Actual Moderator with a Tacoma...But Definitely Not a Build Thread
Discussion in '2nd Gen. Builds (2005-2015)' started by jberry813, Oct 10, 2016.
  1. Feb 25, 2017 at 1:45 PM
    #1101
    JWROSE4
    JWROSE4 Well-Known Member
    Jonny
    Virginia
    2013 DCSB SR5 4X4
    Work In Progress
    Gotcha....thanks
  2. Feb 25, 2017 at 3:58 PM
    #1102
    tetten
    tetten Cynical Twat Waffle
    Andy
    Socal
    I want to re-position my reservoirs/hoses but KING angled the hoses in a goofy manner when they tightened the JICs. If I loosen up the JIC fittings a half a turn am I going to start pissing oil and nitrogen all over myself?
  3. Feb 25, 2017 at 3:59 PM
    #1103
    jberry813
    jberry813 [OP] Professional Fluffer Moderator
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    I have an Air Zenith OB2 compressor. They are baller in terms of $, but they have the highest CFM out of any single compressor I've seen on the market. The ARB dual has a higher CFM rating, but it also draws something like 68 amps vs 35. I wouldn't be worried about the ARB double. Just make sure you plan ahead with your electronics.
    I had the ARB single (CKMA12) in my first gen and in the wife's T4R. No complaints with it. I beat the shit out of them and the only thing that has gone wrong is I had a pressure switch take a shit. They are just not as fast as my current compressor.
  4. Feb 25, 2017 at 4:01 PM
    #1104
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    This is gonna sound really really homo, but I've had it go both ways. I've successfully moved them, and I've also been squirted in the eye.
  5. Feb 25, 2017 at 4:01 PM
    #1105
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Clearance
  6. Feb 25, 2017 at 4:02 PM
    #1106
    tetten
    Andy
    Socal
    Damn, I'll have to wait to get a nitrogen kit to screw with em then.
  7. Feb 25, 2017 at 4:05 PM
    #1107
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    You won't loose nitrogen. You'll loose oil. The nitrogen cavity is separated from the shock oil by the IFP (Internal Floating Piston) in the resi. You just gotta be quick when you adjust it. If you loose too much oil, the IFP will bottom out against the resi cap on rebound.
    SonnyBones and tetten[QUOTED] like this.
  8. Feb 25, 2017 at 4:31 PM
    #1108
    AaronArf
    AaronArf Well-Known Member
    Aaron
    VA Beach
    2023 LR OR DCSB
    You have to look at the flow rates @ pressure. This is a common misrepresentation in the compressor world for advertising purposes. Makes 1000000 CFM at 10psi...lol then falls off at your usable range.
  9. Feb 25, 2017 at 4:39 PM
    #1109
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Touche. I was trying to talk in small words for @Fernando though.
    Holloman, Fernando and T4RFTMFW like this.
  10. Feb 25, 2017 at 4:40 PM
    #1110
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    :ohsnap:
  11. Feb 25, 2017 at 4:42 PM
    #1111
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    BTW...the grill in your avatar is almost the same size as a third gen.
    Bentrodder likes this.
  12. Feb 25, 2017 at 4:47 PM
    #1112
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    Thank god its not a 3rd gen though!! Seeing how shitty they are makes me want to find another virgin 2nd gen and put it away till I get the itch to build another taco again. Grandpa truck life isn't too bad, still working on getting rid of the chrome crap though.
  13. Feb 25, 2017 at 4:56 PM
    #1113
    SixthSnail
    SixthSnail I have no idea what I'm doing
    Los Angeles
    '14 Tacoma Sport
    See Build in Sig
    I can see again!
    stairgod and jberry813[OP] like this.
  14. Feb 25, 2017 at 5:36 PM
    #1114
    Soul Surfer
    Soul Surfer J!m! Was Last Seen: Roam in’ Around…
    J!M!
    West Central Florida Coast
    I had to loosen one of my Fox 2.5 Rear Resiervor hoses, and turn it 180* for it to be correct. Just cracked it lose and kept the wrench on the nut and worked the hose and Resi around into position. Tighten it back up and all is good.
  15. Feb 25, 2017 at 5:36 PM
    #1115
    Fernando
    Fernando Hammerdown
    Fernando
    Sacramento
    04 Tacoma DC 4x4
    Too many, See Build
    Great breakdown...thanks jason
    Much appreciated
    I think you just called me stupid? :wave:
  16. Feb 25, 2017 at 7:58 PM
    #1116
    anthony250f
    Anthony
    San Diego, CA
    Do you have any pics of how close the tire is to the spindle gussets with 4.75 bs ?
  17. Feb 26, 2017 at 5:11 AM
    #1117
    bski22
    bski22 Shaka Zulu \000/
    Rob
    Toyota
    What's your RPMS at 70mph with the 4.88s? And how do the gears and the super charger benefit/work in unison from using 4.88 vs let's say stock?
  18. Feb 26, 2017 at 5:41 AM
    #1118
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    If those cross bars in the grill are bolt in I'd trade you my all black ones for the chrome in a split second cause I love how they look!
  19. Feb 26, 2017 at 12:41 PM
    #1119
    AaronArf
    Aaron
    VA Beach
    2023 LR OR DCSB
    DEAL!
  20. Feb 26, 2017 at 4:44 PM
    #1120
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Ok so I got the 4x HD shackles installed. I'm gonna give them a solid "meh" rating. They are without a doubt beefy as shit, but a few things to note.
    First off, either their bandsaw sucks ass, out of adjustment, or needs a new blade. Nothing was cut true. Both the bushing sleeves and the tube on the shackle were cut at an angle, enough so the naked eye could see. Also one of the sleeves was too long and I had to hit it with a flap disk to shorten it.
    Also, the provided bushings are not full length. With the bushings installed, there is a solid 1/2" gap inside the tube. Kind of a minor detail, but I prefer longer bushings so they don't deflect as much and I don't have to pump 25 squirts of grease to fill the void.
    Next, 4x states the shackles are factory length. Putting them side by side with a bolt through the bushings to center them, you can see the 4x ones are slightly longer. I mic'd them and the 4x shackles are 3/32" longer eye to eye over factory. Definitely not a large difference, but it did drop my ride height not quite 3/16" on both sides.
    Lastly the ears on the shackles that wrap the spring pack bushing were a little too wide also. Made for easy installation, but the ears actually had to bend in almost 1/8" before the torque wrench finally clicked. All that being said, definitely beefy, good hot welds, and clearanced everything fine. But some extra attention with cutting, assembly, and tolerances would make it worth the $100.
    Since I had a the rear end halfway apart to install the shackles, I figured now would be a good time to measure for estimated travel numbers with the new leaf pack and shackles. I had the shocks completely disconnected for this exercise and made sure I had adequate plunge in the driveshaft slip joint. Since I have have hydro bumps, I can see exactly where the leaf pack will bottom out with the hydro bump completely compressed. With everything the way it sits, the pack and shackle allows for 10.0" of travel. The limiter at this point was the rear most spring retainer on the leaf pack.
    For giggles I removed the rear spring retainers to see how much farther it would go. With the rear retainers removed, the axle dropped out another 1/2" and was now limiting on the front spring retainer.
    So again, for giggles, I removed the front spring retainers.
    When that happened, the leaf below the main leaf came in contact with the shackle hanger preventing it from dropping out more.
    A little pry bar and ford tool action and the leafs settled into their full droop. Again, this came out to another 1/2" for a total travel of 11"
    Now...science. Removing the retainers and wheeling it is not the right decision. You can see how far the leafs splay out from the main leaf. In this configuration, ALL of the unsprung load will be resting on just the main leaf. This is a recipe for a broken main leaf. When it warms up enough to do my shock hoops and install the triple bypasses, I'll cycle and burn everything in without the spring retainers, but they are definitely staying installed. Too much weight on the main leaf splayed out like that. I'll also probably bring the hydro bumps up 1/4-1/2" for a little more bump travel. With the slightly longer shackles I should be able to bring it up without going too much negative.
    @Crom, this is kind of what I was alluding to in the overland thread. There's absolutely no way in hell you can pull 13" of travel with factory geometry SOA, not even if you ran no bumps at all and let the spring pack bump off the frame.
