JBA Offroad Upper Control Arms And Suspension MEGA Thread BS thread
Discussion in 'Suspension' started by tcBob, Feb 24, 2015.
  1. Jan 20, 2017 at 2:24 PM
    #801
    2016 Tacoma SR
    2016 Tacoma SR Well-Known Member
    HOCO Maryland
    2016 MGM 4Runner SR5
    ToyTec Ultimate lift, FX Pro wheels, 295/70/17 Ridge Grapplers, AFE drop in filter.
    It's more than alignment spec. I have stock uppers for now however that'll change. Your ball joints are at a bad angle, ride quality could be better, bump steer corrected, it's not just for the alignment.
    Nginerd, TN_Tacoma and Blackout14 like this.
  2. Jan 20, 2017 at 2:33 PM
    #802
    Crom
    Crom Super-Deluxe Member
    Nick
    San Diego, CA
    2009 4x4 DCSB Camp Supreme
    Millions
    Did you actually pay for an alignment? By the looks of it, they didn't adjust anything!
    Nginerd and Blackout14 like this.
  3. Jan 20, 2017 at 2:43 PM
    #803
    2X4TACOMA
    2X4TACOMA Well-Known Member
    Pyrite Mica 2010 Tacoma 4x4 Off Road
    Thanks for the quick replies.
    The shop was talking me out of it.
    Didnt pay anything today. They let me know where I was at right now.
    I talked to JBA yesterday on the phone. He mentioned having enough clearance at the cab mount I believe at full crank. I got about two finger widths (index finger and middle) on the driver side and a little more on the passenger. With these new UCAs the tires will sit back some? Dont want to start rubbing. Never did with my 285/75/16. Now I got 265/75/16.
  4. Jan 20, 2017 at 7:13 PM
    #804
    2X4TACOMA
    Just now placed the order!
    Sna and Blackout14 like this.
  5. Jan 27, 2017 at 8:09 PM
    #805
    2X4TACOMA
    Finally! Got the UCAs this morning went straight to the shop to get them installed and just now picked my up truck with new JBA UCAs!
  6. Jan 27, 2017 at 9:14 PM
    #806
    VE7OSR
    VE7OSR нет войне
    Rob II
    Okanagan, Canada
    05 DCLB TRD Sport
    Armour: All-Pro Skid plates - IFS, transmission, and transfer case. Pelfreybilt rear standard plate bumper, Metal Tech Sliders w/ kickout and dimple die filler plates. Front Suspension: OME 885 + NitroCharger 9000 shocks + 1/2" spacers for a 3" lift. Superbumps replacing stock bumpstops. Camburg ball joint UCA SS braid brake lines Future: ADS Extended length, extended length UCA BJ to increase droop capability Rear Suspension: All-Pro Expedition rear leafs, Walker Evans 27" rear shocks, extended rear brake lines (Wheelers Offroad), U -bolt flip kit, rear Timbren bumpstops. Future: Hammer Hangers, Shock relocate, ADS 12" or 14" shock. Interior: Weatherteck floor liners - front, Wet Okoles- front, ScanGauge, LED interior & map lights. Power moonroof. Exterior: Raider Cobra canopy, retrofit headlight by Insight, LED bulbs all around, modified flasher unit for LEDs. Rear diff breather mod. Front diff vibe problem, driver's side needle bearing replaced with ECGS bushing. yet to install: HID Blazer Fog Retrofit, LED Flood & Spot, + switches, fuse panel. swaybar relocate blocks (build my own)
    FIFY as we lift, we loose caster with the stock UCAs. Less caster, means that coming out of a curve, you have to pull the steering wheel back to center; whereas with positive caster the wheels want to go back to center. A front wheel on a bicycle is a perfect example. Bump steer means that when you hit a bump, the suspension wants to pull in the direction of the bump. Positive caster minimizes that effect. Overall the truck feels like it wants to track straight. at 0 caster you are doing all the work at the steering wheel keeping the truck straight.
  7. Jan 29, 2017 at 6:41 PM
    #807
    moweryaviation
    moweryaviation Life begins, where the pavement ends!
    Dixon, California
    2011 Tacoma, 4x4, manual, access cab
    3" (or so) lift, Dakar leafs & 886 up front.OME Sport shocks, Pro-Crap struts up front, SPC UCA's, Brute Force Fab front and rear, super winch 9500, KM2 255/85, Holly Brakes, SS Brake lines, DOT 4 Fluid, Custom bed system, independent bed LEDs, black head lights, Mag Grey grill, DIY 50$ roof tie down system, On Board Air, DIY spare tire swing arm, DIY painted rims, Energy bushings, camp lights, independant power system, BAMF Bolt on Sliders, DIY IFS Skid, DIY Roof Rack, Bad ass additude, one old smart dog, one young dumb dog, and one hot Burnett!
    Does anyone know if these JBA UCA's give me more clearance between the tire and the UCA? Im running 255/85 with no spacers. I am rubbing on the stock UCA. Thanks for the help!
  8. Jan 29, 2017 at 6:47 PM
    #808
    moweryaviation
    Dixon, California
    CRAP! I wonder if the Camburg Ball Joint UCA will do the same.
  9. Feb 2, 2017 at 8:27 AM
    #809
    lockup
    lockup Active Member
    Calgary, AB, Canada
    DCLB Sport
    Just ordered a set. Are there any other recommended parts that should be replaced along with the UCAs, or tips that will help the process go smoother?
  10. Feb 2, 2017 at 2:40 PM
    #810
    JWL
    JWL Well-Known Member
    Jeff
    Greenville, SC
    08 DCSB 4x4 TRDOR
    OME 885, Bilstein 5100, JBA UCAs, 2" Single AAL
    Thanks for the update. Been following this thread for a while. I'm on 884s with stock UCAs, and wanna go a little higher but do it right with these UCAs. Whenever I can blow the cash, I will. Doesn't look like it'll be for a while though :( oh well at least I can keep watching this product get better and better!! I definitely appreciate the work being put into this product and whenever I can enter the market, this will get my business!
    Blackout14 likes this.
  11. Feb 2, 2017 at 2:56 PM
    #811
    JWL
    Jeff
    Greenville, SC
    08 DCSB 4x4 TRDOR
    Yes I have noticed that!! I pretty much have everything I need to know. I'd get the standard versions unpainted. Plenty of places to see how to install them. The video on the product page on his website is also very informative. It's pretty much everything I could want in a UCA haha
  12. Feb 6, 2017 at 12:08 PM
    #812
    JWL
    Jeff
    Greenville, SC
    08 DCSB 4x4 TRDOR
    @Blackout14 Are y'all having any promotions coming up soon or have any available discount codes for TW members?
  13. Feb 6, 2017 at 2:11 PM
    #813
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    No word on long travel yet?
  14. Feb 6, 2017 at 3:45 PM
    #814
    JWL
    Jeff
    Greenville, SC
    08 DCSB 4x4 TRDOR
    Which is what I just did! Can't wait for em to come in. Been wanting to get UCAs since I got this truck 5 years ago. Thank you guys for providing a good product for the money!!
  15. Feb 6, 2017 at 3:47 PM
    #815
    JWL
    Jeff
    Greenville, SC
    08 DCSB 4x4 TRDOR
    Getting him exposure on TW earned him at least one customer!! He is definitely the man!
    2X4TACOMA and Blackout14 like this.
  16. Feb 6, 2017 at 3:48 PM
    #816
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Still need to show some 1st gen love.....
  17. Feb 6, 2017 at 9:52 PM
    #817
    Sna
    Sna Well-Known Member
    Alberta
    ‘15 trd sport 6MT dcsb, mostly stock?
    Exactly....I was going with SPC uca until I found this thread. I will be ordering a set for my taco in the next month in preparation for my lift going on in the spring.
    JWL[QUOTED] and Blackout14 like this.
  18. Feb 8, 2017 at 10:56 AM
    #818
    DSwarP
    DSwarP Active Member
    Pennsylvania
    09 4.0 DCSB 4x4 TRDS Supah White
    I was on the fence with these but when I realized I literally drive by the shop on the way to and from work every day I figured it was a sign. Will be ordering some in the next few weeks I think.
  19. Feb 10, 2017 at 7:36 PM
    #819
    JWL
    Jeff
    Greenville, SC
    08 DCSB 4x4 TRDOR
    Got them in the mail today, very impressed with the fast shipping! Came completely intact. Can't wait to throw them on here in the next few weeks!!
  20. Feb 14, 2017 at 7:38 AM
    #820
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Since Ive had mine, it looks like they offer 2 ball joints now. There JBA ball joint and the MOOG ball joint. The moog is half the cost, but there Ball joint looks aot better in design and material quality.
    My Moog ball joint is all rusted after only 5-6 months. and the boot doesn't seal good, grease comes out of it and lets water and debris in. Thinking about switching to there ball joint soon.
