JBA Offroad Upper Control Arms And Suspension MEGA Thread BS thread
Discussion in 'Suspension' started by tcBob, Feb 24, 2015.
  1. Dec 15, 2020 at 1:05 PM
    #3761
    tacocart762
    tacocart762 Well-Known Member
    desert55gr
    Santa Clarita Valley
    2017 Tacoma TRD Offroad Dbl Cab Long Box
    1.5in Bilstein 6112 Front,1in Alcan Leaf Rear with Bill 5100's. Battle Armor side step,bull bar, and rear step.
    Ya the local shop I go to got mine to 4.5 on the caster. The truck tracks so straight now and no more bump steer. I thought the wheel might be a bit hard to turn but it just feels solid now. Very happy with my JBA's.
  2. Dec 16, 2020 at 3:48 AM
    #3762
    Texoma
    Texoma IG: Triple C Chop Shop
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    A bunch a cool stickers, a bada ass MetalMiller Tx Longhorns grill emblem painted Hemi Orange, JBA long tube headers with o2 sims, Diff breather mod, Red LED interior lights, Fancy head unit that plays ipod n movies, Also DIY install factory stuff like, factory cruise control, factory intermittent wipers, OME nitro struts with 886x springs and toy tec top plate, JBA high caster UCA's for better alignmnet and dey beefier too, Old Man Emu Dakar leaf springs in da rear with the gear, U bolt flipper, Ivan Stewart TRD rims with 33" K Bro 2's, some bad ass weather tech floor liners so I don't muck up my interior, an ATO shackle flipper for mo travel in da rear wit the gear, also super shiny Fox 2.0 shocks back there too, all sorts of steal armor for bouncing off of the rocks like demello sliders, AP front skid, trans skid, n transfer skid, demello gas tank skid, and a tough as nails ARB bumper with warn 8k winch, I'm sure there's more
    Power steering makes up for that. You can barely feel a difference between 2.5* and 4.5*
    tacocart762[QUOTED] likes this.
  3. Dec 17, 2020 at 9:42 AM
    #3763
    tacocart762
    desert55gr
    yup that is true
  4. Dec 19, 2020 at 1:33 PM
    #3764
    lo2hi
    lo2hi Well-Known Member
    Chiro
    Portland, Oregon
    2006 Impulse Red Tacoma 4.0L 6-Speed 4WD
    265/75R16 Falken Wildpeaks AT3W & KMC Enduros AFE air intake Bilstein 5100 & Eibach Springs & Ironman4x4 performance leaf Magnaflow 12866 muffler
    Does caster bring the tire forward? I have JBA UCA with the high caster and after alignment now rubbing. It was completely fine before the alignment :mad:
    Can barely go into the driveway without rubbing, and pretty scary when driving. I told the person 3-4 caster, 0 camber, 0 toe. They decreased caster to around 2.28 on each side, bringing it down from the 3/4 the left and right were at. I cant believe shops let vehicles out like this after their work. Taking it back to the shop but :annoyed:
    obligatory install pic
  5. Dec 19, 2020 at 3:44 PM
    #3765
    hwntaco20
    hwntaco20 Well-Known Member
    2020 Tacoma TRD Offroad 2wd
    Higher caster pushes the wheel forward in the well away from the cab side. Your wheel /tire combo can contribute to rubbing. What are u running?
    lo2hi[QUOTED] likes this.
  6. Dec 19, 2020 at 3:53 PM
    #3766
    BroID
    BroID Well-Known Member
    The Gem State
    2017 Tacoma TRD off road
    BFG KM2 255/85r16 Bilstein 5100s OME 888, HD Dakar’s, JBA control arms, BAMF Shackle hangers and shackle.
    JBA High caster control arms will actually pull the tire towards the cab. They have caster built in that you can’t adjust. You can adjust the caster at the lower control arm which is what probably needs to be adjusted. I rubbed with 265/75r16 tires initially. The deal though was that my shop ignored me and did not do the alignment correctly. Once they pushed it to 3 degrees it went away. You need to make sure that the shop sets the caster correctly on the lower control arm. I’m not going to say what it is but I believe you get a document about alignment from JBA
    whatstcp and lo2hi[QUOTED] like this.
  7. Dec 19, 2020 at 11:25 PM
    #3767
    lo2hi
    Chiro
    Portland, Oregon
    285/75 r16. Going to have them put caster back to 3-4. basically what the form said, but they didnt listen.
  8. Dec 20, 2020 at 6:18 AM
    #3768
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Sweet spot is 3.8* castor.
  9. Dec 22, 2020 at 8:24 AM
    #3769
    lo2hi
    Chiro
    Portland, Oregon
    This shop couldn't get it right the first time. The guy behind the cashier told me they can't adjust caster with the LCA.
    Even though they took it from 4 to 2 the first time I was there. OK, just told them fix it so it doesn't rub. I dont have much faith in this shop going to the next one after for better alignment.
  10. Dec 22, 2020 at 8:40 AM
    #3770
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    They may have gotten the cams upside down. In that case, no, they wouldn't have been able to make any further adjustment. The pointers on the cams have to be in the northern hemisphere. Meaning, the pointer can point all the way right or left, but never down. Another way to explain is they can point in either the 9 o'clock or 3 o'clock position, but never below those positions. Hope that makes sense.
    trippen1999 and lo2hi[QUOTED] like this.
  11. Dec 22, 2020 at 8:41 AM
    #3771
    lo2hi
    Chiro
    Portland, Oregon
    Thanks, I'll check it out after I get it back from the shop!
  12. Dec 23, 2020 at 7:49 PM
    #3772
    sentientprogram
    sentientprogram Well-Known Member
    Do these upper control arms ever go on sale?
  13. Dec 23, 2020 at 7:49 PM
    #3773
    CowboyTaco
    CowboyTaco $20 is $20
    North Georgia
    11 TRD Sport
    Not that I've seen.
  14. Dec 24, 2020 at 3:29 AM
    #3774
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Their always on sale.
    whatstcp, bmxtaco and lo2hi like this.
  15. Dec 24, 2020 at 8:21 AM
    #3775
    lo2hi
    Chiro
    Portland, Oregon
    $480.71 out the door with JBA STD UCA. It's not so bad. I think they do military discounts if you ask.
    JacksonTacoma likes this.
  16. Dec 31, 2020 at 9:47 PM
    #3776
    Tadpole
    Tadpole Member
    Terry
    I’m putting on a 3” lift and 285/70/17 which arms do I need to buy?
  17. Dec 31, 2020 at 10:08 PM
    #3777
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
  18. Jan 4, 2021 at 2:33 PM
    #3778
    tacoma guy
    tacoma guy Well-Known Member
    Joe
    Phoenix Az.
    2011 Tacoma Prerunner TRD
    Bilstein 5100's on all four corners. Front set @ 0 with OME 883x coils. Alcon leaf springs. Viper Alarm. Wet Okole seat covers. WeatherTech Floor liners front and back. Oem Toyota chrome exhaust tip. ARE Shell. America Outlaw Wheels.
    Hey guys. OK so if I am only lifting my 2nd Gen 2 to 2 1/4 " what should my settings be set at with the high cast UCA?
  19. Jan 4, 2021 at 5:00 PM
    #3779
    Texoma
    Chris(Topher)
    Lago Vista, TX
    10 Taco 4x4
    Same as any other.
    1. Castor to 3.5* +/- 0.5* (more is better, 3.8* is ideal)
    2. Camber and Toe must be to factory spec as close to Zero as possible.
    3. Torque alignment cam nuts/bolts to 130ft#'s
    hyrule_trd likes this.
  20. Jan 4, 2021 at 6:39 PM
    #3780
    tacoma guy
    Joe
    Phoenix Az.
    Perfect Thank you sir much appreciated!!
    Texoma[QUOTED] likes this.
