jbezorg's 2018 AC TRD OR Build Thread
Discussion in '3rd Gen. Builds (2016-2023)' started by jbezorg, Mar 24, 2018.
  1. Sep 18, 2018 at 6:10 AM
    Genypig
    Genypig Well-Known Member
    Yev
    2018 Tacoma TRD OR
    Thanks for the thorough answer! Really appreciate it!
    jbezorg[QUOTED][OP] likes this.
  2. Sep 28, 2018 at 9:59 AM
    jbezorg
    jbezorg [OP] Well-Known Member
    Greg
    Gaithersburg MD
    2018 Tacoma AC TRD Off Road
    So I was going to go with Pelfrey but that's not happening.
    I did find a 1/4" aluminium TRD bling plate for cheap which will suffice for now and replace the thin steel stone guards.
  3. Sep 28, 2018 at 10:03 AM
    magicgus323
    magicgus323 Well-Known Member
    Gustavo
    Visalia Ca. East LA LBC
    2016 White Tacoma Sr 2.7
    TRD rims and suspension, TRD grill, stereo iPhone mirroring stormtrooper decal backflip bed cover painted bumper and mirror caps
    What you do with you’re backseats??
  4. Sep 28, 2018 at 12:06 PM
    jbezorg
    Greg
    Gaithersburg MD
    Sitting is a corner along with the back panel and the bin that lined the storage area.
  5. Sep 29, 2018 at 12:45 PM
    jbezorg
    Greg
    Gaithersburg MD
  6. Sep 30, 2018 at 2:48 PM
    jbezorg
    Greg
    Gaithersburg MD
    Fun with plastidip today
    BrotherBudro likes this.
  7. Oct 1, 2018 at 8:53 AM
    CaliRaisedLed
    CaliRaisedLed Well-Known Member Vendor
    Jake
    Texas (DFW)
    Looks great!
    Thanks for choosing us
  8. Oct 1, 2018 at 9:41 AM
    jbezorg
    Greg
    Gaithersburg MD
    More than once :)
    Got your pro grill and bed stiffeners as well.
  9. Oct 7, 2018 at 6:29 PM
    jbezorg
    Greg
    Gaithersburg MD
    Yesterday. along with some "why not" painting of interior trim pieces since I had to take them off anyway. Color does not match but I'm more surprised that there's no visible runs.
    I did forget to buy Ram mounts though.
  10. Oct 7, 2018 at 6:42 PM
    jbezorg
    Greg
    Gaithersburg MD
    Today, a battery install. I went with a Odyssey 31M Battery and the HK-PC2150 hold down kit.
    The first step was partially assembling and placing the hold down kit to check fit and alignment. Using the holes in the back of the base plate, marks were placed on the sheet metal with a sharpie.
    The mount was removed and disassembled. The marks on the sheet metal and the features of the chassis base plate were copied onto tracing paper. The horizontal line you see to the right of the second largest hole marks a limit for the plusnuts. Past that line towards the relay and fuze box there isn't enough space to place a plusnut.
    Tracing paper was then taped to the battery mounting plate using the original 4 marks as a guide.
    Marking and drilling pilot holes.
    Using the pilot holes in the base plate as a guide to drill holes in the chassis base plate. Locking the plate in place by dropping a bolt into each hole as it was drilled.
    We're good! Absolutely paranoid about screwing up this part
    Drill out the pilot holes for the plusnuts, mask and paint.
    While that's drying. Drill out and countersink the base plate.
    So. Plusnuts. Why? Original plan was to use rivnuts however an 8M rivenut has a pullout strength of about 500lbs. An 80 pound battery in a 45 MPH (66 ft/second) accident is going to have a lot of momentum. So. Plusnut install. An 8M plusnut has a pullout strength of about 1,675 lbs. 5 of them should be enough to withstand a 45mph collision.
    Assemble and mount the battery holder.
    Checking the clearance.
    And we're done!
    Took about 5 hours. I have the Slee negative battery terminal. That's for another day and another project. You can see the prep for it in the top plate of the battery mount.
    If this isn't for you. Adventure Wired offers a Stainless Steel Group 31 Hold Down Bracket and J hooks that uses the factory J-hook holes.
    rob1208 and ScottyR like this.
  11. Oct 13, 2018 at 3:52 PM
    jbezorg
    Greg
    Gaithersburg MD
    Moved the fuse off the battery terminal.
    ScottyR likes this.
  12. Oct 20, 2018 at 10:07 AM
    jbezorg
    Greg
    Gaithersburg MD
  13. Oct 28, 2018 at 6:44 PM
    tonykarter
    tonykarter Crappie Savant
    Snuff Gully, Texas
    2018 DCSB 4x4 Sport 1993 4Runner SR5 4x4, 411,000 miles
    Pine tree air freshener
    Where you live? I'm gonna' come over there and do a Vulcan Mind Meld on you. I commend you conceptualization skills. I have been beating my brain trying to come up with a good design for platforms to replace the rear seat and back, and the front passenger seat. THIS is the way to do it. Thank you for posting this up. Amazing work. I am but an overland modding larvae at this point. You sir are a butterfly.
    jbezorg[OP] likes this.
  14. Dec 24, 2018 at 10:07 PM
    Trash_Panda39
    Trash_Panda39 Member
    2018 TRD Off Road Access
    Great find on the bed rack. We have the same truck and I am pondering building up a drawer/bed system but only wanted to do so for half of the bed. My question is how much clearance do you have underneath the rack?? Hoping some old school milk crates would fit nicely underneath.
  15. Dec 26, 2018 at 3:01 PM
    #35
    jbezorg
    Greg
    Gaithersburg MD
    It was the lowest mod on my priority list but I got a great deal on the ARB snorkel. Couldn't pass.
    '18CementTaco likes this.
  16. Dec 26, 2018 at 3:09 PM
    #36
    jbezorg
    Greg
    Gaithersburg MD
    10 3/4". Had to cut a center leg short so it would rest on top of the wheel well.
    Trash_Panda39[QUOTED] likes this.
  17. Mar 30, 2019 at 2:51 PM
    #37
    jbezorg
    Greg
    Gaithersburg MD
    Mounted the FrontRunner roof rack directly to the ARE CX HD internal frame.
    OneFastGeek likes this.
  18. Apr 20, 2019 at 6:26 PM
    #38
    jbezorg
    Greg
    Gaithersburg MD
    Made some Front Runner Rack stuff. Available here (rotopax mounts) and here (quick fist mounts). Should be able to mount them on any surface. The RotoPax mount? Really just useful for the Front Runner rack. The mounting plate that comes with the RotoPax mount will work elsewhere.
    Alternatively I can remove the Quick Fist and use a locking pins as tie down points for light loads.
    MVIMG_20190420_193445.jpg MVIMG_20190420_193631.jpg MVIMG_20190420_194750.jpg Prototype.jpg
  19. Jul 15, 2019 at 9:43 AM
    #39
    WhiteNemesis
    WhiteNemesis Well-Known Member
    Mr PattyCakes
    T-Town, AZ
    Cant get enough
    Blow it through the roof
  20. Jul 15, 2019 at 10:03 AM
    #40
    jbezorg
    Greg
    Gaithersburg MD
    Table saw and a 200 tooth saw blade for light aluminum, plastic, and vinyl.
