JBA UCAs and 255/85/16s?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by rain76king, Feb 20, 2020.
  1. Feb 20, 2020 at 4:42 PM
    rain76king
    rain76king [OP] Well-Known Member
    Bob
    Boston, MA
    A Tacoma and a bunch of Landcruisers
    Stock
    Looking to lift my tacoma 2-3”.
    Acquired parts over the last few years and looking to slap her together.
    Running 255/85/16s on steel 16x7 16 hole Tacoma rims.
    From what I gather there’s not an enough offset to use JBA’s?
    unless I run a mega spacer which sort of defeats the purpose of running this combo.
    will I run into this problem with other UCAs or just with JBAs?
    thanks in advance.
  2. Feb 20, 2020 at 5:16 PM
    pdaddy
    pdaddy WeLl-KnOwN mEmBeR
    Preston
    Central AL
    ‘13 DCSB Converted Prerunner 4wd
    Same issue. I want 235/85/16s and need UCAs.
  3. Feb 20, 2020 at 5:34 PM
    Alexely999
    Alexely999 Well-Known Member
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    255/85/16s are skinnier than 265/75/16s so i would assume that they would be fine?
    The only reason you would need upper control arms would be due to a 3” lift. Not that tire size.
  4. Feb 20, 2020 at 5:38 PM
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    265/75/16 are about 10.5” wide.
    255/85/16 are about 10” wide.
    235/85/16 are about 9.25” wide.
  5. Feb 20, 2020 at 5:43 PM
    pdaddy
    Preston
    Central AL
    It says on the JBA website JBA UCAs will not work with 255/285/16 tires on stock rims, it needs an offset. But 265/75/16 tires will work and they are recommended on their website.
    DG92071 likes this.
  6. Feb 20, 2020 at 5:45 PM
    Sna
    Sna Well-Known Member
    Alberta
    ‘15 trd sport 6MT dcsb, mostly stock?
    Need offset and backspace information for your wheels but I have the same size tires on 3rd gen TRD Pro wheels (IIRC 16x7, 4.5bs, -13 offset) and I just just rub at full lock.
  7. Feb 20, 2020 at 5:46 PM
    Greenedmc
    Greenedmc Well-Known Member
    Daniel
    Elizabethton TN
    2014 Silver Tacoma Trd Off Road Access cab
    FWIW. 265/75/16 and 235/85/16 are the same height. Both of which are close to a 31. 255/85/16 is a 33. The taller tire may be more likely to rub.
    Edit to add: But the big factor for the UCA rubbing will be your offset
  8. Feb 20, 2020 at 5:46 PM
    rain76king
    Bob
    Boston, MA
    Stock
    So this issue is just brand specific?
  9. Feb 20, 2020 at 5:46 PM
    IdeaMan
    IdeaMan Well-Known Member
    Jim
    Fresno, CA
    Barcelona Red 2018 Toyota Tacoma SR DCSB 4x4
    Eibach Pro Truck Lift, Icon RXT Leaf Springs, LT255/80R17 Toyo ATIII, Body Armor Hiline Bumper w/OZ LED Light bar and Smittybuilt X20 Synthetic Winch, TRD Pro Skid plate, Shrockworks Sliders/steps, bed mat, some interior storage accessories, cell phone mount, and blacked out emblems.
    I'm very interested in this as well because that's the only thing holding me back from getting the JBA's. I may want to move from 265/75/16's to the 255/85/16's.
    pdaddy likes this.
  10. Feb 20, 2020 at 6:24 PM
    rain76king
    Bob
    Boston, MA
    Stock
    I’ve spent most of the night trying to find what the backspacing of my stock 16 hole 16x7 steelies are... with no luck.
    I know how to measure for them but just haven’t yet.
  11. Feb 20, 2020 at 7:23 PM
    Sna
    Alberta
  12. Feb 20, 2020 at 8:10 PM
    rain76king
    Bob
    Boston, MA
    Stock
    Looks like 16 Hole 16x7 Taco spare rim - 4 3/4 backspace
  13. Feb 21, 2020 at 6:05 AM
    Alexely999
    Alex
    Bay Area, CA
    2015 DCSB 4X4
    what size tire do you currently have?
  14. Feb 21, 2020 at 6:13 AM
    Voltron4x4
    Voltron4x4 Well-Known Member
    Denver, Colorado
    2014 Black Trail Limo
    This and that...
    Running 265/70/17in on stock UCA's with 2.5 inches of lift. The Wildpeaks get pretty close to the edge of the UCA. I would imagine when I go to a 255 it would make this a tad better with stock rims at 0 offset. Just bought some Spidertracx though. Would like to know more about a skinny with those UCA....
  15. Feb 21, 2020 at 6:23 AM
    rain76king
    Bob
    Boston, MA
    Stock
    I currently run 2/55/85/16 with no lift.
  16. Aug 25, 2020 at 10:40 AM
    pdaddy
    Preston
    Central AL
    Anyone run 255/85/16 on stock wheels with the JBA uca? Will I need spacers to clear the uca?
  17. Dec 18, 2024 at 9:48 AM
    TaCoHiOgUy
    TaCoHiOgUy Well-Known Member
    Eric
    2008 Regular Cab 4WD 5 Speed
    Eibach Pro Truck 2, 1.5" AAL, 255/85/16, JBA UCA
    Hoping someone is still a part of this thread. Did anyone ever confirm if 255/85/16 will rub on the JBA? Weather it be at the ball joint or further up on the arm while turning?
