Jba uca's
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tbone15, Mar 29, 2021.
  1. Mar 30, 2021 at 8:25 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    That's not true.
    Unless you are looking for some very specific application, like racing or something, you should always opt for the factor specs.
    Tbone15[OP] likes this.
  2. Mar 30, 2021 at 11:44 AM
    Nano909
    Nano909 Stirrer Of Pots
    Xcab 3.4 4wd 5MT
    With what spec wheels?
    alarka[QUOTED] likes this.
  3. Mar 30, 2021 at 11:44 AM
    Nano909
    Xcab 3.4 4wd 5MT
  4. Mar 30, 2021 at 12:00 PM
    jbrandt
    Justin
    This.
    Backspacing and width determine where the tire will sit relative to the suspension.
    Also, tire brand/tread pattern also do a lot to determine if it'll rub or not. Even within the same brand, an all terrain vs. a mud terrain of the same nominal size will measure differently, and may or may not rub. Even more, same nominal size and tread style (i.e mud terrains) will measure differently among different brands.
    Then there's suspension setups, too.. Different lift amounts, different components (UCAs, etc...) all have a say in what rubs and where/when it rubs.
    But probably the biggest thing is people who say "it never rubs" who may have never taken their truck offroad and therefor never actually compress the suspension much, so in those cases you might be able to surmise that it at least doesn't rub in parking lots...
  5. Mar 30, 2021 at 12:18 PM
    Tbone15
    Tbone15 [OP] Well-Known Member
    Trystan gates
    1996 toyota tacoma Xtra cab 4x4
    None yet
    I just contacted JBA and they said they don't use moog they make there own in house. I did look on there website and moog works as a replacement
  6. Mar 30, 2021 at 12:21 PM
    Nano909
    Xcab 3.4 4wd 5MT
    Would love to see someone try using 33's with stock wheels and think they can clear without any rubbing installing these UCA's cause of the no context posts you guys made....
  7. Mar 30, 2021 at 12:27 PM
    Nano909
    Xcab 3.4 4wd 5MT
    Doesn't explain a thing. :blahblah:
  8. Mar 30, 2021 at 12:31 PM
    Tbone15
    Trystan gates
    None yet
    How much did it cost to get your body line sprayed? Im guessing you used bedliner?
  9. Mar 30, 2021 at 12:35 PM
    OpeCity
    OpeCity Well-Known Member
    Long Beach, CA
    Aftermarket wheels and the body lift probably add some context
  10. Mar 30, 2021 at 12:40 PM
    Nano909
    Xcab 3.4 4wd 5MT
    What specs are the wheels then since that pic tells you everything?
  11. Mar 30, 2021 at 12:45 PM
    OpeCity
    Long Beach, CA
    It doesn’t tell us anything
  12. Mar 30, 2021 at 12:45 PM
    Nano909
    Xcab 3.4 4wd 5MT
    Exactly
  13. Mar 30, 2021 at 12:47 PM
    OpeCity
    Long Beach, CA
    I was agreeing with you
  14. Mar 30, 2021 at 12:52 PM
    Nano909
    Xcab 3.4 4wd 5MT
    I know, I was acknowledging your agreement lol
  15. Mar 30, 2021 at 2:27 PM
    #35
    Brandons2004tacoma
    Brandons2004tacoma Member
    Brandon
    2004 toyota Tacoma Double cab
    has anyone put these on 1st gen 2WD? it says on JBA website 4WD only but i don't see why there would be a difference? has anyone put these on their prerunner? or can confirm they will fit?
  16. Mar 30, 2021 at 2:33 PM
    #36
    Davesbruh
    Davesbruh Well-Known Member
    Dave
    Orange County
    02 Prerunner double cab that identifies as 4x4 and is transitioning
    Bootleg special
    Prerunners and 4wd are same suspension. When they say no 2wd it is referring to 5lug
    MalinoisDad likes this.
  17. Mar 30, 2021 at 3:08 PM
    #37
    alarka
    alarka Well-Known Member
    WNC/SE GA
    2k X cab 3.4 5spd
    King ex travel, JBA UCA’s, All Pro Springs/shackles, Locked, all new poly bushings & rack, SS brake & clutch lines, ext bumps for starters.
    16x8 4.5 BS
    Area51Runner likes this.
  18. Mar 30, 2021 at 3:33 PM
    #38
    MalinoisDad
    MalinoisDad Misanthropic dog person
    Michael
    01 TRD PreRunner 5VZ
    5100s w/ 881s, JBA UCAs, J59s, other stuff and things
    I have the JBA UCAs on my 2001 Prerunner. I'm happy with one minor exception. The boots for the ball joint started cracking on both sides after only two weeks of light duty street driving. Not a huge deal and I do feel like JBA is working to send this of us affected by this premature failure a newer style boot. Seems like a solid company with solid products. On the back of the letter from the owner is their lifetime warranty. Lifetime warranties usually have strings attached but the words sure sound nice. Haha
    Thunder Fist likes this.
  19. Mar 30, 2021 at 3:38 PM
    #39
    Tbone15
    Trystan gates
    None yet
    When did you buy them? I thought they fixed that problem. Thanks
  20. Mar 30, 2021 at 3:39 PM
    #40
    Nano909
    Xcab 3.4 4wd 5MT
    I asked a simple question, you could have responded with "I don't know" instead of a series of vague responses. UCA's alone won't fix any rubbing issues as you implied. I'm just watching out for the random people that read through these forums and don't post as I used to.
