JBA Offroad Upper Control Arms And Suspension MEGA Thread BS thread
Discussion in 'Suspension' started by tcBob, Feb 24, 2015.
  1. Aug 24, 2023 at 6:06 PM
    #4041
    98tacojunky
    98tacojunky Well-Known Member
    Upstate NY
    2019 TRDOR double cab
    Jba’s offer an easy replacement by simply bolting on a new ball joint as opposed to having to press one in. The downside is you can only purchase them through JBA. Dobinsons uses a 555 ball joint which I believe is available at most auto parts stores. Dirt king may use an easy obtainable ball joint but I can’t recall for sure. Billsteins UCA is made by dirt king as well.
  2. Aug 24, 2023 at 6:10 PM
    #4042
    PNW15
    PNW15 Well-Known Member
    2015 Tacoma DC LB SR5
    Fantastic info on ball joints. Altho I thought you could buy those JBA ones anywhere as they're technically a stock part for other rigs? What about bushings? I also don't want to be replacing or finicking with those! Not opposed to zerks on bushings, as I will lube every 5k, but I really don't wanna have to replace bushings and prefer OEM.
  3. Aug 24, 2023 at 6:46 PM
    #4043
    98tacojunky
    Upstate NY
    From my understanding the jba ball joints are designed after a specific gm 2500 ball joint. I do believe you can replace them with that. But they are different. The jba ball joints are manufactured in house to achieve specific performance benefits. The only way to retain that is to use jba ball joints only. Plus I imagine if you swap to anything not jba you probably void the warranty but I can’t say that for sure. Jba uses special poly type bushings. They work well but anything can wear out. I can’t recall which brand it is but someone uses OE style bushings which should last a while. I don’t see many people complaining about bushing issues with jba. Spc is having a ton of issues at the moment between bushings and ball joints.
  4. Oct 16, 2023 at 5:54 AM
    #4044
    Tacoma13_NC
    Tacoma13_NC Well-Known Member
    2013 SR5 4x4 DCSB 4.0L (Black) OTT
    Bilstein 6112/5160; JBA HD UCAs; 1.5" 3-Leaf AAL's w/ overload; OME CB drop; RCI aluminum skids w/ catalytic converter shields; Wheeler's U-Bolt flip kit with Superbumps; TRD Pro 4-Runner Wheels; Falken Wildpeak AT4W (265/70/17); Diode Dynamics SS3 Sport (Yellow) fogs; CaliRaised 32" hidden light bar; Morimoto XB LED headlights with upgraded HD harness; Unifilter mod; Rear-View mirror riser bracket; Truxedo Lo Pro tonneau cover; New OEM color-matched grille; Bumpershellz color-matched rear bumper cover; Ultra-Gauge MX 1.4 w/Spiker mount; Baja Designs S2 Sport Ditch Lights with SDHQ brackets; Fog Light Anytime Mod; Overland Tailor Tune (OTT); Yaesu FTM-150 GMRS/Ham radio; Viofo A229+ Dash Cam
    I don't see why people will opt to buy a cheaper ball joint replacement to save a few dollars after spending hundreds for the UCA to begin with. Just buy an extra ball joint from JBA and keep it in the truck somewhere as a backup. Problem solved.
    notlefty likes this.
  5. Nov 6, 2023 at 4:37 PM
    #4045
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
  6. Nov 15, 2023 at 12:46 PM
    #4046
    Tenmile Tacoma
    Tenmile Tacoma IG: tenmile_tacoma
    Nate
    Colorado
    2016 DCLB TRD Sport 4x4
    F&R locked on 33s
    Got around to installing my new JBA HD upper control arms and some new OEM tie rod ends this past weekend. I replaced my SPC upper control arms with these JBAs since the SPCs developed play in the bushings at around 20,000 miles, which is ridiculous in my opinion. Did a lot of research when deciding on these new upper control arms, including reading through this thread, so figured I'd post my experience w/ JBA here as well.
    The new JBAs are awesome - I really like their design w/ the greaseable & replaceable bushings and ball joints. I'm excited to test them out.
    The installation was straightforward since I had already installed control arms before, but the driver's side was a PAIN to get the inner washers between the control arm bushing and the shock tower bolt path. I think that the gap b/w the two control arm mount points was slightly off with the driver's side arm and therefore made getting those inner washers in very difficult. I had to use a pry bar to open it up and tap the washer in. Passenger side was a breeze to install. Overall really happy with my purchase thus far, but I still need to get some miles on them!
    [​IMG][​IMG]
  7. Nov 15, 2023 at 12:56 PM
    #4047
    Tacoma13_NC
    Nice!! I love mine. My alignment is perfect and everything just feels good. My next step is to replace the 5100s/885 coils with 6112s.
  8. Nov 15, 2023 at 1:18 PM
    #4048
    Tenmile Tacoma
    Nate
    Colorado
    F&R locked on 33s
    That's awesome man! Happy to hear you're loving their product too! How many miles you got on your JBAs? About to pick my truck up from the alignment shop this evening. Can't wait to hit some trails!
    Edit: Also, that's cool you're planning to upgrade from 5100 to 6112s. To be honest, I don't know that I would spend the money to upgrade to the 6112s unless your 5100s are shot. I think having the extra diameter is "nice" but I haven't noticed any difference in performance between the 5100s and the 6112s (ran 5100s on my 2nd gen taco and am running the 6112s on my third gen). If I were you, I would consider saving up and doing some kind of mid travel setup. My next big upgrade will be the Bilstein 8100 series. Here is a helpful link about mid travel and how the Bilstein 8100s are one of the leading options. Do some Youtube searches for "Bilstein 8100 testing" and watch them. They are incredible shocks.
    Tacoma13_NC[QUOTED] likes this.
  9. Nov 15, 2023 at 7:11 PM
    #4049
    Tacoma13_NC
    Mine have only been on for a couple weeks now, so not many miles at all. Thanks for the suggestion about the 8100s, but I really don't have a need to upgrade that much for what I do. From what I've read, the 6112s have a little bit smoother ride than the 5100s due to the better dampening effect, and that they pair well with the 5160s which is what I have in the rear. My shocks are still in good shape and could probably sell them and the coils used.
  10. Dec 20, 2023 at 10:00 PM
    #4050
    JBDLB
    JBDLB Well-Known Member
    I’ve been thinking of doing a 3” lift.
    I was hoping to use some 5100 for that and a AAL in the rear. would this gain me three inches front and rear?not sure what springs to get for the front.
    From my research these JBA (non HD) seem to be the most cost effective UCA.
    Would you recommend this set up?
  11. Dec 21, 2023 at 10:24 AM
    #4051
    Hilborn
    Hilborn Adventure First. Safety Second.
    Michael
    Utah
    2009 Tacoma DCLB TRD Sport 4x4
    ADD W1 Oil Catch Can. AFE Magnum FORCE Stage-2 Si Cold Air Intake System. AlphaRex Black Pro-Series Headlights w/ LASFit Bulbs. Anderson Engineering Solutions Manifold Spacer. ARK Splash Guards. AVS Door Sill Protectors. BAMF Bolt-On Rock Sliders. BAMF CMC Plates. BedRug. Brute Force HC Rear Bumper. C4 Engine Skid. C4 Transmission Skid. C4 Transfer Case Skid. C4 Fuel Tank Skid. C4 Rear Diff Skid. Cooper Discoverer ST Maxx LT285/70R-17. Dirt King Ball Joint Upper Control Arms. Dirt King Lower Control Arms. Dirt King Spindle Gussets. Doug Thorley Y-Pipe. DRT Fabrication Shackle Hanger Kit. Eaton Detroit Trutrac Rear Differential. ECGS Bushing. Expedition Essentials Bedside ARB Air Compressor Mount. Garmin Overlander GPS. Genesis Gen 3 Dual Battery System w/ G Screen. HCF Delete. Husky Floor Liners. Hypertech In-Line Speedometer Calibrator (@1.038). IGGY Switch Panel. Ironman4x4 Foam Cell Pro Struts and Shocks. KPOffroad Alignment Cam Upgrade Kit. Leer 100XQ. Magnaflow Overland Series Cat-Back Exhaust w/ 10416 Muffler. Method Vex Titanium 17x8.5. Yukon 4.56 Gears. Odyssey Performance Group 34 Batteries (2). OME 886x Coil Springs. OME Carrier Bearing Spacers. OME CS047R Dakar Leaf Springs w/ D29XL. Overland Torque Tune. Pakrax Tailgate Panel. Pinch Weld Mod. Pop n' Lock. Power Stop Z36 Truck and Tow Brake Pads. rcbs204 Illumited 4x4 Switch. Rear Differential Breather Relocation. Rexing V1 Dash Cam. Scanguage 2 w/ TFT. Stahlbus Oil Drain Plug. Stoptech Cryo-Treated Rotors. Sway Bar Delete. Total Chaos Bed Stiffeners. Toyota 70mm Throttle Body. ToyTec Axle Degree Shims. URD 170° Thermostat.* URD 65 to 70mm Throttle Body Adapter. URD Exhaust Cam Gears. USA Spec IPod Interface. Voltage Booster Pro. Wheeler's Brake Lines. Wheeler's Front SuperBumps with 3/8" Spacers. Wheeler's U-Bolt Flip Kit w/ SuperBumps.
    That's my current setup. I have OME 886x front springs. I have added weight and I still find them to be a little stiff.
  12. Dec 21, 2023 at 11:00 AM
    #4052
    JBDLB
    I don’t have a winch or bumper. I will one day. But lift first. What sprigs would you recommend. Do you get 3” of lift?
  13. Apr 10, 2024 at 9:43 PM
    #4053
    r3k
    r3k Well-Known Member
    will the jba clear the ironman FCP coilovers?
  14. Dec 10, 2024 at 11:10 AM
    #4054
    Coopsdaddy
    Coopsdaddy Well-Known Member
    Quinton
    2012 dclb tacoma
    6112/5160 Deaver stage 1 Are topper Steelies,255/80/17
    Do you Benefit at the 2.25-2.5 inch lift?
    It’s oem good enough?
  15. Dec 10, 2024 at 11:44 AM
    #4055
    Tacoma13_NC
    Definitely benefit. OEM is good enough that your tires probably won't wear unevenly but your steering will still suffer some. I'm only 2.25" and ai noticed a big difference after upgrading.
  16. Dec 10, 2024 at 12:35 PM
    #4056
    Coopsdaddy
    Quinton
    2012 dclb tacoma
    Whats the jba lifespans ,looking at a nice used set but they have 15000 miles.
  17. Dec 10, 2024 at 5:17 PM
    #4057
    hwntaco20
    hwntaco20 Well-Known Member
    2020 Tacoma TRD Offroad 2wd
    I have a 2020, installed Nov 2020,.I have 43,000. Just a cple squirts of grease at each oil chg and all is like brand new still! Zero complaints.
    Taco-Grinder and Tacoma13_NC like this.
  18. Dec 17, 2024 at 9:47 AM
    #4058
    Coopsdaddy
    Quinton
    2012 dclb tacoma
    Thats seems shady!
    Is the quality improved on these?not paying 600 bucks to have to repair in a few years.
  19. Dec 17, 2024 at 10:53 AM
    #4059
    TaCoHiOgUy
    TaCoHiOgUy Well-Known Member
    Eric
    2008 Regular Cab 4WD 5 Speed
    Eibach Pro Truck 2, 1.5" AAL, 255/85/16, JBA UCA
    I just had my truck aligned (Lifted 2.5 and stock UCA). Toe and Camber are set where they need to be but caster is only at 1 degree per side (It's like driving a shopping cart). If I put JBA's on will I have to have camber reset? I'm assuming toe will change but unsure if JBA's change camber at all.
    Tacoma13_NC likes this.
  20. Dec 17, 2024 at 2:22 PM
    #4060
    Tacoma13_NC
    JBAs give an extra 3* of caster which will make a huge difference in your drivability.
    TaCoHiOgUy[QUOTED] likes this.
