jberry's Retarded Desert Penguin
Discussion in '1st Gen. Builds (1995-2004)' started by jberry813, Feb 5, 2011.
  1. Jun 7, 2015 at 12:53 PM
    #3581
    Supra TT
    Supra TT Supercharged Lifter
    Eric
    Indiana
    2000 SAS D60 F/R Supercharged
    Supercharged on One Tons
    Diesel is cool and all until you gotta change your oil which costs $128.............. :pout:
    Nice Tundra man, looks bitchin'
  2. Jun 7, 2015 at 1:19 PM
    #3582
    SACTOWN
    SACTOWN Well-Known Member
    Greg
    What is the Towing on your new one @jberry813? 10k?
  3. Jun 7, 2015 at 3:05 PM
    #3583
    jberry813
    jberry813 [OP] Professional Fluffer Moderator
    Lake Tahoe
    2012 DCSB Sport
    ...too much shit to list.
    Thanks man.
    Just about. 9800
  4. Jun 7, 2015 at 3:11 PM
    #3584
    allmotorrex
    allmotorrex Grove St. Fab
    Gideon
    Memphis 901
    08 SR5 4wd 2.7
    NWF crawlbox, 5.29s, rear Detriot, front Harrop, 37" SXIIs, 17x9" KMC Grenade Crawl beadlocks, Dirt King 3.5" LT kit with King shocks, Fox 12" smooth body RR, BAMF shock kit, AP 3" springs, ext. brake lines, custom 1 piece driveshaft with .135 wall tubeing, GSF front rock crawling bumper, GSF rear bumper, Relentless Fab ifs skid, BAMF k/o sliders, X2O 10K comp. winch, TP glass fenders, OKled 20"bar, EBS dimpled/slotted rotors, EBS green pads, custom K&N CAI, LCE headers, FM Super 44 w/h turn down, URD MAF, Spec clutch, LCE heavy flywheel, URD short shifter, TMPer M1 Abrams shift knob, Amsoil oil, Cobra 75wxst w/h 4' firestix, Grillcraft, FXR TRS, T1 eyelids, custom ADV Monster 60 lights, bed lights, speedo light mod, Glow Shift volt/oil pres gauges, Glow shift 2g column pod, Optima yellow tops dual battery setup w/h IBS system, Pioneer DEH-P7200HD head unit, Pioneer 600W 4ch & 350w 2ch amps for doors and sub, Wet Oakle covers
    Good price. Thats a lot of truck for the price though as opposed to some of these fords and chevys that are 50k
  5. Jun 15, 2015 at 7:08 AM
    #3585
    j0shu4
    j0shu4 98 TRD 4x4, 3.4 Turbo, Full LT, Fully Locked
    98 TRD, Turbo, 3.4L, 4x4, LT
    Turbo, Fiberglass, Full Long Travel, Lockers, T100 axle, King Shocks
    Got a solo motorsports LT kit coming my way. Partial bedcage, king triples, the works. I was told you can run shocks outside the frame rails if done properly on the 1st gen by them. I have also read many members say no. Is this possible using stock trd axle because I want to keep it simple plus retain the elocker? Notching frame? Any input would be super helpful. He has a first gen himself, and has done many so he told me confidently I wouldn't need a tundra axle.
  6. Jun 15, 2015 at 7:11 AM
    #3586
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    You might be able to outboard the shocks on a stock axle, but you would need some pretty aggressive wheel spacers and likely a frame notch. Hell I've seen people notch even with a tundra axle. It all boils down to shock placement.
  7. Jun 15, 2015 at 7:11 AM
    #3587
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    You need a tundra axle if you want to to try to match your rear width with your front width. I would suggest getting a tundra axle to throw in if you're getting a Solo kit. AFAIK it's a pretty easy drop in, I'm sure Jason can elaborate.
  8. Jun 15, 2015 at 7:12 AM
    #3588
    NYCO
    NYCO go explore...
    bOb
    Colorado
    Blue Betty - '06 TRD OR
    dents & scratches
    nice!!!
  9. Jun 15, 2015 at 7:14 AM
    #3589
    VolcomTacoma
    Jeff
    NorCal
    On that subject,
    Jason you said an older econoline axle is best to match up for second gens, how new can they be?
    I also found a '91 f250 10.25 axle that looks like it could work, 69ish wms(haven't purchased). I'm just trying to figure out the logistics of getting all the brakes and abs and everything set up. I really don't want to start pulling fuses for that stuff. Should I just stick with a newer tundra axle and figure out that headache instead?
  10. Jun 15, 2015 at 7:15 AM
    #3590
    j0shu4
    Yeah, I might just do that tundra axle. Was going to run 2" spacers to try and come close to the 3.5" the front will extend out. I don't do lots of jumping and whoops like you guys out there.......my wheels are kmc with huge negative offset.
  11. Jun 15, 2015 at 7:52 AM
    #3591
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Up to mid 80's. 1986 I think. Not at home so can't look at my scribbles.
    I would do a ford 9" way before I would do a new tundra axle. The carrier support is stronger with a 9" and aftermarket/gear ratios are endless with a 9".
  12. Jun 15, 2015 at 8:02 AM
    #3592
    VolcomTacoma
    Jeff
    NorCal
    Gotcha, I'll keep looking
  13. Jun 15, 2015 at 1:28 PM
    #3593
    Mademan925
    Mademan925 Senor Taco
    Nick
    Discovery Bay, CA
    2014 4x4 TRD OFFROAD DCSB
    enough to go over stuff
    Love the interioir on the new truck... I want one. Maybe when I pay off my tacoma
  14. Jun 24, 2015 at 4:57 PM
    #3594
    ebbs15
    ebbs15 Lord Winchester
    Brandon
    Spokane Washington
    09 Lexus GX470
    where did you find those?
  15. Jun 24, 2015 at 5:00 PM
    #3595
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    Amazon
    ebbs15[QUOTED] likes this.
  16. Jun 25, 2015 at 3:20 PM
    #3596
    scocar
    scocar Patron of the Farts
    Ahem.
    "Lost"?
    Might I assume that they were departing the vehicle on hard landings in a manner similar to how one might spit out a watermelon seed?
    nfs257 likes this.
  17. Jun 25, 2015 at 9:34 PM
    #3597
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    I feel like that might be a safe assumption. Except the spitting of seeds isn't in any particular direction I'm aware of.
  18. Jun 26, 2015 at 5:19 AM
    #3598
    VolcomTacoma
    Jeff
    NorCal
    I was thinking more along the lines of Galagher.
  19. Jun 26, 2015 at 11:01 AM
    #3599
    scocar
    But don't the wires act like leashes?
  20. Jun 26, 2015 at 11:49 AM
    #3600
    jberry813
    Lake Tahoe
    2012 DCSB Sport
    The first couple times...yes. There's only so much torture they can take. At some point, like everything else on my truck, they throw their hands up and say "fuck this...I'm out."
    BradyT88 and ebbs15 like this.
