JBA Offroad Upper Control Arms And Suspension MEGA Thread BS thread
Discussion in 'Suspension' started by tcBob, Feb 24, 2015.
  1. Apr 13, 2017 at 12:11 PM
    #1081
    dgilbert2006
    dgilbert2006 Well-Known Member
    Dan
    Northglenn, Colorado
    2015 Tacoma 4x4 SR5 DCSB
    5100s, Dakars, D2S Retro, Level 8 MK6 285
    Okay. I figured because it drives a help of a lot better on the highway. Thanks.
    Blackout14 likes this.
  2. Apr 17, 2017 at 11:51 AM
    #1082
    cuda2k
    cuda2k Well-Known Member
    Jon
    Allen, TX
    BRM 15 TRD Off Road 4wd
    LVL8 MK6 wheels,SOS Sliders,Smked 3rd Brake,Gibson Exhaust
    My set went on yesterday along with my OME / Nitrocharger coils from Headstrong. Took me a few minutes to realize there was a 10mm slot milled into the bottom of the shaft to keep the balljoing from rotating while tightening down the nut, other than that they UCA's were way easier to do than dealing with trying to thread that coilover in between everything to get it in place.
    Sna likes this.
  3. Apr 21, 2017 at 12:55 PM
    #1083
    Sna
    Sna Well-Known Member
    Alberta
    ‘15 trd sport 6MT dcsb, mostly stock?
    @Blackout14 how long does it usually take Marlin to respond to emails?
  4. May 1, 2017 at 10:13 AM
    #1084
    DSwarP
    DSwarP Active Member
    Pennsylvania
    09 4.0 DCSB 4x4 TRDS Supah White
    Installed mine yesterday, it was really much easier than I was expecting, and all my rumbles and grumbles that my front end used to give me are gone! Smooth as butter baby!
    Fixed my rubbing on the drivers side too... but also introduced rubbing on my passenger side lol. Alignment coming Wednesday...
    DrFunker and Blackout14 like this.
  5. May 25, 2017 at 2:42 PM
    #1085
    Sna
    Alberta
    My suspension is getting installed June 12th....I'll post here once it's done.
    beachingtaco, DrFunker and Blackout14 like this.
  6. May 27, 2017 at 7:31 AM
    #1086
    MO Tacoma
    MO Tacoma Well-Known Member
    Castle Rock, CO
    2014 DCLB with a couple mods
    ADS extended travel, 14" 700 lb springs, Total Chaos UCA/LCA, Dakars. 37/12.50r17 Pitbull Radial Rocker. SCS 17" SR8. 4.56s with f&r ARB lockers. Relentless sliders, full skids, debadged. 35% tint on all windows. Katzkin leather w/ heated seats
    Are a lot of people running these with 35s? I ordered a set of std high caster. Happy with the build quality, the chevy ball joint integration and the articulation capabilities. Installed them last week and I rub a decent amount on the flat lip where it connects to the tubular arm when turning. I was not even close with stock uca but know that's apple and oranges. I ordered a set of spidertrax but will have to tub the firewall if I keep this setup. The only other option I see is different uca. Has anyone else run into this situation?
    I'm running SCS SR8 17"
  7. May 27, 2017 at 7:48 AM
    #1087
    Taco1999
    Taco1999 Well-Known Member
    Jeremy
    Slidell, Louisiana
    2014 Tacoma Double cab 4x4 trd
    i was rubbing in the same spot when i turn at full lock with 275/70/18 4.5 backspacing. im hoping that with my new ray 10's ill be ok since they are 4.0 backspacing.
  8. May 27, 2017 at 7:53 AM
    #1088
    MO Tacoma
    Castle Rock, CO
    I think the sr8 are 4.30 bs and don't think it's enough to clear the uca. I still have a good half a turn of the steering wheel to go. But... the same setup works on one truck and not another. Let me know how it turns out.
  9. May 27, 2017 at 7:59 AM
    #1089
    Taco1999
    Jeremy
    Slidell, Louisiana
    With the 4.5bs i had to stop about a 1/4 turn before full lock.Just the edge of the tire treadblock would rub on the flat spot. I think it sticks out farther than the stock arms cause i didnt rub at all on those. Waiting on tires now so we'll see how it goes. Might clear if you go to 33's
  10. May 27, 2017 at 8:13 AM
    #1090
    Taco1999
    Jeremy
    Slidell, Louisiana
    I'm also running about 4 degrees of caster...I'm almost curtain if i dail that back some it wont rub...just a theory.
  11. May 27, 2017 at 8:24 AM
    #1091
    Taco1999
    Jeremy
    Slidell, Louisiana
    If I cant get my new setup to not rub I will be buying different UCA's
  12. May 27, 2017 at 11:54 AM
    #1092
    ETaco23
    ETaco23 Marshall offroad Fabrication
    Evan
    PNW
    13' Pyrite Mica TRD Offroad DCSB 4x4
    Color Match Grille, Bed mat, Kings with JBA UCA's, Dakars and 34" BFG KM3, Snugtop Canopy, and my "Marshall Fabrication" Rock Sliders.
    Yeah Im starting to wish I went with different UCA's.. first thing I came across was the rubbing issue. with 4.5" BS wheels and 0mm offset.. and 285's.
    So I had to get wheels spacers, (which JBA should reimburse me for.)
    Then I got different wheels with 4.75" BS and up'd my tire size to 34"x11.5" on 17" wheels. and I have to run the 3/4" wheel spacers in order to clear ofcourse.
    Then there was the moog ball joint issue of them rusting to shit in 4 months. grease leaking all over and the ball joint not sealed in the boot, water and dirt easily got inside. So then I got there new Ball joints, the Stainless ones that are definitely better in design and quality but still the boot doesnt totally seal and grease comes out.
    So after all that, I couldve bought Total Chaos UCA"s and been done. Ive had them in the past and they are awesome. So what if you have to keep the Uni-ball clean and lubed. It wasnt that bad to keep up on.
    Fix the quirks and kinks JBA and your UCA's could be a great buy!!!
  13. May 27, 2017 at 10:15 PM
    #1093
    ETaco23
    Evan
    PNW
    No worries, and yeah the boot on the moog's didnt seal at all. The top iner was wide open, so when you grease them the grease just comes out the top and I had water and dirt get in there. I didnt want to wait till they failed in few months up here in the PNW. So I just got his new ST Ball Joints.
  14. May 31, 2017 at 7:03 AM
    #1094
    randomguy
    randomguy Well-Known Member
    The Dalles, OR
    17 T4R 4x4 MGM
    Anyone running these with stock sport wheels and 265s?
  15. May 31, 2017 at 8:56 AM
    #1095
    Age315
    Age315 Well-Known Member
    AJ
    Castle Rock, CO
    2016 BBP Yeti Mobile
    TRD Baja Kit with JBA UCA's 1/2 inch spacer on top, Medium Dakars with BAMF hangars and super bumps all around. 285/75/16 Cooper Discoverer AT3 XLT's on graphite TRD faux beadlock wheels. Pro skid powder coated black with Pelfreybilt aluminum mid skid and aluminum gas tank skid.
    I would of never thought of that. Will these work with 285's on stock wheels with 1.25 inch spacers?
  16. May 31, 2017 at 9:23 AM
    #1096
    Age315
    AJ
    Castle Rock, CO
    Thanks for letting me know.
  17. Jun 1, 2017 at 3:37 AM
    #1097
    JLRSR5
    JLRSR5 Member
    Has anyone ran these JBA's with 17" Method NV wheels?? I've got these but am concerned about fitment with 285's bc the backspacing on my wheels is 4.75.
    Worried about UCA rubbing the tire?
  18. Jun 1, 2017 at 3:56 AM
    #1098
    Taco1999
    Jeremy
    Slidell, Louisiana
    I know with an 18'' 4.5bs they will rub...so its a pretty good possibility 17'' with 4.75 will rub.
  19. Jun 1, 2017 at 6:45 AM
    #1099
    JLRSR5
    JLRSR5 Member
    @Taco1999 I was afraid of that. Reckon I'll have to look elsewhere, I do not want to have to deal with UCA tire rubbing=headache.
  20. Jun 1, 2017 at 9:46 AM
    #1100
    JLRSR5
    JLRSR5 Member
    I could add wheel spacers, but I'm ot sure if wheel spacers would help to clear the UCA enough.
