 11.2") tire on 17 x 8.5 wheel, 0mm offset (4.75" backspace)
    • LT285/75R16 (32.8" x 11") tire on 16 x 9 wheel, -19mm offset (4.25" backspace)
    • LT255/85R16 (33.10" x 10") tire on 16 x 8 wheel, -12mm offset (4" backspace)
    • LT315/70R17 (34.4" x 12.4") tire on 17 x 9 wheel, -25mm offset (4.00" backspace)
  4. Jan 19, 2020 at 6:46 PM
    #3424
    nat5nat11
    nat5nat11 Well-Known Member
    Colorado
    2004 Tacoma Xtracab
    I'm having trouble pressing the ball joint adapters into the spindle. I'm using a pitman arm puller like I used to remove the original ball joints, but I can't get it to stay straight as I press. Any ideas?
    tonyclifton likes this.
  5. Jan 19, 2020 at 6:52 PM
    #3425
    taco03Trd
    taco03Trd 03 rig trd v6
    Carlos
    Riverside ca
    03 DC prerunner trd v6 2wd
    Ome 881 5100's jba's looking for more
    Did my with help from @whatstcp u need extra hands to hold the adopter in place with a balljoint tool and impact we got it to going straight but wasn't easy ..
    whatstcp likes this.
  6. Jan 22, 2020 at 9:31 AM
    #3426
    Pilsner
    Pilsner Well-Known Member
    18 TRDOR
    255/85r16 ST Maxx 6112/5160 w/ Dakar RCI armor, sliders, and rear bumper CBI hidden winch mount w/ Smity 20k
    Anyone know if stock OR wheels with 255s will clear? I would rather not run a spacer if I don't have to. Lift parts on the way - 6112s up front. Trying to decide on UCAs currently. I don't want to buy wheels right now.
  7. Jan 22, 2020 at 3:42 PM
    #3427
    rdpoe
    rdpoe #2WDFTW
    Central Kentucky
    2019 TRD OR DCLB (Sold), Honda Civic TRD PRO
    Per JBAs instructions you do need spacers or wheels with correct offset to clear the UCAs with 255s.
    My comment that you quoted was in response to someone asking about a totally different size tire.
  8. Jan 23, 2020 at 7:09 AM
    #3428
    Pilsner
    18 TRDOR
    I know, I was hoping you or someone else had tried them without spacers. It looks like a lot of clearance right now with stock wheels and 255s and stock UCAs. I will probably buy a set of spacers to have on hand when I do mine. If they hit, I will toss them on until I go to new wheels with 285s. Too many things to buy.
  9. Jan 23, 2020 at 7:55 AM
    #3429
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
    2021 TRD Poser Pro Manual.
    I have 255's on my 16 inch TRD BEADLOCK Wheels with no issues
    rain76king likes this.
  10. Jan 23, 2020 at 10:37 AM
    #3430
    Pilsner
    18 TRDOR
    Do you know what the backspacing is on those?
  11. Jan 23, 2020 at 11:17 AM
    #3431
    Unchained 5150
    Unchained 5150 Rick
    Rick
    Auburn Ma
  12. Jan 23, 2020 at 11:54 AM
    #3432
    rdpoe
    rdpoe #2WDFTW
    Central Kentucky
    I gotcha. Looping in @Jibbs because he helped JBA determine some of these specs through trial and error.
  13. Jan 23, 2020 at 6:06 PM
    #3433
    Jibbs
    Jibbs "When in doubt, throttle out!"
    Josh
    Cincinnati
    2017 SCREW Raptor Lightning Blue
    Whoooooooshchchch
    You will need spacers to clear 255s. JBAs stick out way farther than oem arms.
  14. Jan 24, 2020 at 12:18 PM
    #3434
    Snaeper
    Snaeper Drinks like an 8, Drives like a 3
    Martin
    Phoenix, AZ
    2019 Quicksand SX 2.7 4x4 1990 Toyota Celica ST
    SnugTop Rebel, Infinity Kappa's, ToughDog 40mm
    Question:
    Would the JBA's be overkill with a 1.5-2" lift? I noticed it says theyre optimized for 2-4". I'm looking at 6112's and while the lift maxes out at 1.65" for my particular truck, I get an extra inch of travel if I go with an aftermarket UCA. The JBA's are "right-priced" for my minimal demands.
  15. Feb 1, 2020 at 3:11 PM
    #3435
    Schonher16
    Schonher16 Well-Known Member
    Gillett PA
    2014 TRD Off Road Spruce Mica
    ARMOR: Mobtown Offroad front bumper SUSPENSION: 3 inch OME and Dakars JBA Off-road UCAs LIGHTS: Cali Raised 3x2 pods
    So in a post a while back on here someone said there was a recall for rusty ball joints and such. I bought mine back in February of 2018 before the recall, just failed inspection this year for too much play in upper ball joints. Messaged JBA hopefully hear something back from them.
  16. Feb 10, 2020 at 1:24 PM
    #3436
    msgs350
    msgs350 Well-Known Member
    PNW
    2020 Tacoma OR Cement DCSB 4x4 AT
    Some Mods
    Any update?
  17. Feb 13, 2020 at 8:49 AM
    #3437
    TacomaLover
    TacomaLover Well-Known Member
    Preston
    Tennessee
    1995 Tacoma
    any discount codes?
  18. Feb 13, 2020 at 9:56 AM
    #3438
    rdpoe
    rdpoe #2WDFTW
    Central Kentucky
    Only way to get a discount is as military. He doesn't run sales/discounts. The pieces are priced right anyway
    SR-71A likes this.
  19. Feb 14, 2020 at 8:34 AM
    #3439
    dr4g1116
    dr4g1116 Well-Known Member
    2019 Silver Sky Metallic TRD OR SB M/T
    Had JBAs on my Liberty and they were nice. My only complaint that I had was the powder coating kind of sucked. Had them for about 3 years and they started flaking around the BJ
  20. Feb 15, 2020 at 3:42 AM
    #3440
    Schonher16
    Gillett PA
    Talked to Marlin he sent some new ones out gotta ship back the old ones. Marlin says there ball joints don’t fail. But both mine had a ton of play.
    Also installed the new ones and the passenger side is a good tight fit with the boot, washer and the knuckle but the driver side has a gap between the boot and washer can’t get it to go further on either, which worries me..
