Actual Moderator with a Tacoma...But Definitely Not a Build Thread
Discussion in '2nd Gen. Builds (2005-2015)' started by jberry813, Oct 10, 2016.
  1. Oct 10, 2016 at 1:12 PM
    jberry813
    jberry813 [OP] Professional Fluffer Moderator
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    That's right. I was told the dark side has cookies so I bought a second gen. I was on the hunt for a first gen double cab (just the cab) for the last 8 months and came up short. Everyone was way to proud of them to be worthwhile. So, I bought a second gen and put the RDP up for sale.
    Vehicle
    2012 Toyota Tacoma DCSB TRD Sport
    4.0L V6 1GR-FE
    4x4 w/5 Speed Auto
    Performance
    Magunson Supercharger
    Currie Ford 9" Fabricated Rear Axle with 3.5” Axle Tubes, Truss, Fill/Inspection Port, Desert Skid, and 68” WMS-WMS
    4.88 Front Gears and 4.86 Rear Gears
    Dual ARB Lockers
    Dual Optima Yellow Top Batteries Relocated to the Bed
    SOS Performance 6 Piston StopTech Front Big Brake Kit
    SOS Performance Rear Disk Conversion with 4 Piston StopTech Big Brake Kit
    MBRP Cat Back
    URD Y-Pipe
    URD 2.85 Pulley
    Shoes
    Method 105 Matte Black Beadlock Wheels 17x8.5 (4.75BS, 0mm Offset)
    Cooper STT Pro 315/70/17
    Front Suspension
    Total Chaos +2" Race Series Long Travel Kit
    King LT Coilovers with 700# Springs
    King 8" Secondary Triple Bypasses
    Fabricated Secondary Shock Hoop
    Total Chaos Alignment Cam Tab Gussets
    Total Chaos Coil Bucket Gussets
    Total Chaos Spindle Gussets [Sway Bar Version for Extra Strength]
    Total Chaos +2 Extended CV axles
    SDHQ High Angle CV Boots
    Rear Suspension
    Custom Deaver Leaf Pack
    BAMF HD Shackle Hangers
    BAMF HD Shackles
    King 2” Hydro Bumps
    King 12" Triple Bypasses
    Fabricated Shock Hoops
    Frame Plates
    Lights
    FXR HID Retrofit by Ambiguous (Osram SVS 4300k Bulbs, Morimoto 35w Ballast, Apollo Srouds, XBAL LED Halo's)
    Rigid 40" Midnight LED Roof Bar
    Relentless Fabrication Ditch Light Brackets
    Rigid D2 Dually Driving LED Ditch Lights
    Rigid SR2 20" Combo Driving/Hyperspot LED Bar
    Rigid D2 Amber Driving LED's for Fog Lights
    Rigid D2 Dually Driving Reverse Lights
    LED Lights (Dome, License plate, Map Lights)
    FLYZEYE V2W LED Dash Light
    FLYZEYE 3VP Console Light
    Fog Light Mod (On Anytime)
    886 Bulb Reverse Light Mod
    Exterior Goodies
    Relentless Fabrication Front Bumper (Full hoops, Light Bar Cut Out, Fog Cut Out)
    Relentless Fabrication Skids (IFS/Mid/T-case)
    Pelfreybilt Gas Tank Skid
    Warn ZEON 12-s Winch
    Warn Wireless Winch Controller
    Factor 55 Ultrahook
    Factor 55 1.5 Aluminum Hawse Fairlead
    Relentless High Clearance Rear Bumper w/ Swing Out & Bed Side Protection
    Relentless Fabrication Sliders
    Relentless Fabrication Aluminum Tailgate Reinforcement
    Vagabond Outdoors Drifter Camper
    Two 100 Watt Solar Panels
    Renogy Adventurer Solar Controller
    ARB Drawer
    Alu-Cab Fridge Slide
    ARB 82 Quart Fridge
    ARB Hydraulic Jack
    Relentless Fab Axe/Shovel mount
    Stock Fenders & Flares Cut ~2" Front/Rear
    Airflow Snorkel
    Red line Quick Lift Plus Hood Struts
    Stainless Steel Goodridge Extended Brake Lines
    Blue Sea 5026 Auxiliary Fuse Panel w/ Blue Sea 7144 100A Breaker
    Blue Sea USB Charging ports (One in Bed / One Interior)
    Rear Diff Breather Mod (Toyota PN Union: 90404-51319, Plug: 90930-03136 & Fuel line)
    Pelfreybilt Bed Side Supports
    ARB Dual Air Compressor
    Slee Air Compressor Mount
    Powertank ARB Solenoid Manifold
    Cab Mount Chop
    Prinsu CABRAC Roof Rack Chopped
    Pelican Storm Cases containing Recovery Gear
    Energy Suspension Poly Body Mounts
    Total Chaos Rear Channel Bed Stiffeners
    Interior Goodies
    Weathertech Floor Mats
    Wet Okole Seat Covers Front & Rear (Charcoal/Black)
    ImMrYo Rear View Mirror relocation bracket
    OTRATTW Switches in Custom Housing
    Speedhut Wideband and Boost Gauges on A-pillar
    Ultra Gauge EM V1.2
    Kenwood TM-V71A HAM Radio
    Overland AF Patch Collection
    As with all of my builds, stay tuned for fun coupons being spent.
  2. Oct 10, 2016 at 1:12 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Small collection of pictures taken on my drive home, mostly involving tomfoolery and shenanigans.
  3. Oct 10, 2016 at 1:12 PM
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    First real "mod" I did after I got it home was the bedrack. The bedrack is actually @RelentlessFab's new bolt-together prototype for the Tundra. But a quick phone call to the man himself and he got me a set of crossbars that fit the tacoma bed-width the same day. Got the Kukenam all mounted and this bitch is ready for Tepui fest.
    Well...almost. I had to mount my new fishing boat to complete the "adventure ready" look.
  4. Oct 10, 2016 at 1:20 PM
    Acerwin
    Acerwin The unNORM NORM
    Andrew
    South Carolina
    Toyota Tundra
    :yes:
    ChadsPride likes this.
  5. Oct 10, 2016 at 1:23 PM
    colinb17
    colinb17 If at first you don't succeed, don't try skydiving
    Colin
    Charleston, SC
    '07 TRD Sport 4x4
    Build thread in sig... 4-link long travel
  6. Oct 10, 2016 at 1:23 PM
    Bentrodder
    Bentrodder PeeRunner Fanboy
    Peter
    Cotati, CA.
    2015 DCLBFTMFW TRD Sport
    Kings and a TW DECAL!!!
    First for the newds!!!!
    EDIT: Crap got beat! Still here for the newds!
    bski22, ChadsPride, grdgz97 and 2 others like this.
  7. Oct 10, 2016 at 1:25 PM
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    Damn. Pretty sweet built rig. Aaron did a good job. Hadn't popped in on his thread in years.
    sjwhitaker and ChadsPride like this.
  8. Oct 10, 2016 at 1:25 PM
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
  9. Oct 10, 2016 at 1:28 PM
    t.hornstra
    t.hornstra Well-Known Member
    Ted
    NorCal
    White with 4 wheels
    Little this. Little that 4x4 Swap’d PreRunner
  10. Oct 10, 2016 at 1:30 PM
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    sub for BS.
  11. Oct 10, 2016 at 1:30 PM
    ramonortiz55
    Ramon
    Texas
    stock
  12. Oct 10, 2016 at 1:31 PM
    Roll Tide
    Roll Tide COO COO KACHOO
    Q
    Here and there. Sometimes.
    01 T4R
    Head unit. That's it.
    WOW.
  13. Oct 10, 2016 at 1:34 PM
    Whitecloud
    Whitecloud Cloudy-fabricator of things
    Johnathan
    Albuquerque, New Mexico
    Superwhite 06 DCLB
    ICON Extended travel Coilovers, Custom leaf pack, custom sliders and F&R bumpers, 295 75 17 Toyo Open Country MT's, On-Board air with F+R connectors, On-Board water with quick disconnect shower.Trimmed fenders and body mount chop. LOTS of wiring, dual battery setup, Solar charging system, with some random lights spread around here and there.
    Subbed for the laughs and the internet butt hurt that will happen at some point.
  14. Oct 10, 2016 at 1:35 PM
    Slimwood Shady
    Slimwood Shady I love your mom!
    Linwood
    San Antonio, TX
    '23 TRD Pro Tundra; 996TT; '16 Odyssey
    #nomods
  15. Oct 10, 2016 at 1:36 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    First page.
    JennJenn and ChadsPride like this.
  16. Oct 10, 2016 at 1:39 PM
    Breezy
    Breezy vaping in my subaru
    @breezy.images
    Bardstown, KY
    Ferd Fuckus
    :popcorn:
    One of my favorite builds on here lives again!
  17. Oct 10, 2016 at 1:39 PM
    DCLBFTW
    DCLBFTW Well-Known Member
    Minnesota
    06 dclb
    OME 887's, Bilsten 5100 up front at 0, dakers and nitro-charges in the back, 9500lb winch, 42" led light bar on an oem rack,ridgid d2's up front and 4 duallys cut in the bumper, Back rack with highlift mounted and a uws tool box 2500 watt power inverter, Body Armor4x4 front and back bumper, leer 100xq cap, all pro skids and sliders
    I was wondering who would buy it
  18. Oct 10, 2016 at 1:40 PM
    siznarf
    siznarf Everyone my age is older than me...
    Francis
    Kommiefornia
    08 Taco
    91 Octane
    How much for this beast?
  19. Oct 10, 2016 at 1:40 PM
    HCJ
    HCJ Well-Known Member
    Virginia --> Texas
    '05 Taco with not enough miles
    Subd
  20. Oct 10, 2016 at 1:41 PM
    916TacoTruck
    916TacoTruck BallzDeep is how I go
    Inyo mom
    2019 Rapturd
    Former 2013 TRD OR. Sickass edition
    I like the ( for now ) stuff.
    1truckdriver and ChadsPride like this.
